1 |
/* Copyright (c) 1992 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* readoct.c - routines to read octree information. |
9 |
10 |
* 7/30/85 |
11 |
12 |
13 |
#include "standard.h" |
14 |
15 |
#include "octree.h" |
16 |
17 |
#include "object.h" |
18 |
19 |
#include "otypes.h" |
20 |
21 |
static double ogetflt(); |
22 |
static long ogetint(); |
23 |
static char *ogetstr(); |
24 |
static int getobj(), octerror(); |
25 |
static OCTREE getfullnode(), gettree(); |
26 |
27 |
static char *infn; /* input file name */ |
28 |
static FILE *infp; /* input file stream */ |
29 |
static int objsize; /* size of stored OBJECT's */ |
30 |
static OBJECT objorig; /* zeroeth object */ |
31 |
static short otypmap[NUMOTYPE+8]; /* object type map */ |
32 |
33 |
34 |
int |
35 |
readoct(fname, load, scene, ofn) /* read in octree from file */ |
36 |
char *fname; |
37 |
int load; |
38 |
CUBE *scene; |
39 |
char *ofn[]; |
40 |
41 |
char sbuf[512]; |
42 |
int nf; |
43 |
OBJECT fnobjects; |
44 |
register int i; |
45 |
long m; |
46 |
47 |
if (fname == NULL) { |
48 |
infn = "standard input"; |
49 |
infp = stdin; |
50 |
} else { |
51 |
infn = fname; |
52 |
if ((infp = fopen(fname, "r")) == NULL) { |
53 |
sprintf(errmsg, "cannot open octree file \"%s\"", |
54 |
fname); |
55 |
error(SYSTEM, errmsg); |
56 |
57 |
58 |
#ifdef MSDOS |
59 |
setmode(fileno(infp), O_BINARY); |
60 |
#endif |
61 |
/* get header */ |
62 |
if (checkheader(infp, OCTFMT, load&IO_INFO ? stdout : NULL) < 0) |
63 |
octerror(USER, "not an octree"); |
64 |
/* check format */ |
65 |
if ((objsize = ogetint(2)-OCTMAGIC) <= 0 || |
66 |
objsize > MAXOBJSIZ || objsize > sizeof(long)) |
67 |
octerror(USER, "incompatible octree format"); |
68 |
/* get boundaries */ |
69 |
if (load & IO_BOUNDS) { |
70 |
for (i = 0; i < 3; i++) |
71 |
scene->cuorg[i] = atof(ogetstr(sbuf)); |
72 |
scene->cusize = atof(ogetstr(sbuf)); |
73 |
} else { |
74 |
for (i = 0; i < 4; i++) |
75 |
ogetstr(sbuf); |
76 |
77 |
objorig = nobjects; /* set object offset */ |
78 |
nf = 0; /* get object files */ |
79 |
while (*ogetstr(sbuf)) { |
80 |
if (load & IO_SCENE) |
81 |
readobj(sbuf); |
82 |
if (load & IO_FILES) |
83 |
ofn[nf] = savqstr(sbuf); |
84 |
nf++; |
85 |
86 |
87 |
ofn[nf] = NULL; |
88 |
/* get number of objects */ |
89 |
fnobjects = m = ogetint(objsize); |
90 |
if (fnobjects != m) |
91 |
octerror(USER, "too many objects"); |
92 |
93 |
if (load & IO_TREE) /* get the octree */ |
94 |
scene->cutree = gettree(); |
95 |
else if (load & IO_SCENE && nf == 0) |
96 |
skiptree(); |
97 |
98 |
if (load & IO_SCENE) /* get the scene */ |
99 |
if (nf == 0) { |
100 |
for (i = 0; *ogetstr(sbuf); i++) |
101 |
if ((otypmap[i] = otype(sbuf)) < 0) { |
102 |
sprintf(errmsg, "unknown type \"%s\"", sbuf); |
103 |
octerror(WARNING, errmsg); |
104 |
105 |
while (getobj() != OVOID) |
106 |
107 |
} else { /* consistency checks */ |
108 |
/* check object count */ |
109 |
if (nobjects != objorig+fnobjects) |
110 |
octerror(USER, "bad object count; octree stale?"); |
111 |
/* check for non-surfaces */ |
112 |
if (nonsurfinset(objorig, fnobjects)) |
113 |
octerror(USER, "modifier in tree; octree stale?"); |
114 |
115 |
fclose(infp); |
116 |
return(nf); |
117 |
118 |
119 |
120 |
static char * |
121 |
ogetstr(s) /* get null-terminated string */ |
122 |
char *s; |
123 |
124 |
extern char *getstr(); |
125 |
126 |
if (getstr(s, infp) == NULL) |
127 |
octerror(USER, "truncated octree"); |
128 |
return(s); |
129 |
130 |
131 |
132 |
static OCTREE |
133 |
getfullnode() /* get a set, return fullnode */ |
134 |
135 |
OBJECT set[MAXSET+1]; |
136 |
register int i; |
137 |
register long m; |
138 |
139 |
if ((set[0] = ogetint(objsize)) > MAXSET) |
140 |
octerror(USER, "bad set in getfullnode"); |
141 |
