1 |
/* Copyright (c) 1991 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* readoct.c - routines to read octree information. |
9 |
10 |
* 7/30/85 |
11 |
12 |
13 |
#include "standard.h" |
14 |
15 |
#include "octree.h" |
16 |
17 |
#include "object.h" |
18 |
19 |
#include "otypes.h" |
20 |
21 |
extern double atof(); |
22 |
static double getflt(); |
23 |
static long getint(); |
24 |
static char *getstr(); |
25 |
static int getobj(), octerror(); |
26 |
static OCTREE getfullnode(), gettree(); |
27 |
28 |
static char *infn; /* input file name */ |
29 |
static FILE *infp; /* input file stream */ |
30 |
static int objsize; /* size of stored OBJECT's */ |
31 |
static OBJECT objorig; /* zeroeth object */ |
32 |
static short otypmap[NUMOTYPE+8]; /* object type map */ |
33 |
34 |
35 |
int |
36 |
readoct(fname, load, scene, ofn) /* read in octree from file */ |
37 |
char *fname; |
38 |
int load; |
39 |
CUBE *scene; |
40 |
char *ofn[]; |
41 |
42 |
extern int fputs(); |
43 |
char sbuf[512]; |
44 |
int nf; |
45 |
OBJECT fnobjects; |
46 |
register int i; |
47 |
long m; |
48 |
49 |
if (fname == NULL) { |
50 |
infn = "standard input"; |
51 |
infp = stdin; |
52 |
} else { |
53 |
infn = fname; |
54 |
if ((infp = fopen(fname, "r")) == NULL) { |
55 |
sprintf(errmsg, "cannot open octree file \"%s\"", |
56 |
fname); |
57 |
error(SYSTEM, errmsg); |
58 |
59 |
60 |
/* get header */ |
61 |
if (checkheader(infp, OCTFMT, load&IO_INFO ? stdout : NULL) < 0) |
62 |
octerror(USER, "not an octree"); |
63 |
/* check format */ |
64 |
if ((objsize = getint(2)-OCTMAGIC) <= 0 || |
65 |
objsize > MAXOBJSIZ || objsize > sizeof(long)) |
66 |
octerror(USER, "incompatible octree format"); |
67 |
/* get boundaries */ |
68 |
if (load & IO_BOUNDS) { |
69 |
for (i = 0; i < 3; i++) |
70 |
scene->cuorg[i] = atof(getstr(sbuf)); |
71 |
scene->cusize = atof(getstr(sbuf)); |
72 |
} else { |
73 |
for (i = 0; i < 4; i++) |
74 |
getstr(sbuf); |
75 |
76 |
objorig = nobjects; /* set object offset */ |
77 |
nf = 0; /* get object files */ |
78 |
while (*getstr(sbuf)) { |
79 |
if (load & IO_SCENE) |
80 |
readobj(sbuf); |
81 |
if (load & IO_FILES) |
82 |
ofn[nf] = savqstr(sbuf); |
83 |
nf++; |
84 |
85 |
86 |
ofn[nf] = NULL; |
87 |
/* get number of objects */ |
88 |
fnobjects = m = getint(objsize); |
89 |
if (fnobjects != m) |
90 |
octerror(USER, "too many objects"); |
91 |
92 |
if (load & IO_TREE) { |
93 |
/* get the octree */ |
94 |
scene->cutree = gettree(); |
95 |
/* get the scene */ |
96 |
if (nf == 0 && load & IO_SCENE) { |
97 |
for (i = 0; *getstr(sbuf); i++) |
98 |
if ((otypmap[i] = otype(sbuf)) < 0) { |
99 |
sprintf(errmsg, "unknown type \"%s\"", |
100 |
sbuf); |
101 |
octerror(WARNING, errmsg); |
102 |
103 |
while (getobj() != OVOID) |
104 |
105 |
} else if (load & IO_SCENE) { /* consistency checks */ |
106 |
/* check object count */ |
107 |
if (nobjects != objorig+fnobjects) |
108 |
octerror(USER, "bad object count; octree stale?"); |
109 |
/* check for non-surfaces */ |
110 |
if (nonsurfinset(objorig, fnobjects)) |
111 |
octerror(USER, "non-surface in set; octree stale?"); |
112 |
113 |
114 |
fclose(infp); |
115 |
return(nf); |
116 |
117 |
118 |
119 |
static char * |
120 |
getstr(s) /* get null-terminated string */ |
121 |
char *s; |
122 |
123 |
register char *cp; |
124 |
register int c; |
125 |
126 |
cp = s; |
127 |
while ((c = getc(infp)) != EOF) |
128 |
if ((*cp++ = c) == '\0') |
129 |
return(s); |
130 |
131 |
octerror(USER, "truncated octree"); |
132 |
133 |
134 |
135 |
static OCTREE |
136 |
getfullnode() /* get a set, return fullnode */ |
137 |
138 |
OBJECT set[MAXSET+1]; |
139 |
register int i; |
140 |
register long m; |
141 |
142 |
