1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: readoct.c,v 2.19 2003/07/16 01:32:53 greg Exp $"; |
3 |
#endif |
4 |
5 |
* readoct.c - routines to read octree information. |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include <stdio.h> |
11 |
#include <time.h> |
12 |
13 |
#include "standard.h" |
14 |
#include "platform.h" |
15 |
#include "octree.h" |
16 |
#include "object.h" |
17 |
#include "otypes.h" |
18 |
#include "resolu.h" |
19 |
20 |
static double ogetflt(void); |
21 |
static long ogetint(int); |
22 |
static char *ogetstr(char *); |
23 |
static int nonsurfinset(OBJECT *); |
24 |
static void octerror(int etyp, char *msg); |
25 |
static void skiptree(void); |
26 |
static OCTREE getfullnode(void), gettree(void); |
27 |
28 |
static char *infn; /* input file specification */ |
29 |
static FILE *infp; /* input file stream */ |
30 |
static int objsize; /* size of stored OBJECT's */ |
31 |
static OBJECT objorig; /* zeroeth object */ |
32 |
static OBJECT fnobjects; /* number of objects in this file */ |
33 |
34 |
35 |
int |
36 |
readoct(inpspec, load, scene, ofn) /* read in octree file or stream */ |
37 |
char *inpspec; |
38 |
int load; |
39 |
CUBE *scene; |
40 |
char *ofn[]; |
41 |
42 |
char sbuf[512]; |
43 |
int nf; |
44 |
int i; |
45 |
long m; |
46 |
47 |
if (inpspec == NULL) { |
48 |
infn = "standard input"; |
49 |
infp = stdin; |
50 |
} else if (inpspec[0] == '!') { |
51 |
infn = inpspec; |
52 |
if ((infp = popen(inpspec+1, "r")) == NULL) { |
53 |
sprintf(errmsg, "cannot execute \"%s\"", inpspec); |
54 |
error(SYSTEM, errmsg); |
55 |
56 |
} else { |
57 |
infn = inpspec; |
58 |
if ((infp = fopen(inpspec, "r")) == NULL) { |
59 |
sprintf(errmsg, "cannot open octree file \"%s\"", |
60 |
inpspec); |
61 |
62 |
63 |
64 |
SET_FILE_BINARY(infp); |
65 |
/* get header */ |
66 |
if (checkheader(infp, OCTFMT, load&IO_INFO ? stdout : (FILE *)NULL) < 0) |
67 |
octerror(USER, "not an octree"); |
68 |
/* check format */ |
69 |
if ((objsize = ogetint(2)-OCTMAGIC) <= 0 || |
70 |
objsize > MAXOBJSIZ || objsize > sizeof(long)) |
71 |
octerror(USER, "incompatible octree format"); |
72 |
/* get boundaries */ |
73 |
if (load & IO_BOUNDS) { |
74 |
for (i = 0; i < 3; i++) |
75 |
scene->cuorg[i] = atof(ogetstr(sbuf)); |
76 |
scene->cusize = atof(ogetstr(sbuf)); |
77 |
} else { |
78 |
for (i = 0; i < 4; i++) |
79 |
ogetstr(sbuf); |
80 |
81 |
objorig = nobjects; /* set object offset */ |
82 |
nf = 0; /* get object files */ |
83 |
while (*ogetstr(sbuf)) { |
84 |
if (load & IO_SCENE) |
85 |
readobj(sbuf); |
86 |
if (load & IO_FILES) |
87 |
ofn[nf] = savqstr(sbuf); |
88 |
nf++; |
89 |
90 |
91 |
ofn[nf] = NULL; |
92 |
/* get number of objects */ |
93 |
fnobjects = m = ogetint(objsize); |
94 |
if (fnobjects != m) |
95 |
octerror(USER, "too many objects"); |
96 |
97 |
if (load & IO_TREE) /* get the octree */ |
98 |
scene->cutree = gettree(); |
99 |
else if (load & IO_SCENE && nf == 0) |
100 |
skiptree(); |
101 |
102 |
if (load & IO_SCENE) /* get the scene */ |
103 |
if (nf == 0) { |
104 |
/* load binary scene data */ |
105 |
readscene(infp, objsize); |
106 |
107 |
} else { /* consistency checks */ |
108 |
/* check object count */ |
109 |
