root/radiance/ray/src/common/readoct.c
Fri Mar 4 00:21:21 2016 UTC (8 years, 2 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.29: +1 -6 lines
Diff to previous 2.29 , to selected 1.3
Tue Feb 2 18:02:32 2016 UTC (8 years, 3 months ago) by greg
Diff to previous 2.28 , to selected 1.3
Thu Dec 16 19:31:36 2004 UTC (19 years, 5 months ago) by greg
CVS Tags: rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0
Diff to previous 2.27 , to selected 1.3
Fixed problem with last bug-fix (serious)
Wed Dec 15 22:02:04 2004 UTC (19 years, 5 months ago) by greg
Changes since 2.26: +25 -21 lines
Diff to previous 2.26 , to selected 1.3
Fixed bug that caused inappropriate fatal error mixing meshes and instances
Tue Sep 14 02:53:50 2004 UTC (19 years, 8 months ago) by greg
Changes since 2.25: +2 -1 lines
Diff to previous 2.25 , to selected 1.3
Added #undef for getc/putc where they were being replaced
Thu Apr 29 14:36:49 2004 UTC (20 years ago) by greg
Changes since 2.24: +5 -1 lines
Diff to previous 2.24 , to selected 1.3
Added macros to avoid flockfile(3) overhead
Changes since 2.23: +2 -1 lines
Diff to previous 2.23 , to selected 1.3
Diff to previous 2.22 , to selected 1.3
Fri Aug 29 16:46:51 2003 UTC (20 years, 8 months ago) by greg
Diff to previous 2.21 , to selected 1.3
Fixed inappropriate return
Mon Jul 21 22:30:17 2003 UTC (20 years, 10 months ago) by schorsch
Diff to previous 2.20 , to selected 1.3
Changes since 2.19: +6 -6 lines
Diff to previous 2.19 , to selected 1.3
Wed Jul 16 01:32:53 2003 UTC (20 years, 10 months ago) by greg
Changes since 2.18: +2 -1 lines
Diff to previous 2.18 , to selected 1.3
Minor compile fixes
Sun Jun 8 12:03:09 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.17: +2 -5 lines
Diff to previous 2.17 , to selected 1.3
Changes since 2.16: +14 -8 lines
Diff to previous 2.16 , to selected 1.3
Changes since 2.15: +2 -4 lines
Diff to previous 2.15 , to selected 1.3
Fri Mar 14 21:27:46 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.14: +5 -73 lines
Diff to previous 2.14 , to selected 1.3
Changes since 2.13: +1 -56 lines
Diff to previous 2.13 , to selected 1.3
Changes since 2.12: +79 -17 lines
Diff to previous 2.12 , to selected 1.3
Fri Mar 7 15:45:26 1997 UTC (27 years, 2 months ago) by greg
Changes since 2.11: +18 -2 lines
Diff to previous 2.11 , to selected 1.3
added new set routines
Mon Aug 29 14:20:37 1994 UTC (29 years, 8 months ago) by greg
Diff to previous 2.10 , to selected 1.3
fixed AIX compiler problem with conditional
Thu Nov 18 09:27:01 1993 UTC (30 years, 6 months ago) by greg
Diff to previous 2.9 , to selected 1.3
minor compiler warning fixes
Mon Jun 7 09:42:16 1993 UTC (30 years, 11 months ago) by greg
Changes since 2.8: +0 -1 lines
Diff to previous 2.8 , to selected 1.3
removed incorrect declaration of fputs()
Mon Jan 25 12:42:39 1993 UTC (31 years, 4 months ago) by greg
Changes since 2.7: +0 -1 lines
Diff to previous 2.7 , to selected 1.3
removed lastrno from object structure
Mon Sep 21 12:04:17 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.6: +9 -6 lines
Diff to previous 2.6 , to selected 1.3
Changes for PC port
Thu Aug 6 09:29:38 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.5: +3 -2 lines
Diff to previous 2.5 , to selected 1.3
made skiptree() slightly more efficient
Thu Aug 6 09:02:38 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.4: +46 -22 lines
Diff to previous 2.4 , to selected 1.3
added skiptree() function for reading scenes w/o octrees
Mon Jul 13 15:36:29 1992 UTC (31 years, 10 months ago) by greg
Changes since 2.3: +39 -49 lines
Diff to previous 2.3 , to selected 1.3
moved portable i/o routines to portio.c
Thu Mar 12 12:18:18 1992 UTC (32 years, 2 months ago) by greg
Changes since 2.2: +7 -7 lines
Diff to previous 2.2 , to selected 1.3
improved logic slightly
Thu Dec 19 14:45:45 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 2.1 , to selected 1.3
Tue Nov 12 16:55:01 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.16 , to selected 1.3
Mon Oct 28 09:47:22 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.15: +1 -0 lines
Diff to previous 1.15 , to selected 1.3
Thu Oct 24 10:13:20 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.14: +8 -8 lines
Diff to previous 1.14 , to selected 1.3
minor fixes
Wed Oct 23 11:53:38 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.13: +21 -8 lines
Diff to previous 1.13 , to selected 1.3
added conditional sizing of structures from BIGMEM
made reading of foreign octrees more flexible
Mon Aug 5 08:58:52 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.12: +8 -10 lines
Diff to previous 1.12 , to selected 1.3
fixed small logic problem
Thu Apr 18 13:01:28 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.11: +4 -5 lines
Diff to previous 1.11 , to selected 1.3
added format information to header
Thu Feb 7 11:00:42 1991 UTC (33 years, 3 months ago) by greg
Diff to previous 1.10 , to selected 1.3
increased sbuf size from 128 to 512 bytes
Wed Dec 12 22:43:57 1990 UTC (33 years, 5 months ago) by greg
Diff to previous 1.9 , to selected 1.3
put in cast to ldexp() call
Mon Sep 10 10:01:21 1990 UTC (33 years, 8 months ago) by greg
Diff to previous 1.8 , to selected 1.3
minor change in stale octree error reporting
Thu Sep 6 23:32:45 1990 UTC (33 years, 8 months ago) by greg
Changes since 1.7: +12 -0 lines
Diff to previous 1.7 , to selected 1.3
added consistency checks to detect stale octrees
Mon Mar 12 10:39:17 1990 UTC (34 years, 2 months ago) by greg
Changes since 1.6: +5 -5 lines
Diff to previous 1.6 , to selected 1.3
fixed predeclarations for fussy compilers
Tue Sep 19 13:40:48 1989 UTC (34 years, 8 months ago) by greg
Changes since 1.5: +7 -5 lines
Diff to previous 1.5 , to selected 1.3
eliminated unnecessary call to ungetc()
Sun Apr 23 19:38:51 1989 UTC (35 years, 1 month ago) by greg
Diff to previous 1.4 , to selected 1.3
changed error message
Wed Mar 22 09:53:46 1989 UTC (35 years, 2 months ago) by greg
Diff to previous 1.3
deleted inappropriate comment
Revision 1.3 - (view) (download) (annotate) - [selected]
Tue Mar 21 15:54:45 1989 UTC (35 years, 2 months ago) by greg
Changes since 1.2: +9 -6 lines
Diff to previous 1.2
fixed getint portability problems
Tue Feb 21 14:59:06 1989 UTC (35 years, 3 months ago) by greg
Diff to previous 1.1 , to selected 1.3
portability fixes
Thu Feb 2 10:34:40 1989 UTC (35 years, 3 months ago) by greg
Diff to selected 1.3
