root/radiance/ray/src/common/resolu.h
Revision: 1.1
Committed: Mon Nov 11 14:03:22 1991 UTC (32 years, 7 months ago) by greg
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * Definitions for resolution line in image file.
7 *
8 * True image orientation is defined by an xy coordinate system
9 * whose origin is at the lower left corner of the image, with
10 * x increasing to the right and y increasing in the upward direction.
11 * This true orientation is independent of how the pixels are actually
12 * ordered in the file, which is indicated by the resolution line.
13 * This line is of the form "{+-}{XY} xyres {+-}{YX} yxres\n".
14 * A typical line for a 1024x600 image might be "-Y 600 +X 1024\n",
15 * indicating that the scanlines are in English text order (PIXSTANDARD).
16 */
17
18 /* flags for scanline ordering */
19 #define XDECR 1
20 #define YDECR 2
21 #define YMAJOR 4
22
23 /* standard scanline ordering */
24 #define PIXSTANDARD (YMAJOR|YDECR)
25 #define PIXSTDFMT "-Y %d +X %d\n"
26
27 /* structure for image dimensions */
28 typedef struct {
29 int or; /* orientation (from flags above) */
30 int xr, yr; /* x and y resolution */
31 } RESOLU;
32
33 /* macros to get scanline length and number */
34 #define scanlen(rs) ((rs)->or & YMAJOR ? (rs)->xr : (rs)->yr)
35 #define numscans(rs) ((rs)->or & YMAJOR ? (rs)->yr : (rs)->xr)
36
37 /* resolution string buffer and its size */
38 #define RESOLU_BUFLEN 32
39 extern char resolu_buf[RESOLU_BUFLEN];
40
41 /* macros for reading/writing resolution struct */
42 #define fputsresolu(rs,fp) fputs(resolu2str(resolu_buf,rs),fp)
43 #define fgetsresolu(rs,fp) str2resolu(rs, \
44 fgets(resolu_buf,RESOLU_BUFLEN,fp))
45
46 /* reading/writing of standard ordering */
47 #define fprtresolu(sl,ns,fp) fprintf(fp,PIXSTDFMT,ns,sl)
48 #define fscnresolu(sl,ns,fp) (fscanf(fp,PIXSTDFMT,ns,sl)==2)
49
50 extern char *fgets(), *resolu2str();
