| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: readoct.c,v 2.37 2025/06/07 05:09:45 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* readoct.c - routines to read octree information.
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include <stdio.h>
| 11 |
#include <time.h>
| 12 |
| 13 |
#include "platform.h"
| 14 |
#include "standard.h"
| 15 |
#include "octree.h"
| 16 |
#include "object.h"
| 17 |
#include "otypes.h"
| 18 |
#include "resolu.h"
| 19 |
| 20 |
static double ogetflt(void);
| 21 |
static long ogetint(int);
| 22 |
static char *ogetstr(char *);
| 23 |
static int nonsurfintree(OCTREE ot);
| 24 |
static void octerror(int etyp, char *msg);
| 25 |
static void skiptree(void);
| 26 |
static OCTREE getfullnode(void), gettree(void);
| 27 |
| 28 |
static char *infn; /* input file specification */
| 29 |
static FILE *infp; /* input file stream */
| 30 |
static int objsize; /* size of stored OBJECT's */
| 31 |
static OBJECT objorig; /* zeroeth object */
| 32 |
static OBJECT fnobjects; /* number of objects in this file */
| 33 |
| 34 |
| 35 |
int
| 36 |
readoct( /* read in octree file or stream */
| 37 |
char *inpspec,
| 38 |
int load,
| 39 |
CUBE *scene,
| 40 |
char *ofn[]
| 41 |
| 42 |
| 43 |
time_t oct_t = 0;
| 44 |
time_t last_it = 0;
| 45 |
char sbuf[512];
| 46 |
int nf;
| 47 |
int i;
| 48 |
long m;
| 49 |
| 50 |
if (inpspec == NULL) {
| 51 |
infn = "standard input";
| 52 |
infp = stdin;
| 53 |
} else if (inpspec[0] == '!') {
| 54 |
infn = inpspec;
| 55 |
if ((infp = popen(inpspec+1, "r")) == NULL) {
| 56 |
sprintf(errmsg, "cannot execute \"%s\"", inpspec);
| 57 |
error(SYSTEM, errmsg);
| 58 |
| 59 |
} else {
| 60 |
infn = inpspec;
| 61 |
if ((infp = fopen(inpspec, "r")) == NULL) {
| 62 |
sprintf(errmsg, "cannot open octree file \"%s\"",
| 63 |
inpspec);
| 64 |
| 65 |
| 66 |
oct_t = fddate(fileno(infp));
| 67 |
| 68 |
#ifdef getc_unlocked /* avoid stupid semaphores */
| 69 |
flockfile(infp);
| 70 |
#endif
| 71 |
SET_FILE_BINARY(infp);
| 72 |
/* get header */
| 73 |
if (checkheader(infp, OCTFMT, load&IO_INFO ? stdout : (FILE *)NULL) < 0)
| 74 |
octerror(USER, "not an octree");
| 75 |
/* check format */
| 76 |
if ((objsize = ogetint(2)-OCTMAGIC) <= 0 ||
| 77 |
objsize > MAXOBJSIZ || objsize > sizeof(long))
| 78 |
octerror(USER, "incompatible octree format");
| 79 |
/* get boundaries */
| 80 |
if (load & IO_BOUNDS) {
| 81 |
for (i = 0; i < 3; i++)
| 82 |
scene->cuorg[i] = atof(ogetstr(sbuf));
| 83 |
scene->cusize = atof(ogetstr(sbuf));
| 84 |
} else {
| 85 |
for (i = 0; i < 4; i++)
| 86 |
ogetstr(sbuf);
| 87 |
| 88 |
objorig = nobjects; /* set object offset */
| 89 |
nf = 0; /* get object files */
| 90 |
while (*ogetstr(sbuf)) {
| 91 |
if (load & IO_SCENE)
| 92 |
readobj(sbuf);
| 93 |
if (load & IO_FILES)
| 94 |
ofn[nf] = savqstr(sbuf);
| 95 |
if (oct_t > last_it) {
| 96 |
time_t t = fdate(sbuf);
| 97 |
if (t > last_it)
| 98 |
last_it = t;
| 99 |
| 100 |
nf++;
| 101 |
| 102 |
| 103 |
ofn[nf] = NULL;
| 104 |
/* get number of objects */
| 105 |
fnobjects = m = ogetint(objsize);
| 106 |
if (fnobjects != m)
| 107 |
octerror(USER, "too many objects");
| 108 |
| 109 |
if (load & IO_TREE) /* get the octree */
| 110 |
scene->cutree = gettree();
| 111 |
else if (load & IO_SCENE && nf == 0)
| 112 |
skiptree();
| 113 |
| 114 |
if (load & IO_SCENE) { /* get the scene */
| 115 |
if (nf == 0) {
| 116 |
/* load binary scene data */
| 117 |
readscene(infp, objsize);
| 118 |
| 119 |
