root/radiance/ray/src/common/resolu.h
Revision: 2.15
Committed: Mon Apr 6 04:00:08 2020 UTC (5 years, 1 month ago) by greg
Fixed bug where fscnresolu() would over-read string if followed by white space
1 /* RCSid $Id: resolu.h,v 2.14 2019/07/19 17:37:56 greg Exp $ */
2 /*
3 * Definitions for resolution line in image file.
4 *
5 * Include after <stdio.h>
6 *
7 * True image orientation is defined by an xy coordinate system
8 * whose origin is at the lower left corner of the image, with
9 * x increasing to the right and y increasing in the upward direction.
10 * This true orientation is independent of how the pixels are actually
11 * ordered in the file, which is indicated by the resolution line.
12 * This line is of the form "{+-}{XY} xyres {+-}{YX} yxres\n".
13 * A typical line for a 1024x600 image might be "-Y 600 +X 1024\n",
14 * indicating that the scanlines are in English text order (PIXSTANDARD).
15 */
16 #ifndef _RAD_RESOLU_H_
17 #define _RAD_RESOLU_H_
18
19 #ifdef __cplusplus
20 extern "C" {
21 #endif
22
23 /* flags for scanline ordering */
24 #define XDECR 1
25 #define YDECR 2
26 #define YMAJOR 4
27
28 /* standard scanline ordering */
29 #define PIXSTANDARD (YMAJOR|YDECR)
30 #define PIXSTDFMT "-Y %d +X %d\n"
31
32 /* structure for image dimensions */
33 typedef struct {
34 int rt; /* orientation (from flags above) */
35 int xr, yr; /* x and y resolution */
36 } RESOLU;
37
38 /* macros to get scanline length and number */
39 #define scanlen(rs) ((rs)->rt & YMAJOR ? (rs)->xr : (rs)->yr)
40 #define numscans(rs) ((rs)->rt & YMAJOR ? (rs)->yr : (rs)->xr)
41
42 /* resolution string buffer and its size */
43 #define RESOLU_BUFLEN 32
44 extern char resolu_buf[RESOLU_BUFLEN];
45
46 /* macros for reading/writing resolution struct */
47 #define fputsresolu(rs,fp) fputs(resolu2str(resolu_buf,rs),fp)
48 #define fgetsresolu(rs,fp) str2resolu(rs, \
49 fgets(resolu_buf,RESOLU_BUFLEN,fp))
50
51 /* reading/writing of standard ordering */
52 #define fprtresolu(sl,ns,fp) fprintf(fp,PIXSTDFMT,ns,sl)
53 #define fscnresolu(sl,ns,fp) (fgetresolu(sl,ns,fp)==PIXSTANDARD)
54
55 /* defined in resolu.c */
56 extern void fputresolu(int ord, int sl, int ns, FILE *fp);
57 extern int fgetresolu(int *sl, int *ns, FILE *fp);
58 extern char * resolu2str(char *buf, RESOLU *rp);
59 extern int str2resolu(RESOLU *rp, char *buf);
60
61 #ifdef __cplusplus
62 }
63 #endif
64 #endif /* _RAD_RESOLU_H_ */
65
