root/radiance/ray/src/common/readwfobj.c
Tue Feb 7 20:28:16 2023 UTC (2 years, 2 months ago) by greg
CVS Tags: HEAD, rad5R4
perf: added calls to flockfile()/funlockfile() for more efficient reading
Sat Jan 15 02:00:21 2022 UTC (3 years, 3 months ago) by greg
refactor: eliminated stray uses of (char *) to point to memory
Wed Feb 10 17:57:28 2021 UTC (4 years, 2 months ago) by greg
Changes since 2.7: +6 -3 lines
fix: Added measure of caution for very long file names or command lines
Fri Dec 18 00:15:47 2020 UTC (4 years, 4 months ago) by greg
feat(robjutil): improved verbose reporting
Mon Dec 14 20:07:34 2020 UTC (4 years, 4 months ago) by greg
Changes since 2.5: +8 -6 lines
fix: eliminated spurious call to fclose() on pipe
Mon Nov 16 18:40:53 2020 UTC (4 years, 5 months ago) by greg
Changes since 2.4: +7 -4 lines
fix: added check for pipe command return status
Sat May 2 00:12:45 2020 UTC (5 years ago) by greg
Changes since 2.3: +16 -38 lines
Made addFace() into a public routine as well, so tools can add geometry
Fri May 1 18:55:34 2020 UTC (5 years ago) by greg
Changes since 2.2: +7 -65 lines
Made some useful routines public from readwfobj.c
Thu Apr 23 03:19:48 2020 UTC (5 years ago) by greg
Fix for missing popen() in Windows
Mon Mar 30 18:28:35 2020 UTC (5 years, 1 month ago) by greg
Diff to selected 2.10