} else { /* consistency checks */
| 120 |
/* check object count */
| 121 |
if (nobjects != objorig+fnobjects)
| 122 |
octerror(USER, "bad object count; octree stale?");
| 123 |
/* check for non-surfaces */
| 124 |
if (oct_t <= last_it && nonsurfintree(scene->cutree))
| 125 |
octerror(USER, "modifier in tree; octree stale?");
| 126 |
| 127 |
| 128 |
/* close the input */
| 129 |
if (infn[0] == '!') {
| 130 |
if (pclose(infp) != 0) {
| 131 |
sprintf(errmsg, "bad status from \"%s\"", inpspec);
| 132 |
error(WARNING, errmsg);
| 133 |
| 134 |
} else if (infp != stdin)
| 135 |
fclose(infp);
| 136 |
| 137 |
else
| 138 |
funlockfile(infp);
| 139 |
#endif
| 140 |
return(nf);
| 141 |
| 142 |
| 143 |
| 144 |
static char *
| 145 |
ogetstr(char *s) /* get null-terminated string */
| 146 |
| 147 |
if (getstr(s, infp) == NULL)
| 148 |
octerror(USER, "truncated octree");
| 149 |
return(s);
| 150 |
| 151 |
| 152 |
| 153 |
static OCTREE
| 154 |
getfullnode() /* get a set, return fullnode */
| 155 |
| 156 |
OBJECT set[MAXSET+1];
| 157 |
int i;
| 158 |
long m;
| 159 |
| 160 |
if ((set[0] = ogetint(objsize)) > MAXSET)
| 161 |
octerror(USER, "bad set in getfullnode");
| 162 |
for (i = 1; i <= set[0]; i++) {
| 163 |
m = ogetint(objsize) + objorig;
| 164 |
if ((set[i] = m) != m)
| 165 |
| 166 |
| 167 |
return(fullnode(set));
| 168 |
| 169 |
| 170 |
| 171 |
static long
| 172 |
ogetint(int siz) /* get a siz-byte integer */
| 173 |
| 174 |
long r;
| 175 |
| 176 |
r = getint(siz, infp);
| 177 |
if (feof(infp))
| 178 |
| 179 |
return(r);
| 180 |
| 181 |
| 182 |
| 183 |
static double
| 184 |
ogetflt() /* get a floating point number */
| 185 |
| 186 |
double r;
| 187 |
| 188 |
r = getflt(infp);
| 189 |
if (feof(infp))
| 190 |
| 191 |
return(r);
| 192 |
| 193 |
| 194 |
| 195 |
static OCTREE
| 196 |
gettree() /* get a pre-ordered octree */
| 197 |
| 198 |
OCTREE ot;
| 199 |
int i;
| 200 |
| 201 |
switch (getc(infp)) {
| 202 |
case OT_EMPTY:
| 203 |
return(EMPTY);
| 204 |
case OT_FULL:
| 205 |
return(getfullnode());
| 206 |
case OT_TREE:
| 207 |
if ((ot = octalloc()) == EMPTY)
| 208 |
octerror(SYSTEM, "out of tree space in gettree");
| 209 |
for (i = 0; i < 8; i++)
| 210 |
octkid(ot, i) = gettree();
| 211 |
return(ot);
| 212 |
case EOF:
| 213 |
| 214 |
default:
| 215 |
octerror(USER, "damaged octree");
| 216 |
| 217 |
return EMPTY; /* pro forma return */
| 218 |
| 219 |
| 220 |
| 221 |
static int
| 222 |
nonsurfintree(OCTREE ot) /* check tree for modifiers */
| 223 |
| 224 |
| 225 |
int i;
| 226 |
| 227 |
if (isempty(ot))
| 228 |
return(0);
| 229 |
if (istree(ot)) {
| 230 |
| 231 |
if (nonsurfintree(octkid(ot, i)))
| 232 |
return(1);
| 233 |
return(0);
| 234 |
| 235 |
objset(set, ot);
| 236 |
for (i = set[0]; i > 0; i-- )
| 237 |
if (ismodifier(objptr(set[i])->otype))
| 238 |
return(1);
| 239 |
return(0);
| 240 |
| 241 |
| 242 |
| 243 |
static void
| 244 |
skiptree(void) /* skip octree on input */
| 245 |
| 246 |
int i;
| 247 |
| 248 |
| 249 |
case OT_EMPTY:
| 250 |
return;
| 251 |
case OT_FULL:
| 252 |
for (i = ogetint(objsize)*objsize; i-- > 0; )
| 253 |
if (getc(infp) == EOF)
| 254 |
| 255 |
return;
| 256 |
case OT_TREE:
| 257 |
| 258 |
skiptree();
| 259 |
return;
| 260 |
case EOF:
| 261 |
| 262 |
default:
| 263 |
| 264 |
| 265 |
| 266 |
| 267 |
| 268 |
static void
| 269 |
octerror(int etyp, char *msg) /* octree error */
| 270 |
| 271 |
char msgbuf[128];
| 272 |
| 273 |
sprintf(msgbuf, "(%s): %s", infn, msg);
| 274 |
error(etyp, msgbuf);
| 275 |
