root/radiance/ray/src/common/readoct.c
Revision: 2.31
Committed: Sat May 4 00:32:47 2019 UTC (6 years, 1 month ago) by greg
Fixed issue with recovering after octree read from stdin
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.31 static const char RCSid[] = "$Id: readoct.c,v 2.30 2016/03/04 00:21:21 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * readoct.c - routines to read octree information.
6 greg 2.13 */
7
8 greg 2.14 #include "copyright.h"
9 greg 1.1
10 schorsch 2.17 #include <stdio.h>
11 greg 2.19 #include <time.h>
12 schorsch 2.17
13 greg 2.23 #include "platform.h"
14 greg 2.29 #include "paths.h"
15 greg 1.1 #include "standard.h"
16     #include "octree.h"
17     #include "object.h"
18     #include "otypes.h"
19 schorsch 2.17 #include "resolu.h"
20 greg 1.1
21 schorsch 2.20 static double ogetflt(void);
22     static long ogetint(int);
23     static char *ogetstr(char *);
24 greg 2.27 static int nonsurfintree(OCTREE ot);
25 schorsch 2.17 static void octerror(int etyp, char *msg);
26     static void skiptree(void);
27 schorsch 2.20 static OCTREE getfullnode(void), gettree(void);
28 greg 1.1
29 greg 2.13 static char *infn; /* input file specification */
30 greg 1.1 static FILE *infp; /* input file stream */
31 greg 1.14 static int objsize; /* size of stored OBJECT's */
32 greg 1.1 static OBJECT objorig; /* zeroeth object */
33 greg 2.12 static OBJECT fnobjects; /* number of objects in this file */
34 greg 1.1
35
36     int
37 greg 2.27 readoct( /* read in octree file or stream */
38     char *inpspec,
39     int load,
40     CUBE *scene,
41     char *ofn[]
42     )
43 greg 1.1 {
44 greg 1.11 char sbuf[512];
45 greg 1.1 int nf;
46 greg 2.15 int i;
47 greg 1.15 long m;
48 greg 1.1
49 greg 2.13 if (inpspec == NULL) {
50 greg 1.1 infn = "standard input";
51     infp = stdin;
52 greg 2.13 } else if (inpspec[0] == '!') {
53     infn = inpspec;
54     if ((infp = popen(inpspec+1, "r")) == NULL) {
55     sprintf(errmsg, "cannot execute \"%s\"", inpspec);
56     error(SYSTEM, errmsg);
57     }
58 greg 1.1 } else {
59 greg 2.13 infn = inpspec;
60     if ((infp = fopen(inpspec, "r")) == NULL) {
61 greg 1.1 sprintf(errmsg, "cannot open octree file \"%s\"",
62 greg 2.13 inpspec);
63 greg 1.1 error(SYSTEM, errmsg);
64     }
65     }
66 schorsch 2.16 SET_FILE_BINARY(infp);
67 greg 1.1 /* get header */
68 greg 2.11 if (checkheader(infp, OCTFMT, load&IO_INFO ? stdout : (FILE *)NULL) < 0)
69 greg 1.12 octerror(USER, "not an octree");
70 greg 1.1 /* check format */
71 greg 2.4 if ((objsize = ogetint(2)-OCTMAGIC) <= 0 ||
72 greg 1.14 objsize > MAXOBJSIZ || objsize > sizeof(long))
73 greg 1.12 octerror(USER, "incompatible octree format");
74 greg 1.1 /* get boundaries */
75     if (load & IO_BOUNDS) {
76     for (i = 0; i < 3; i++)
77 greg 2.4 scene->cuorg[i] = atof(ogetstr(sbuf));
78     scene->cusize = atof(ogetstr(sbuf));
79 greg 1.1 } else {
80     for (i = 0; i < 4; i++)
81 greg 2.4 ogetstr(sbuf);
82 greg 1.1 }
83     objorig = nobjects; /* set object offset */
84     nf = 0; /* get object files */
85 greg 2.4 while (*ogetstr(sbuf)) {
86 greg 1.1 if (load & IO_SCENE)
87     readobj(sbuf);
88     if (load & IO_FILES)
89     ofn[nf] = savqstr(sbuf);
90     nf++;
91     }
92     if (load & IO_FILES)
93     ofn[nf] = NULL;
94 greg 1.8 /* get number of objects */
95 greg 2.4 fnobjects = m = ogetint(objsize);
96 greg 1.15 if (fnobjects != m)
97     octerror(USER, "too many objects");
98 greg 1.1
99 greg 2.13 if (load & IO_TREE) /* get the octree */
100 greg 1.1 scene->cutree = gettree();
101 greg 2.5 else if (load & IO_SCENE && nf == 0)
102     skiptree();
103
104 schorsch 2.21 if (load & IO_SCENE) { /* get the scene */
105 greg 2.5 if (nf == 0) {
106 greg 2.15 /* load binary scene data */
107     readscene(infp, objsize);
108
109 greg 2.5 } else { /* consistency checks */
110     /* check object count */
111     if (nobjects != objorig+fnobjects)
112     octerror(USER, "bad object count; octree stale?");
113     /* check for non-surfaces */
114 greg 2.27 if (nonsurfintree(scene->cutree))
115 greg 2.5 octerror(USER, "modifier in tree; octree stale?");
116     }
117 schorsch 2.21 }
118 greg 2.13 /* close the input */
119     if (infn[0] == '!')