for (i = 1; i <= set[0]; i++) { |
142 |
m = ogetint(objsize) + objorig; |
143 |
if ((set[i] = m) != m) |
144 |
145 |
146 |
return(fullnode(set)); |
147 |
148 |
149 |
150 |
static long |
151 |
ogetint(siz) /* get a siz-byte integer */ |
152 |
int siz; |
153 |
154 |
extern long getint(); |
155 |
register long r; |
156 |
157 |
r = getint(siz, infp); |
158 |
if (feof(infp)) |
159 |
160 |
return(r); |
161 |
162 |
163 |
164 |
static double |
165 |
ogetflt() /* get a floating point number */ |
166 |
167 |
extern double getflt(); |
168 |
double r; |
169 |
170 |
r = getflt(infp); |
171 |
if (feof(infp)) |
172 |
173 |
return(r); |
174 |
175 |
176 |
177 |
static OCTREE |
178 |
gettree() /* get a pre-ordered octree */ |
179 |
180 |
register OCTREE ot; |
181 |
register int i; |
182 |
183 |
switch (getc(infp)) { |
184 |
case OT_EMPTY: |
185 |
return(EMPTY); |
186 |
case OT_FULL: |
187 |
return(getfullnode()); |
188 |
case OT_TREE: |
189 |
if ((ot = octalloc()) == EMPTY) |
190 |
octerror(SYSTEM, "out of tree space in gettree"); |
191 |
for (i = 0; i < 8; i++) |
192 |
octkid(ot, i) = gettree(); |
193 |
return(ot); |
194 |
case EOF: |
195 |
196 |
default: |
197 |
octerror(USER, "damaged octree"); |
198 |
199 |
200 |
201 |
202 |
static |
203 |
skiptree() /* skip octree on input */ |
204 |
205 |
register int i; |
206 |
207 |
208 |
case OT_EMPTY: |
209 |
return; |
210 |
case OT_FULL: |
211 |
for (i = ogetint(objsize)*objsize; i-- > 0; ) |
212 |
if (getc(infp) == EOF) |
213 |
214 |
return; |
215 |
case OT_TREE: |
216 |
217 |
skiptree(); |
218 |
return; |
219 |
case EOF: |
220 |
221 |
default: |
222 |
223 |
224 |
225 |
226 |
227 |
static |
228 |
getobj() /* get next object */ |
229 |
230 |
char sbuf[MAXSTR]; |
231 |
int obj; |
232 |
register int i; |
233 |
register long m; |
234 |
register OBJREC *objp; |
235 |
236 |
i = ogetint(1); |
237 |
if (i == -1) |
238 |
return(OVOID); /* terminator */ |
239 |
if ((obj = newobject()) == OVOID) |
240 |
error(SYSTEM, "out of object space"); |
241 |
objp = objptr(obj); |
242 |
if ((objp->otype = otypmap[i]) < 0) |
243 |
octerror(USER, "reference to unknown type"); |
244 |
if ((m = ogetint(objsize)) != OVOID) { |
245 |
m += objorig; |
246 |
if ((OBJECT)m != m) |
247 |
248 |
249 |
objp->omod = m; |
250 |
objp->oname = savqstr(ogetstr(sbuf)); |
251 |
if (objp->oargs.nsargs = ogetint(2)) { |
252 |
objp->oargs.sarg = (char **)bmalloc |
253 |
(objp->oargs.nsargs*sizeof(char *)); |
254 |
if (objp->oargs.sarg == NULL) |
255 |
goto memerr; |
256 |
for (i = 0; i < objp->oargs.nsargs; i++) |
257 |
objp->oargs.sarg[i] = savestr(ogetstr(sbuf)); |
258 |
} else |
259 |
objp->oargs.sarg = NULL; |
260 |
#ifdef IARGS |
261 |
if (objp->oargs.niargs = ogetint(2)) { |
262 |
objp->oargs.iarg = (long *)bmalloc |
263 |
(objp->oargs.niargs*sizeof(long)); |
264 |
if (objp->oargs.iarg == NULL) |
265 |
goto memerr; |
266 |
for (i = 0; i < objp->oargs.niargs; i++) |
267 |
objp->oargs.iarg[i] = ogetint(4); |
268 |
} else |
269 |
objp->oargs.iarg = NULL; |
270 |
#endif |
271 |
if (objp->oargs.nfargs = ogetint(2)) { |
272 |
objp->oargs.farg = (FLOAT *)bmalloc |
273 |
(objp->oargs.nfargs*sizeof(FLOAT)); |
274 |
if (objp->oargs.farg == NULL) |
275 |
goto memerr; |
276 |
for (i = 0; i < objp->oargs.nfargs; i++) |
277 |
objp->oargs.farg[i] = ogetflt(); |
278 |
} else |
279 |
objp->oargs.farg = NULL; |
280 |
/* initialize */ |
281 |
objp->os = NULL; |
282 |
/* insert */ |
283 |
insertobject(obj); |
284 |
return(obj); |
285 |
memerr: |
286 |
error(SYSTEM, "out of memory in getobj"); |
287 |
288 |
289 |
290 |
static |
291 |
octerror(etyp, msg) /* octree error */ |
292 |
int etyp; |
293 |
char *msg; |
294 |
295 |
char msgbuf[128]; |
296 |
297 |
sprintf(msgbuf, "(%s): %s", infn, msg); |
298 |
error(etyp, msgbuf); |
299 |
