root/radiance/ray/src/common/readoct.c
Revision: 1.12
Committed: Thu Apr 18 13:01:28 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.11: +4 -5 lines
added format information to header
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * readoct.c - routines to read octree information.
9 *
10 * 7/30/85
11 */
12
13 #include "standard.h"
14
15 #include "octree.h"
16
17 #include "object.h"
18
19 #include "otypes.h"
20
21 extern double atof();
22 static double getflt();
23 static long getint();
24 static char *getstr();
25 static OCTREE getfullnode(), gettree();
26
27 static char *infn; /* input file name */
28 static FILE *infp; /* input file stream */
29 static OBJECT objorig; /* zeroeth object */
30 static short otypmap[NUMOTYPE+8]; /* object type map */
31
32
33 int
34 readoct(fname, load, scene, ofn) /* read in octree from file */
35 char *fname;
36 int load;
37 CUBE *scene;
38 char *ofn[];
39 {
40 extern int fputs();
41 char sbuf[512];
42 int nf;
43 OBJECT fnobjects;
44 register int i;
45
46 if (fname == NULL) {
47 infn = "standard input";
48 infp = stdin;
49 } else {
50 infn = fname;
51 if ((infp = fopen(fname, "r")) == NULL) {
52 sprintf(errmsg, "cannot open octree file \"%s\"",
53 fname);
54 error(SYSTEM, errmsg);
55 }
56 }
57 /* get header */
58 if (checkheader(infp, OCTFMT, load&IO_INFO ? stdout : NULL) < 0)
59 octerror(USER, "not an octree");
60 /* check format */
61 if (getint(2) != OCTMAGIC)
62 octerror(USER, "incompatible octree format");
63 /* get boundaries */
64 if (load & IO_BOUNDS) {
65 for (i = 0; i < 3; i++)
66 scene->cuorg[i] = atof(getstr(sbuf));
67 scene->cusize = atof(getstr(sbuf));
68 } else {
69 for (i = 0; i < 4; i++)
70 getstr(sbuf);
71 }
72 objorig = nobjects; /* set object offset */
73 nf = 0; /* get object files */
74 while (*getstr(sbuf)) {
75 if (load & IO_SCENE)
76 readobj(sbuf);
77 if (load & IO_FILES)
78 ofn[nf] = savqstr(sbuf);
79 nf++;
80 }
81 if (load & IO_FILES)
82 ofn[nf] = NULL;
83 /* get number of objects */
84 fnobjects = getint(sizeof(OBJECT));
85
86 if (load & IO_TREE) {
87 /* get the octree */
88 scene->cutree = gettree();
89 /* get the scene */
90 if (nf == 0 && load & IO_SCENE) {
91 for (i = 0; *getstr(sbuf); i++)
92 if ((otypmap[i] = otype(sbuf)) < 0) {
93 sprintf(errmsg, "unknown type \"%s\"",
94 sbuf);
95 octerror(WARNING, errmsg);
96 }
97 while (getobj() != OVOID)
98 ;
99 }
100 }
101 fclose(infp);
102 /* consistency checks */
103 if (load & IO_SCENE) {
104 /* check object count */
105 if (nobjects != objorig+fnobjects)
106 octerror(USER, "bad object count; octree stale?");
107 /* check for non-surfaces */
108 if (nonsurfinset(objorig, fnobjects))
109 octerror(USER, "non-surface in set; octree stale?");
110 }
111 return(nf);
112 }
113
114
115 static char *
116 getstr(s) /* get null-terminated string */
117 char *s;
118 {
119 register char *cp;
120 register int c;
121
122 cp = s;
123 while ((c = getc(infp)) != EOF)
124 if ((*cp++ = c) == '\0')
125 return(s);
126
127 octerror(USER, "truncated octree");
128 }
129
130
131 static OCTREE
132 getfullnode() /* get a set, return fullnode */
133 {
134 OBJECT set[MAXSET+1];
135 register int i;
136
137 set[0] = getint(sizeof(OBJECT));
