--- ray/src/common/readoct.c 1992/08/06 09:02:38 2.5 +++ ray/src/common/readoct.c 1993/06/07 09:42:16 2.9 @@ -38,10 +38,9 @@ int load; CUBE *scene; char *ofn[]; { - extern int fputs(); char sbuf[512]; int nf; - OBJECT fnobjects; + OBJECT fnobjects; register int i; long m; @@ -56,6 +55,9 @@ char *ofn[]; error(SYSTEM, errmsg); } } +#ifdef MSDOS + setmode(fileno(infp), O_BINARY); +#endif /* get header */ if (checkheader(infp, OCTFMT, load&IO_INFO ? stdout : NULL) < 0) octerror(USER, "not an octree"); @@ -130,7 +132,7 @@ char *s; static OCTREE getfullnode() /* get a set, return fullnode */ { - OBJECT set[MAXSET+1]; + OBJECT set[MAXSET+1]; register int i; register long m; @@ -163,7 +165,7 @@ static double ogetflt() /* get a floating point number */ { extern double getflt(); - double r; + double r; r = getflt(infp); if (feof(infp)) @@ -175,7 +177,7 @@ ogetflt() /* get a floating point number */ static OCTREE gettree() /* get a pre-ordered octree */ { - register OCTREE ot; + register OCTREE ot; register int i; switch (getc(infp)) { @@ -206,8 +208,9 @@ skiptree() /* skip octree on input */ case OT_EMPTY: return; case OT_FULL: - for (i = ogetint(objsize); i-- > 0; ) - ogetint(objsize); + for (i = ogetint(objsize)*objsize; i-- > 0; ) + if (getc(infp) == EOF) + octerror(USER, "truncated octree"); return; case OT_TREE: for (i = 0; i < 8; i++) @@ -228,7 +231,7 @@ getobj() /* get next object */ int obj; register int i; register long m; - register OBJREC *objp; + register OBJREC *objp; i = ogetint(1); if (i == -1) @@ -254,7 +257,7 @@ getobj() /* get next object */ objp->oargs.sarg[i] = savestr(ogetstr(sbuf)); } else objp->oargs.sarg = NULL; -#ifdef IARGS +#ifdef IARGS if (objp->oargs.niargs = ogetint(2)) { objp->oargs.iarg = (long *)bmalloc (objp->oargs.niargs*sizeof(long)); @@ -276,7 +279,6 @@ getobj() /* get next object */ objp->oargs.farg = NULL; /* initialize */ objp->os = NULL; - objp->lastrno = -1; /* insert */ insertobject(obj); return(obj);
