root/radiance/ray/src/common/readoct.c
Revision: 2.9
Committed: Mon Jun 7 09:42:16 1993 UTC (32 years, 1 month ago) by greg
Changes since 2.8: +0 -1 lines
removed incorrect declaration of fputs()
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * readoct.c - routines to read octree information.
9 *
10 * 7/30/85
11 */
12
13 #include "standard.h"
14
15 #include "octree.h"
16
17 #include "object.h"
18
19 #include "otypes.h"
20
21 static double ogetflt();
22 static long ogetint();
23 static char *ogetstr();
24 static int getobj(), octerror();
25 static OCTREE getfullnode(), gettree();
26
27 static char *infn; /* input file name */
28 static FILE *infp; /* input file stream */
29 static int objsize; /* size of stored OBJECT's */
30 static OBJECT objorig; /* zeroeth object */
31 static short otypmap[NUMOTYPE+8]; /* object type map */
32
33
34 int
35 readoct(fname, load, scene, ofn) /* read in octree from file */
36 char *fname;
37 int load;
38 CUBE *scene;
39 char *ofn[];
40 {
41 char sbuf[512];
42 int nf;
43 OBJECT fnobjects;
44 register int i;
45 long m;
46
47 if (fname == NULL) {
48 infn = "standard input";
49 infp = stdin;
50 } else {
51 infn = fname;
52 if ((infp = fopen(fname, "r")) == NULL) {
53 sprintf(errmsg, "cannot open octree file \"%s\"",
54 fname);
55 error(SYSTEM, errmsg);
56 }
57 }
58 #ifdef MSDOS
59 setmode(fileno(infp), O_BINARY);
60 #endif
61 /* get header */
62 if (checkheader(infp, OCTFMT, load&IO_INFO ? stdout : NULL) < 0)
63 octerror(USER, "not an octree");
64 /* check format */
65 if ((objsize = ogetint(2)-OCTMAGIC) <= 0 ||
66 objsize > MAXOBJSIZ || objsize > sizeof(long))
67 octerror(USER, "incompatible octree format");
68 /* get boundaries */
69 if (load & IO_BOUNDS) {
70 for (i = 0; i < 3; i++)
71 scene->cuorg[i] = atof(ogetstr(sbuf));
72 scene->cusize = atof(ogetstr(sbuf));
73 } else {
74 for (i = 0; i < 4; i++)
75 ogetstr(sbuf);
76 }
77 objorig = nobjects; /* set object offset */
78 nf = 0; /* get object files */
79 while (*ogetstr(sbuf)) {
80 if (load & IO_SCENE)
81 readobj(sbuf);
82 if (load & IO_FILES)
83 ofn[nf] = savqstr(sbuf);
84 nf++;
85 }
86 if (load & IO_FILES)
87 ofn[nf] = NULL;
88 /* get number of objects */
89 fnobjects = m = ogetint(objsize);
90 if (fnobjects != m)
91 octerror(USER, "too many objects");
92
93 if (load & IO_TREE) /* get the octree */
94 scene->cutree = gettree();
95 else if (load & IO_SCENE && nf == 0)
96 skiptree();
97
98 if (load & IO_SCENE) /* get the scene */
99 if (nf == 0) {
100 for (i = 0; *ogetstr(sbuf); i++)
101 if ((otypmap[i] = otype(sbuf)) < 0) {
102 sprintf(errmsg, "unknown type \"%s\"", sbuf);
103 octerror(WARNING, errmsg);
104 }
105 while (getobj() != OVOID)
106 ;
107 } else { /* consistency checks */
108 /* check object count */
109 if (nobjects != objorig+fnobjects)
110 octerror(USER, "bad object count; octree stale?");
111 /* check for non-surfaces */
112 if (nonsurfinset(objorig, fnobjects))
113 octerror(USER, "modifier in tree; octree stale?");
114 }
115 fclose(infp);
116 return(nf);
117 }
118
119
120 static char *
121 ogetstr(s) /* get null-terminated string */
122 char *s;
123 {
124 extern char *getstr();
125
126 if (getstr(s, infp) == NULL)
127 octerror(USER, "truncated octree");
128 return(s);
129 }
130
131
132 static OCTREE
133 getfullnode() /* get a set, return fullnode */
134 {
135 OBJECT set[MAXSET+1];
136 register int i;
137 register long m;
138
139 if ((set[0] = ogetint(objsize)) > MAXSET)
140 octerror(USER, "bad set in getfullnode");
141 for (i = 1; i <= set[0]; i++) {
142 m = ogetint(objsize) + objorig;