138 if (set[0] > MAXSET)
139 octerror(USER, "bad set in getfullnode");
140 for (i = 1; i <= set[0]; i++)
141 set[i] = getint(sizeof(OBJECT)) + objorig;
142 return(fullnode(set));
143 }
144
145
146 static long
147 getint(siz) /* get a siz-byte integer */
148 register int siz;
149 {
150 register int c;
151 register long r;
152
153 if ((c = getc(infp)) == EOF)
154 goto end_file;
155 r = 0x80&c ? -1<<8|c : c; /* sign extend */
156 while (--siz > 0) {
157 if ((c = getc(infp)) == EOF)
158 goto end_file;
159 r <<= 8;
160 r |= c;
161 }
162 return(r);
163 end_file:
164 octerror(USER, "truncated octree");
165 }
166
167
168 static double
169 getflt() /* get a floating point number */
170 {
171 extern double ldexp();
172 double d;
173
174 d = (double)getint(4)/0x7fffffff;
175 return(ldexp(d, (int)getint(1)));
176 }
177
178
179 static OCTREE
180 gettree() /* get a pre-ordered octree */
181 {
182 register OCTREE ot;
183 register int i;
184
185 switch (getc(infp)) {
186 case OT_EMPTY:
187 return(EMPTY);
188 case OT_FULL:
189 return(getfullnode());
190 case OT_TREE:
191 if ((ot = octalloc()) == EMPTY)
192 octerror(SYSTEM, "out of tree space in gettree");
193 for (i = 0; i < 8; i++)
194 octkid(ot, i) = gettree();
195 return(ot);
196 case EOF:
197 octerror(USER, "truncated octree");
198 default:
199 octerror(USER, "damaged octree");
200 }
201 }
202
203
204 static
205 getobj() /* get next object */
206 {
207 char sbuf[MAXSTR];
208 int obj;
209 register int i;
210 register OBJREC *objp;
211
212 i = getint(1);
213 if (i == -1)
214 return(OVOID); /* terminator */
215 if ((obj = newobject()) == OVOID)
216 error(SYSTEM, "out of object space");
217 objp = objptr(obj);
218 if ((objp->otype = otypmap[i]) < 0)
219 octerror(USER, "reference to unknown type");
220 if ((objp->omod = getint(sizeof(OBJECT))) != OVOID)
221 objp->omod += objorig;
222 objp->oname = savqstr(getstr(sbuf));
223 if (objp->oargs.nsargs = getint(2)) {
224 objp->oargs.sarg = (char **)bmalloc
225 (objp->oargs.nsargs*sizeof(char *));
226 if (objp->oargs.sarg == NULL)
227 goto memerr;
228 for (i = 0; i < objp->oargs.nsargs; i++)
229 objp->oargs.sarg[i] = savestr(getstr(sbuf));
230 } else
231 objp->oargs.sarg = NULL;
232 #ifdef IARGS
233 if (objp->oargs.niargs = getint(2)) {
234 objp->oargs.iarg = (long *)bmalloc
235 (objp->oargs.niargs*sizeof(long));
236 if (objp->oargs.iarg == NULL)
237 goto memerr;
238 for (i = 0; i < objp->oargs.niargs; i++)
239 objp->oargs.iarg[i] = getint(4);
240 } else
241 objp->oargs.iarg = NULL;
242 #endif
243 if (objp->oargs.nfargs = getint(2)) {
244 objp->oargs.farg = (double *)bmalloc
245 (objp->oargs.nfargs*sizeof(double));
246 if (objp->oargs.farg == NULL)
247 goto memerr;
248 for (i = 0; i < objp->oargs.nfargs; i++)
249 objp->oargs.farg[i] = getflt();
250 } else
251 objp->oargs.farg = NULL;
252 /* initialize */
253 objp->os = NULL;
254 objp->lastrno = -1;
255 /* insert */
256 insertobject(obj);
257 return(obj);
258 memerr:
259 error(SYSTEM, "out of memory in getobj");
260 }
261
262
263 static
264 octerror(etyp, msg) /* octree error */
265 int etyp;
266 char *msg;
267 {
268 char msgbuf[128];
269
270 sprintf(msgbuf, "(%s): %s", infn, msg);
271 error(etyp, msgbuf);
272 }