if (nobjects != objorig+fnobjects) |
110 |
octerror(USER, "bad object count; octree stale?"); |
111 |
/* check for non-surfaces */ |
112 |
if (dosets(nonsurfinset)) |
113 |
octerror(USER, "modifier in tree; octree stale?"); |
114 |
115 |
/* close the input */ |
116 |
if (infn[0] == '!') |
117 |
pclose(infp); |
118 |
else |
119 |
fclose(infp); |
120 |
return(nf); |
121 |
122 |
123 |
124 |
static char * |
125 |
ogetstr(s) /* get null-terminated string */ |
126 |
char *s; |
127 |
128 |
extern char *getstr(); |
129 |
130 |
if (getstr(s, infp) == NULL) |
131 |
octerror(USER, "truncated octree"); |
132 |
return(s); |
133 |
134 |
135 |
136 |
static OCTREE |
137 |
getfullnode() /* get a set, return fullnode */ |
138 |
139 |
OBJECT set[MAXSET+1]; |
140 |
register int i; |
141 |
register long m; |
142 |
143 |
if ((set[0] = ogetint(objsize)) > MAXSET) |
144 |
octerror(USER, "bad set in getfullnode"); |
145 |
for (i = 1; i <= set[0]; i++) { |
146 |
m = ogetint(objsize) + objorig; |
147 |
if ((set[i] = m) != m) |
148 |
149 |
150 |
return(fullnode(set)); |
151 |
152 |
153 |
154 |
static long |
155 |
ogetint(siz) /* get a siz-byte integer */ |
156 |
int siz; |
157 |
158 |
extern long getint(); |
159 |
register long r; |
160 |
161 |
r = getint(siz, infp); |
162 |
if (feof(infp)) |
163 |
164 |
return(r); |
165 |
166 |
167 |
168 |
static double |
169 |
ogetflt() /* get a floating point number */ |
170 |
171 |
extern double getflt(); |
172 |
double r; |
173 |
174 |
r = getflt(infp); |
175 |
if (feof(infp)) |
176 |
177 |
return(r); |
178 |
179 |
180 |
181 |
static OCTREE |
182 |
gettree() /* get a pre-ordered octree */ |
183 |
184 |
register OCTREE ot; |
185 |
register int i; |
186 |
187 |
switch (getc(infp)) { |
188 |
case OT_EMPTY: |
189 |
return(EMPTY); |
190 |
case OT_FULL: |
191 |
return(getfullnode()); |
192 |
case OT_TREE: |
193 |
if ((ot = octalloc()) == EMPTY) |
194 |
octerror(SYSTEM, "out of tree space in gettree"); |
195 |
for (i = 0; i < 8; i++) |
196 |
octkid(ot, i) = gettree(); |
197 |
return(ot); |
198 |
case EOF: |
199 |
200 |
default: |
201 |
octerror(USER, "damaged octree"); |
202 |
203 |
return NULL; /* pro forma return */ |
204 |
205 |
206 |
207 |
static int |
208 |
nonsurfinset(os) /* check set for modifier */ |
209 |
register OBJECT *os; |
210 |
211 |
register OBJECT s; |
212 |
register int i; |
213 |
214 |
for (i = *os; i-- > 0; ) |
215 |
if ((s = *++os) >= objorig && s < objorig+fnobjects && |
216 |
ismodifier(objptr(s)->otype)) |
217 |
return(1); |
218 |
return(0); |
219 |
220 |
221 |
222 |
static void |
223 |
skiptree(void) /* skip octree on input */ |
224 |
225 |
register int i; |
226 |
227 |
228 |
case OT_EMPTY: |
229 |
return; |
230 |
case OT_FULL: |
231 |
for (i = ogetint(objsize)*objsize; i-- > 0; ) |
232 |
if (getc(infp) == EOF) |
233 |
234 |
return; |
235 |
case OT_TREE: |
236 |
237 |
skiptree(); |
238 |
return; |
239 |
case EOF: |
240 |
241 |
default: |
242 |
243 |
244 |
245 |
246 |
247 |
static void |
248 |
octerror(etyp, msg) /* octree error */ |
249 |
int etyp; |
250 |
char *msg; |
251 |
252 |
char msgbuf[128]; |
253 |
254 |
sprintf(msgbuf, "(%s): %s", infn, msg); |
255 |
error(etyp, msgbuf); |
256 |
