root/Development/ray/src/common/resolu.h
Revision: 2.16
Committed: Thu Mar 3 03:55:13 2022 UTC (3 years, 8 months ago) by greg
CVS Tags: rad6R0, rad5R4, HEAD
feat: Added float and double alignment to i/o routines for future mmap() use
# User Rev Content
1 greg 2.16 /* RCSid $Id: resolu.h,v 2.15 2020/04/06 04:00:08 greg Exp $ */
2 greg 1.1 /*
3     * Definitions for resolution line in image file.
4     *
5 greg 2.10 * Include after <stdio.h>
6 greg 2.3 *
7 greg 1.1 * True image orientation is defined by an xy coordinate system
8     * whose origin is at the lower left corner of the image, with
9     * x increasing to the right and y increasing in the upward direction.
10     * This true orientation is independent of how the pixels are actually
11     * ordered in the file, which is indicated by the resolution line.
12     * This line is of the form "{+-}{XY} xyres {+-}{YX} yxres\n".
13     * A typical line for a 1024x600 image might be "-Y 600 +X 1024\n",
14     * indicating that the scanlines are in English text order (PIXSTANDARD).
15     */
16 schorsch 2.5 #ifndef _RAD_RESOLU_H_
17     #define _RAD_RESOLU_H_
18 schorsch 2.8
19 greg 2.3 #ifdef __cplusplus
20     extern "C" {
21     #endif
22
23 greg 1.1 /* flags for scanline ordering */
24     #define XDECR 1
25     #define YDECR 2
26     #define YMAJOR 4
27
28     /* standard scanline ordering */
29     #define PIXSTANDARD (YMAJOR|YDECR)
30 greg 2.16 #define PIXSTDFMT "-Y %8d +X %8d\n"
31 greg 1.1
32     /* structure for image dimensions */
33     typedef struct {
34 greg 2.3 int rt; /* orientation (from flags above) */
35 greg 1.1 int xr, yr; /* x and y resolution */
36     } RESOLU;
37
38     /* macros to get scanline length and number */
39 greg 2.3 #define scanlen(rs) ((rs)->rt & YMAJOR ? (rs)->xr : (rs)->yr)
40     #define numscans(rs) ((rs)->rt & YMAJOR ? (rs)->yr : (rs)->xr)
41 greg 1.1
42     /* resolution string buffer and its size */
43     #define RESOLU_BUFLEN 32
44     extern char resolu_buf[RESOLU_BUFLEN];
45
46     /* macros for reading/writing resolution struct */
47     #define fputsresolu(rs,fp) fputs(resolu2str(resolu_buf,rs),fp)
48     #define fgetsresolu(rs,fp) str2resolu(rs, \
49     fgets(resolu_buf,RESOLU_BUFLEN,fp))
50
51     /* reading/writing of standard ordering */
52     #define fprtresolu(sl,ns,fp) fprintf(fp,PIXSTDFMT,ns,sl)
53 greg 2.15 #define fscnresolu(sl,ns,fp) (fgetresolu(sl,ns,fp)==PIXSTANDARD)
54 greg 1.1
55 greg 2.14 /* defined in resolu.c */
56 greg 2.3 extern void fputresolu(int ord, int sl, int ns, FILE *fp);
57     extern int fgetresolu(int *sl, int *ns, FILE *fp);
58     extern char * resolu2str(char *buf, RESOLU *rp);
59     extern int str2resolu(RESOLU *rp, char *buf);
60
61     #ifdef __cplusplus
62     }
63     #endif
64 schorsch 2.5 #endif /* _RAD_RESOLU_H_ */
65