143 if ((set[i] = m) != m)
144 octerror(USER, "too many objects");
145 }
146 return(fullnode(set));
147 }
148
149
150 static long
151 ogetint(siz) /* get a siz-byte integer */
152 int siz;
153 {
154 extern long getint();
155 register long r;
156
157 r = getint(siz, infp);
158 if (feof(infp))
159 octerror(USER, "truncated octree");
160 return(r);
161 }
162
163
164 static double
165 ogetflt() /* get a floating point number */
166 {
167 extern double getflt();
168 double r;
169
170 r = getflt(infp);
171 if (feof(infp))
172 octerror(USER, "truncated octree");
173 return(r);
174 }
175
176
177 static OCTREE
178 gettree() /* get a pre-ordered octree */
179 {
180 register OCTREE ot;
181 register int i;
182
183 switch (getc(infp)) {
184 case OT_EMPTY:
185 return(EMPTY);
186 case OT_FULL:
187 return(getfullnode());
188 case OT_TREE:
189 if ((ot = octalloc()) == EMPTY)
190 octerror(SYSTEM, "out of tree space in gettree");
191 for (i = 0; i < 8; i++)
192 octkid(ot, i) = gettree();
193 return(ot);
194 case EOF:
195 octerror(USER, "truncated octree");
196 default:
197 octerror(USER, "damaged octree");
198 }
199 }
200
201
202 static
203 skiptree() /* skip octree on input */
204 {
205 register int i;
206
207 switch (getc(infp)) {
208 case OT_EMPTY:
209 return;
210 case OT_FULL:
211 for (i = ogetint(objsize)*objsize; i-- > 0; )
212 if (getc(infp) == EOF)
213 octerror(USER, "truncated octree");
214 return;
215 case OT_TREE:
216 for (i = 0; i < 8; i++)
217 skiptree();
218 return;
219 case EOF:
220 octerror(USER, "truncated octree");
221 default:
222 octerror(USER, "damaged octree");
223 }
224 }
225
226
227 static
228 getobj() /* get next object */
229 {
230 char sbuf[MAXSTR];
231 int obj;
232 register int i;
233 register long m;
234 register OBJREC *objp;
235
236 i = ogetint(1);
237 if (i == -1)
238 return(OVOID); /* terminator */
239 if ((obj = newobject()) == OVOID)
240 error(SYSTEM, "out of object space");
241 objp = objptr(obj);
242 if ((objp->otype = otypmap[i]) < 0)
243 octerror(USER, "reference to unknown type");
244 if ((m = ogetint(objsize)) != OVOID) {
245 m += objorig;
246 if ((OBJECT)m != m)
247 octerror(USER, "too many objects");
248 }
249 objp->omod = m;
250 objp->oname = savqstr(ogetstr(sbuf));
251 if (objp->oargs.nsargs = ogetint(2)) {
252 objp->oargs.sarg = (char **)bmalloc
253 (objp->oargs.nsargs*sizeof(char *));
254 if (objp->oargs.sarg == NULL)
255 goto memerr;
256 for (i = 0; i < objp->oargs.nsargs; i++)
257 objp->oargs.sarg[i] = savestr(ogetstr(sbuf));
258 } else
259 objp->oargs.sarg = NULL;
260 #ifdef IARGS
261 if (objp->oargs.niargs = ogetint(2)) {
262 objp->oargs.iarg = (long *)bmalloc
263 (objp->oargs.niargs*sizeof(long));
264 if (objp->oargs.iarg == NULL)
265 goto memerr;
266 for (i = 0; i < objp->oargs.niargs; i++)
267 objp->oargs.iarg[i] = ogetint(4);
268 } else
269 objp->oargs.iarg = NULL;
270 #endif
271 if (objp->oargs.nfargs = ogetint(2)) {
272 objp->oargs.farg = (FLOAT *)bmalloc
273 (objp->oargs.nfargs*sizeof(FLOAT));
274 if (objp->oargs.farg == NULL)
275 goto memerr;
276 for (i = 0; i < objp->oargs.nfargs; i++)
277 objp->oargs.farg[i] = ogetflt();
278 } else
279 objp->oargs.farg = NULL;
280 /* initialize */
281 objp->os = NULL;
282 /* insert */
283 insertobject(obj);
284 return(obj);
285 memerr:
286 error(SYSTEM, "out of memory in getobj");
287 }
288
289
290 static
291 octerror(etyp, msg) /* octree error */
292 int etyp;
293 char *msg;
294 {
295 char msgbuf[128];
296
297 sprintf(msgbuf, "(%s): %s", infn, msg);
298 error(etyp, msgbuf);
299 }
