--- ray/src/common/readoct.c 1997/03/07 15:45:26 2.12 +++ ray/src/common/readoct.c 2025/06/07 05:09:45 2.37 @@ -1,64 +1,74 @@ -/* Copyright (c) 1992 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: readoct.c,v 2.37 2025/06/07 05:09:45 greg Exp $"; #endif - /* * readoct.c - routines to read octree information. - * - * 7/30/85 */ -#include "standard.h" +#include "copyright.h" -#include "octree.h" +#include +#include +#include "platform.h" +#include "standard.h" +#include "octree.h" #include "object.h" - #include "otypes.h" +#include "resolu.h" -static double ogetflt(); -static long ogetint(); -static char *ogetstr(); -static int nonsurfinset(); -static int getobj(), octerror(), skiptree(); -static OCTREE getfullnode(), gettree(); +static double ogetflt(void); +static long ogetint(int); +static char *ogetstr(char *); +static int nonsurfintree(OCTREE ot); +static void octerror(int etyp, char *msg); +static void skiptree(void); +static OCTREE getfullnode(void), gettree(void); -static char *infn; /* input file name */ +static char *infn; /* input file specification */ static FILE *infp; /* input file stream */ static int objsize; /* size of stored OBJECT's */ static OBJECT objorig; /* zeroeth object */ static OBJECT fnobjects; /* number of objects in this file */ -static short otypmap[NUMOTYPE+8]; /* object type map */ int -readoct(fname, load, scene, ofn) /* read in octree from file */ -char *fname; -int load; -CUBE *scene; -char *ofn[]; +readoct( /* read in octree file or stream */ + char *inpspec, + int load, + CUBE *scene, + char *ofn[] +) { + time_t oct_t = 0; + time_t last_it = 0; char sbuf[512]; int nf; - register int i; + int i; long m; - if (fname == NULL) { + if (inpspec == NULL) { infn = "standard input"; infp = stdin; + } else if (inpspec[0] == '!') { + infn = inpspec; + if ((infp = popen(inpspec+1, "r")) == NULL) { + sprintf(errmsg, "cannot execute \"%s\"", inpspec); + error(SYSTEM, errmsg); + } } else { - infn = fname; - if ((infp = fopen(fname, "r")) == NULL) { + infn = inpspec; + if ((infp = fopen(inpspec, "r")) == NULL) { sprintf(errmsg, "cannot open octree file \"%s\"", - fname); + inpspec); error(SYSTEM, errmsg); } + oct_t = fddate(fileno(infp)); } -#ifdef MSDOS - setmode(fileno(infp), O_BINARY); +#ifdef getc_unlocked /* avoid stupid semaphores */ + flockfile(infp); #endif + SET_FILE_BINARY(infp); /* get header */ if (checkheader(infp, OCTFMT, load&IO_INFO ? stdout : (FILE *)NULL) < 0) octerror(USER, "not an octree"); @@ -82,6 +92,11 @@ char *ofn[]; readobj(sbuf); if (load & IO_FILES) ofn[nf] = savqstr(sbuf); + if (oct_t > last_it) { + time_t t = fdate(sbuf); + if (t > last_it) + last_it = t; + } nf++; } if (load & IO_FILES) @@ -91,39 +106,44 @@ char *ofn[]; if (fnobjects != m) octerror(USER, "too many objects"); - if (load & IO_TREE) /* get the octree */ + if (load & IO_TREE) /* get the octree */ scene->cutree = gettree(); else if (load & IO_SCENE && nf == 0) skiptree(); - if (load & IO_SCENE) /* get the scene */ + if (load & IO_SCENE) { /* get the scene */ if (nf == 0) { - for (i = 0; *ogetstr(sbuf); i++) - if ((otypmap[i] = otype(sbuf)) < 0) { - sprintf(errmsg, "unknown type \"%s\"", sbuf); - octerror(WARNING, errmsg); - } - while (getobj() != OVOID) - ; + /* load binary scene data */ + readscene(infp, objsize); + } else { /* consistency checks */ /* check object count */ if (nobjects != objorig+fnobjects) octerror(USER, "bad object count; octree stale?"); /* check for non-surfaces */ - if (dosets(nonsurfinset)) + if (oct_t <= last_it && nonsurfintree(scene->cutree)) octerror(USER, "modifier in tree; octree stale?"); } - fclose(infp); + } + /* close the input */ + if (inpspec[0] == '!') { + if (pclose(infp) != 0) { + sprintf(errmsg, "bad status from \"%s\"", inpspec); + error(WARNING, errmsg); + } + } else if (infp != stdin) + fclose(infp); +#ifdef getc_unlocked + else + funlockfile(infp); +#endif return(nf); } static char * -ogetstr(s) /* get null-terminated string */ -char *s; +ogetstr(char *s) /* get null-terminated string */ { - extern char *getstr(); - if (getstr(s, infp) == NULL) octerror(USER, "truncated octree"); return(s); @@ -134,8 +154,8 @@ static OCTREE getfullnode() /* get a set, return fullnode */ { OBJECT set[MAXSET+1]; - register int i; - register long m; + int i; + long m; if ((set[0] = ogetint(objsize)) > MAXSET) octerror(USER, "bad set in getfullnode"); @@ -149,11 +169,9 @@ getfullnode() /* get a set, return fullnode */ static long -ogetint(siz) /* get a siz-byte integer */ -int siz; +ogetint(int siz) /* get a siz-byte integer */ { - extern long getint(); - register long r; + long r; r = getint(siz, infp); if (feof(infp)) @@ -165,7 +183,6 @@ int siz; static double ogetflt() /* get a floating point number */ { - extern double getflt(); double r; r = getflt(infp); @@ -178,8 +195,8 @@ ogetflt() /* get a floating point number */ static OCTREE gettree() /* get a pre-ordered octree */ { - register OCTREE ot; - register int i; + OCTREE ot; + int i; switch (getc(infp)) { case OT_EMPTY: @@ -197,28 +214,36 @@ gettree() /* get a pre-ordered octree */ default: octerror(USER, "damaged octree"); } + return EMPTY; /* pro forma return */ } static int -nonsurfinset(os) /* check set for modifier */ -register OBJECT *os; +nonsurfintree(OCTREE ot) /* check tree for modifiers */ { - register OBJECT s; - register int i; + OBJECT set[MAXSET+1]; + int i; - for (i = *os; i-- > 0; ) - if ((s = *++os) >= objorig && s < objorig+fnobjects && - ismodifier(objptr(s)->otype)) + if (isempty(ot)) + return(0); + if (istree(ot)) { + for (i = 0; i < 8; i++) + if (nonsurfintree(octkid(ot, i))) + return(1); + return(0); + } + objset(set, ot); + for (i = set[0]; i > 0; i-- ) + if (ismodifier(objptr(set[i])->otype)) return(1); return(0); } -static -skiptree() /* skip octree on input */ +static void +skiptree(void) /* skip octree on input */ { - register int i; + int i; switch (getc(infp)) { case OT_EMPTY: @@ -240,73 +265,8 @@ skiptree() /* skip octree on input */ } -static -getobj() /* get next object */ -{ - char sbuf[MAXSTR]; - int obj; - register int i; - register long m; - register OBJREC *objp; - - i = ogetint(1); - if (i == -1) - return(OVOID); /* terminator */ - if ((obj = newobject()) == OVOID) - error(SYSTEM, "out of object space"); - objp = objptr(obj); - if ((objp->otype = otypmap[i]) < 0) - octerror(USER, "reference to unknown type"); - if ((m = ogetint(objsize)) != OVOID) { - m += objorig; - if ((OBJECT)m != m) - octerror(USER, "too many objects"); - } - objp->omod = m; - objp->oname = savqstr(ogetstr(sbuf)); - if (objp->oargs.nsargs = ogetint(2)) { - objp->oargs.sarg = (char **)bmalloc - (objp->oargs.nsargs*sizeof(char *)); - if (objp->oargs.sarg == NULL) - goto memerr; - for (i = 0; i < objp->oargs.nsargs; i++) - objp->oargs.sarg[i] = savestr(ogetstr(sbuf)); - } else - objp->oargs.sarg = NULL; -#ifdef IARGS - if (objp->oargs.niargs = ogetint(2)) { - objp->oargs.iarg = (long *)bmalloc - (objp->oargs.niargs*sizeof(long)); - if (objp->oargs.iarg == NULL) - goto memerr; - for (i = 0; i < objp->oargs.niargs; i++) - objp->oargs.iarg[i] = ogetint(4); - } else - objp->oargs.iarg = NULL; -#endif - if (objp->oargs.nfargs = ogetint(2)) { - objp->oargs.farg = (FLOAT *)bmalloc - (objp->oargs.nfargs*sizeof(FLOAT)); - if (objp->oargs.farg == NULL) - goto memerr; - for (i = 0; i < objp->oargs.nfargs; i++) - objp->oargs.farg[i] = ogetflt(); - } else - objp->oargs.farg = NULL; - /* initialize */ - objp->os = NULL; - /* insert */ - insertobject(obj); - return(obj); -memerr: - error(SYSTEM, "out of memory in getobj"); -} - - -static -octerror(etyp, msg) /* octree error */ -int etyp; -char *msg; +static void +octerror(int etyp, char *msg) /* octree error */ { char msgbuf[128];
