| 1 |
/* Copyright (c) 1992 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* readoct.c - routines to read octree information.
| 9 |
| 10 |
* 7/30/85
| 11 |
| 12 |
| 13 |
#include "standard.h"
| 14 |
| 15 |
#include "octree.h"
| 16 |
| 17 |
#include "object.h"
| 18 |
| 19 |
#include "otypes.h"
| 20 |
| 21 |
static double ogetflt();
| 22 |
static long ogetint();
| 23 |
static char *ogetstr();
| 24 |
static int getobj(), octerror();
| 25 |
static OCTREE getfullnode(), gettree();
| 26 |
| 27 |
static char *infn; /* input file name */
| 28 |
static FILE *infp; /* input file stream */
| 29 |
static int objsize; /* size of stored OBJECT's */
| 30 |
static OBJECT objorig; /* zeroeth object */
| 31 |
static short otypmap[NUMOTYPE+8]; /* object type map */
| 32 |
| 33 |
| 34 |
int
| 35 |
readoct(fname, load, scene, ofn) /* read in octree from file */
| 36 |
char *fname;
| 37 |
int load;
| 38 |
CUBE *scene;
| 39 |
char *ofn[];
| 40 |
| 41 |
char sbuf[512];
| 42 |
int nf;
| 43 |
OBJECT fnobjects;
| 44 |
register int i;
| 45 |
long m;
| 46 |
| 47 |
if (fname == NULL) {
| 48 |
infn = "standard input";
| 49 |
infp = stdin;
| 50 |
} else {
| 51 |
infn = fname;
| 52 |
if ((infp = fopen(fname, "r")) == NULL) {
| 53 |
sprintf(errmsg, "cannot open octree file \"%s\"",
| 54 |
fname);
| 55 |
error(SYSTEM, errmsg);
| 56 |
| 57 |
| 58 |
#ifdef MSDOS
| 59 |
setmode(fileno(infp), O_BINARY);
| 60 |
#endif
| 61 |
/* get header */
| 62 |
if (checkheader(infp, OCTFMT, load&IO_INFO ? stdout : NULL) < 0)
| 63 |
octerror(USER, "not an octree");
| 64 |
/* check format */
| 65 |
if ((objsize = ogetint(2)-OCTMAGIC) <= 0 ||
| 66 |
objsize > MAXOBJSIZ || objsize > sizeof(long))
| 67 |
octerror(USER, "incompatible octree format");
| 68 |
/* get boundaries */
| 69 |
if (load & IO_BOUNDS) {
| 70 |
for (i = 0; i < 3; i++)
| 71 |
scene->cuorg[i] = atof(ogetstr(sbuf));
| 72 |
scene->cusize = atof(ogetstr(sbuf));
| 73 |
} else {
| 74 |
for (i = 0; i < 4; i++)
| 75 |
ogetstr(sbuf);
| 76 |
| 77 |
objorig = nobjects; /* set object offset */
| 78 |
nf = 0; /* get object files */
| 79 |
while (*ogetstr(sbuf)) {
| 80 |
if (load & IO_SCENE)
| 81 |
readobj(sbuf);
| 82 |
if (load & IO_FILES)
| 83 |
ofn[nf] = savqstr(sbuf);
| 84 |
nf++;
| 85 |
| 86 |
| 87 |
ofn[nf] = NULL;
| 88 |
/* get number of objects */
| 89 |
fnobjects = m = ogetint(objsize);
| 90 |
if (fnobjects != m)
| 91 |
octerror(USER, "too many objects");
| 92 |
| 93 |
if (load & IO_TREE) /* get the octree */
| 94 |
scene->cutree = gettree();
| 95 |
else if (load & IO_SCENE && nf == 0)
| 96 |
skiptree();
| 97 |
| 98 |
if (load & IO_SCENE) /* get the scene */
| 99 |
if (nf == 0) {
| 100 |
for (i = 0; *ogetstr(sbuf); i++)
| 101 |
if ((otypmap[i] = otype(sbuf)) < 0) {
| 102 |
sprintf(errmsg, "unknown type \"%s\"", sbuf);
| 103 |
octerror(WARNING, errmsg);
| 104 |
| 105 |
while (getobj() != OVOID)
| 106 |
| 107 |
} else { /* consistency checks */
| 108 |
/* check object count */
| 109 |
if (nobjects != objorig+fnobjects)
| 110 |
octerror(USER, "bad object count; octree stale?");
| 111 |
/* check for non-surfaces */
| 112 |
if (nonsurfinset(objorig, fnobjects))
| 113 |
octerror(USER, "modifier in tree; octree stale?");
| 114 |
| 115 |
fclose(infp);
| 116 |
return(nf);
| 117 |
| 118 |
| 119 |
| 120 |
static char *
| 121 |
ogetstr(s) /* get null-terminated string */
| 122 |
char *s;
| 123 |
| 124 |
extern char *getstr();
| 125 |
| 126 |
if (getstr(s, infp) == NULL)
| 127 |
octerror(USER, "truncated octree");
| 128 |
return(s);
| 129 |
| 130 |
| 131 |
| 132 |
static OCTREE
| 133 |
getfullnode() /* get a set, return fullnode */
| 134 |
| 135 |
OBJECT set[MAXSET+1];
| 136 |
register int i;
| 137 |
register long m;
| 138 |
| 139 |
if ((set[0] = ogetint(objsize)) > MAXSET)
| 140 |
octerror(USER, "bad set in getfullnode");
| 141 |
for (i = 1; i <= set[0]; i++) {
