root/radiance/ray/src/common/resolu.c
Tue Nov 21 18:47:03 2023 UTC (5 months, 3 weeks ago) by greg
Changes since 2.8: +20 -16 lines
style: Updated code to modern prototypes
Wed Jun 21 15:43:16 2023 UTC (10 months, 3 weeks ago) by greg
fix: made handling of resolution strings more consistent
Thu Mar 3 03:55:13 2022 UTC (2 years, 2 months ago) by greg
feat: Added float and double alignment to i/o routines for future mmap() use
Wed Jun 7 17:52:03 2006 UTC (17 years, 11 months ago) by schorsch
CVS Tags: rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3
Tue Feb 1 01:28:16 2005 UTC (19 years, 3 months ago) by greg
Changes since 2.4: +1 -3 lines
Eliminated redundant include files.
Changes since 2.3: +1 -56 lines
Changes since 2.2: +76 -16 lines
Thu Nov 28 10:31:04 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 2.1
minor bug fix to avoid skipping past empty string to oblivion
Tue Nov 12 16:54:21 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.2
Mon Nov 11 14:00:16 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.1: +71 -28 lines
Diff to previous 1.1
Sat Sep 22 10:44:55 1990 UTC (33 years, 8 months ago) by greg