120     pclose(infp);
121 greg 2.31 else if (infp != stdin)
122 greg 2.13 fclose(infp);
123 greg 1.1 return(nf);
124     }
125
126
127     static char *
128 greg 2.27 ogetstr(char *s) /* get null-terminated string */
129 greg 1.1 {
130 greg 2.4 extern char *getstr();
131 greg 1.1
132 greg 2.4 if (getstr(s, infp) == NULL)
133     octerror(USER, "truncated octree");
134     return(s);
135 greg 1.1 }
136
137
138     static OCTREE
139     getfullnode() /* get a set, return fullnode */
140     {
141 greg 2.7 OBJECT set[MAXSET+1];
142 greg 1.1 register int i;
143 greg 1.14 register long m;
144 greg 1.1
145 greg 2.4 if ((set[0] = ogetint(objsize)) > MAXSET)
146 greg 1.1 octerror(USER, "bad set in getfullnode");
147 greg 1.14 for (i = 1; i <= set[0]; i++) {
148 greg 2.4 m = ogetint(objsize) + objorig;
149 greg 1.15 if ((set[i] = m) != m)
150 greg 1.14 octerror(USER, "too many objects");
151     }
152 greg 1.1 return(fullnode(set));
153     }
154
155
156     static long
157 greg 2.27 ogetint(int siz) /* get a siz-byte integer */
158 greg 1.1 {
159 greg 2.4 extern long getint();
160 greg 1.3 register long r;
161 greg 1.1
162 greg 2.4 r = getint(siz, infp);
163     if (feof(infp))
164     octerror(USER, "truncated octree");
165 greg 1.1 return(r);
166     }
167
168
169     static double
170 greg 2.4 ogetflt() /* get a floating point number */
171 greg 1.1 {
172 greg 2.4 extern double getflt();
173 greg 2.7 double r;
174 greg 1.1
175 greg 2.4 r = getflt(infp);
176     if (feof(infp))
177     octerror(USER, "truncated octree");
178     return(r);
179 greg 1.1 }
180
181
182     static OCTREE
183     gettree() /* get a pre-ordered octree */
184     {
185 greg 2.7 register OCTREE ot;
186 greg 1.1 register int i;
187
188     switch (getc(infp)) {
189     case OT_EMPTY:
190     return(EMPTY);
191     case OT_FULL:
192     return(getfullnode());
193     case OT_TREE:
194     if ((ot = octalloc()) == EMPTY)
195     octerror(SYSTEM, "out of tree space in gettree");
196     for (i = 0; i < 8; i++)
197     octkid(ot, i) = gettree();
198     return(ot);
199 greg 2.5 case EOF:
200     octerror(USER, "truncated octree");
201     default:
202     octerror(USER, "damaged octree");
203     }
204 greg 2.22 return EMPTY; /* pro forma return */
205 greg 2.12 }
206
207
208     static int
209 greg 2.27 nonsurfintree(OCTREE ot) /* check tree for modifiers */
210 greg 2.12 {
211 greg 2.27 OBJECT set[MAXSET+1];
212 greg 2.12 register int i;
213
214 greg 2.27 if (isempty(ot))
215     return(0);
216     if (istree(ot)) {
217     for (i = 0; i < 8; i++)
218     if (nonsurfintree(octkid(ot, i)))
219     return(1);
220     return(0);
221     }
222     objset(set, ot);
223 greg 2.28 for (i = set[0]; i > 0; i-- )
224 greg 2.27 if (ismodifier(objptr(set[i])->otype))
225 greg 2.12 return(1);
226     return(0);
227 greg 2.5 }
228
229
230 schorsch 2.17 static void
231     skiptree(void) /* skip octree on input */
232 greg 2.5 {
233     register int i;
234
235     switch (getc(infp)) {
236     case OT_EMPTY:
237     return;
238     case OT_FULL:
239 greg 2.6 for (i = ogetint(objsize)*objsize; i-- > 0; )
240     if (getc(infp) == EOF)
241     octerror(USER, "truncated octree");
242 greg 2.5 return;
243     case OT_TREE:
244     for (i = 0; i < 8; i++)
245     skiptree();
246     return;
247 greg 1.1 case EOF:
248     octerror(USER, "truncated octree");
249     default:
250     octerror(USER, "damaged octree");
251     }
252     }
253
254
255 schorsch 2.17 static void
256 greg 2.27 octerror(int etyp, char *msg) /* octree error */
257 greg 1.1 {
258     char msgbuf[128];
259
260     sprintf(msgbuf, "(%s): %s", infn, msg);
261     error(etyp, msgbuf);
262     }