| 142 |
m = ogetint(objsize) + objorig;
| 143 |
if ((set[i] = m) != m)
| 144 |
| 145 |
| 146 |
return(fullnode(set));
| 147 |
| 148 |
| 149 |
| 150 |
static long
| 151 |
ogetint(siz) /* get a siz-byte integer */
| 152 |
int siz;
| 153 |
| 154 |
extern long getint();
| 155 |
register long r;
| 156 |
| 157 |
r = getint(siz, infp);
| 158 |
if (feof(infp))
| 159 |
| 160 |
return(r);
| 161 |
| 162 |
| 163 |
| 164 |
static double
| 165 |
ogetflt() /* get a floating point number */
| 166 |
| 167 |
extern double getflt();
| 168 |
double r;
| 169 |
| 170 |
r = getflt(infp);
| 171 |
if (feof(infp))
| 172 |
| 173 |
return(r);
| 174 |
| 175 |
| 176 |
| 177 |
static OCTREE
| 178 |
gettree() /* get a pre-ordered octree */
| 179 |
| 180 |
register OCTREE ot;
| 181 |
register int i;
| 182 |
| 183 |
switch (getc(infp)) {
| 184 |
case OT_EMPTY:
| 185 |
return(EMPTY);
| 186 |
case OT_FULL:
| 187 |
return(getfullnode());
| 188 |
case OT_TREE:
| 189 |
if ((ot = octalloc()) == EMPTY)
| 190 |
octerror(SYSTEM, "out of tree space in gettree");
| 191 |
for (i = 0; i < 8; i++)
| 192 |
octkid(ot, i) = gettree();
| 193 |
return(ot);
| 194 |
case EOF:
| 195 |
| 196 |
default:
| 197 |
octerror(USER, "damaged octree");
| 198 |
| 199 |
| 200 |
| 201 |
| 202 |
static
| 203 |
skiptree() /* skip octree on input */
| 204 |
| 205 |
register int i;
| 206 |
| 207 |
| 208 |
case OT_EMPTY:
| 209 |
return;
| 210 |
case OT_FULL:
| 211 |
for (i = ogetint(objsize)*objsize; i-- > 0; )
| 212 |
if (getc(infp) == EOF)
| 213 |
| 214 |
return;
| 215 |
case OT_TREE:
| 216 |
| 217 |
skiptree();
| 218 |
return;
| 219 |
case EOF:
| 220 |
| 221 |
default:
| 222 |
| 223 |
| 224 |
| 225 |
| 226 |
| 227 |
static
| 228 |
getobj() /* get next object */
| 229 |
| 230 |
char sbuf[MAXSTR];
| 231 |
int obj;
| 232 |
register int i;
| 233 |
register long m;
| 234 |
register OBJREC *objp;
| 235 |
| 236 |
i = ogetint(1);
| 237 |
if (i == -1)
| 238 |
return(OVOID); /* terminator */
| 239 |
if ((obj = newobject()) == OVOID)
| 240 |
error(SYSTEM, "out of object space");
| 241 |
objp = objptr(obj);
| 242 |
if ((objp->otype = otypmap[i]) < 0)
| 243 |
octerror(USER, "reference to unknown type");
| 244 |
if ((m = ogetint(objsize)) != OVOID) {
| 245 |
m += objorig;
| 246 |
if ((OBJECT)m != m)
| 247 |
| 248 |
| 249 |
objp->omod = m;
| 250 |
objp->oname = savqstr(ogetstr(sbuf));
| 251 |
if (objp->oargs.nsargs = ogetint(2)) {
| 252 |
objp->oargs.sarg = (char **)bmalloc
| 253 |
(objp->oargs.nsargs*sizeof(char *));
| 254 |
if (objp->oargs.sarg == NULL)
| 255 |
goto memerr;
| 256 |
for (i = 0; i < objp->oargs.nsargs; i++)
| 257 |
objp->oargs.sarg[i] = savestr(ogetstr(sbuf));
| 258 |
} else
| 259 |
objp->oargs.sarg = NULL;
| 260 |
#ifdef IARGS
| 261 |
if (objp->oargs.niargs = ogetint(2)) {
| 262 |
objp->oargs.iarg = (long *)bmalloc
| 263 |
(objp->oargs.niargs*sizeof(long));
| 264 |
if (objp->oargs.iarg == NULL)
| 265 |
goto memerr;
| 266 |
for (i = 0; i < objp->oargs.niargs; i++)
| 267 |
objp->oargs.iarg[i] = ogetint(4);
| 268 |
} else
| 269 |
objp->oargs.iarg = NULL;
| 270 |
#endif
| 271 |
if (objp->oargs.nfargs = ogetint(2)) {
| 272 |
objp->oargs.farg = (FLOAT *)bmalloc
| 273 |
(objp->oargs.nfargs*sizeof(FLOAT));
| 274 |
if (objp->oargs.farg == NULL)
| 275 |
goto memerr;
| 276 |
for (i = 0; i < objp->oargs.nfargs; i++)
| 277 |
objp->oargs.farg[i] = ogetflt();
| 278 |
} else
| 279 |
objp->oargs.farg = NULL;
| 280 |
/* initialize */
| 281 |
objp->os = NULL;
| 282 |
/* insert */
| 283 |
insertobject(obj);
| 284 |
return(obj);
| 285 |
memerr:
| 286 |
error(SYSTEM, "out of memory in getobj");
| 287 |
| 288 |
| 289 |
| 290 |
static
| 291 |
octerror(etyp, msg) /* octree error */
| 292 |
int etyp;
| 293 |
char *msg;
| 294 |
| 295 |
char msgbuf[128];
| 296 |
| 297 |
sprintf(msgbuf, "(%s): %s", infn, msg);
| 298 |
error(etyp, msgbuf);
| 299 |