if ((set[0] = getint(objsize)) > MAXSET) |
143 |
octerror(USER, "bad set in getfullnode"); |
144 |
for (i = 1; i <= set[0]; i++) { |
145 |
m = getint(objsize) + objorig; |
146 |
if ((set[i] = m) != m) |
147 |
148 |
149 |
return(fullnode(set)); |
150 |
151 |
152 |
153 |
static long |
154 |
getint(siz) /* get a siz-byte integer */ |
155 |
register int siz; |
156 |
157 |
register int c; |
158 |
register long r; |
159 |
160 |
if ((c = getc(infp)) == EOF) |
161 |
goto end_file; |
162 |
r = 0x80&c ? -1<<8|c : c; /* sign extend */ |
163 |
while (--siz > 0) { |
164 |
165 |
goto end_file; |
166 |
r <<= 8; |
167 |
r |= c; |
168 |
169 |
return(r); |
170 |
end_file: |
171 |
172 |
173 |
174 |
175 |
static double |
176 |
getflt() /* get a floating point number */ |
177 |
178 |
extern double ldexp(); |
179 |
double d; |
180 |
181 |
d = (double)getint(4)/0x7fffffff; |
182 |
return(ldexp(d, (int)getint(1))); |
183 |
184 |
185 |
186 |
static OCTREE |
187 |
gettree() /* get a pre-ordered octree */ |
188 |
189 |
register OCTREE ot; |
190 |
register int i; |
191 |
192 |
switch (getc(infp)) { |
193 |
case OT_EMPTY: |
194 |
return(EMPTY); |
195 |
case OT_FULL: |
196 |
return(getfullnode()); |
197 |
case OT_TREE: |
198 |
if ((ot = octalloc()) == EMPTY) |
199 |
octerror(SYSTEM, "out of tree space in gettree"); |
200 |
for (i = 0; i < 8; i++) |
201 |
octkid(ot, i) = gettree(); |
202 |
return(ot); |
203 |
case EOF: |
204 |
205 |
default: |
206 |
octerror(USER, "damaged octree"); |
207 |
208 |
209 |
210 |
211 |
static |
212 |
getobj() /* get next object */ |
213 |
214 |
char sbuf[MAXSTR]; |
215 |
int obj; |
216 |
register int i; |
217 |
register long m; |
218 |
register OBJREC *objp; |
219 |
220 |
i = getint(1); |
221 |
if (i == -1) |
222 |
return(OVOID); /* terminator */ |
223 |
if ((obj = newobject()) == OVOID) |
224 |
error(SYSTEM, "out of object space"); |
225 |
objp = objptr(obj); |
226 |
if ((objp->otype = otypmap[i]) < 0) |
227 |
octerror(USER, "reference to unknown type"); |
228 |
if ((m = getint(objsize)) != OVOID) { |
229 |
m += objorig; |
230 |
if ((OBJECT)m != m) |
231 |
232 |
233 |
objp->omod = m; |
234 |
objp->oname = savqstr(getstr(sbuf)); |
235 |
if (objp->oargs.nsargs = getint(2)) { |
236 |
objp->oargs.sarg = (char **)bmalloc |
237 |
(objp->oargs.nsargs*sizeof(char *)); |
238 |
if (objp->oargs.sarg == NULL) |
239 |
goto memerr; |
240 |
for (i = 0; i < objp->oargs.nsargs; i++) |
241 |
objp->oargs.sarg[i] = savestr(getstr(sbuf)); |
242 |
} else |
243 |
objp->oargs.sarg = NULL; |
244 |
#ifdef IARGS |
245 |
if (objp->oargs.niargs = getint(2)) { |
246 |
objp->oargs.iarg = (long *)bmalloc |
247 |
(objp->oargs.niargs*sizeof(long)); |
248 |
if (objp->oargs.iarg == NULL) |
249 |
goto memerr; |
250 |
for (i = 0; i < objp->oargs.niargs; i++) |
251 |
objp->oargs.iarg[i] = getint(4); |
252 |
} else |
253 |
objp->oargs.iarg = NULL; |
254 |
#endif |
255 |
if (objp->oargs.nfargs = getint(2)) { |
256 |
objp->oargs.farg = (FLOAT *)bmalloc |
257 |
(objp->oargs.nfargs*sizeof(FLOAT)); |
258 |
if (objp->oargs.farg == NULL) |
259 |
goto memerr; |
260 |
for (i = 0; i < objp->oargs.nfargs; i++) |
261 |
objp->oargs.farg[i] = getflt(); |
262 |
} else |
263 |
objp->oargs.farg = NULL; |
264 |
/* initialize */ |
265 |
objp->os = NULL; |
266 |
objp->lastrno = -1; |
267 |
/* insert */ |
268 |
insertobject(obj); |
269 |
return(obj); |
270 |
memerr: |
271 |
error(SYSTEM, "out of memory in getobj"); |
272 |
273 |
274 |
275 |
static |
276 |
octerror(etyp, msg) /* octree error */ |
277 |
int etyp; |
278 |
char *msg; |
279 |
280 |
char msgbuf[128]; |
281 |
282 |
sprintf(msgbuf, "(%s): %s", infn, msg); |
283 |
error(etyp, msgbuf); |
284 |
