--- ray/src/common/readoct.c 2003/02/22 02:07:22 2.13
+++ ray/src/common/readoct.c 2003/07/17 09:21:29 2.20
@@ -1,88 +1,35 @@
#ifndef lint
-static const char RCSid[] = "$Id: readoct.c,v 2.13 2003/02/22 02:07:22 greg Exp $";
+static const char RCSid[] = "$Id: readoct.c,v 2.20 2003/07/17 09:21:29 schorsch Exp $";
#endif
* readoct.c - routines to read octree information.
- * The Radiance Software License, Version 1.0
- * Copyright (c) 1990 - 2002 The Regents of the University of California,
- * through Lawrence Berkeley National Laboratory. All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in
- * the documentation and/or other materials provided with the
- * distribution.
- * 3. The end-user documentation included with the redistribution,
- * if any, must include the following acknowledgment:
- * "This product includes Radiance software
- * (http://radsite.lbl.gov/)
- * developed by the Lawrence Berkeley National Laboratory
- * (http://www.lbl.gov/)."
- * Alternately, this acknowledgment may appear in the software itself,
- * if and wherever such third-party acknowledgments normally appear.
- * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
- * and "The Regents of the University of California" must
- * not be used to endorse or promote products derived from this
- * software without prior written permission. For written
- * permission, please contact radiance@radsite.lbl.gov.
- * 5. Products derived from this software may not be called "Radiance",
- * nor may "Radiance" appear in their name, without prior written
- * permission of Lawrence Berkeley National Laboratory.
- * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
- * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
- * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
- * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
- * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
- * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
- * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
- * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
- * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
- * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
- * This software consists of voluntary contributions made by many
- * individuals on behalf of Lawrence Berkeley National Laboratory. For more
- * information on Lawrence Berkeley National Laboratory, please see
+#include "copyright.h"
-#include "standard.h"
+#include
+#include
+#include "standard.h"
+#include "platform.h"
#include "octree.h"
#include "object.h"
#include "otypes.h"
+#include "resolu.h"
-static double ogetflt();
-static long ogetint();
-static char *ogetstr();
-static int nonsurfinset();
-static int getobj(), octerror(), skiptree();
-static OCTREE getfullnode(), gettree();
+static double ogetflt(void);
+static long ogetint(int);
+static char *ogetstr(char *);
+static int nonsurfinset(OBJECT *);
+static void octerror(int etyp, char *msg);
+static void skiptree(void);
+static OCTREE getfullnode(void), gettree(void);
static char *infn; /* input file specification */
static FILE *infp; /* input file stream */
static int objsize; /* size of stored OBJECT's */
static OBJECT objorig; /* zeroeth object */
static OBJECT fnobjects; /* number of objects in this file */
-static short otypmap[NUMOTYPE+8]; /* object type map */
int
@@ -94,7 +41,7 @@ char *ofn[];
char sbuf[512];
int nf;
- register int i;
+ int i;
long m;
if (inpspec == NULL) {
@@ -114,9 +61,7 @@ char *ofn[];
error(SYSTEM, errmsg);
-#ifdef MSDOS
- setmode(fileno(infp), O_BINARY);
-#endif
+ SET_FILE_BINARY(infp);
/* get header */
if (checkheader(infp, OCTFMT, load&IO_INFO ? stdout : (FILE *)NULL) < 0)
octerror(USER, "not an octree");
@@ -156,13 +101,9 @@ char *ofn[];
if (load & IO_SCENE) /* get the scene */
if (nf == 0) {
- for (i = 0; *ogetstr(sbuf); i++)
- if ((otypmap[i] = otype(sbuf)) < 0) {
- sprintf(errmsg, "unknown type \"%s\"", sbuf);
- octerror(WARNING, errmsg);
- while (getobj() != OVOID)
+ /* load binary scene data */
+ readscene(infp, objsize);
} else { /* consistency checks */
/* check object count */
if (nobjects != objorig+fnobjects)
@@ -259,6 +200,7 @@ gettree() /* get a pre-ordered octree */
default:
octerror(USER, "damaged octree");
+ return NULL; /* pro forma return */
@@ -277,8 +219,8 @@ register OBJECT *os;
-static
-skiptree() /* skip octree on input */
+static void
+skiptree(void) /* skip octree on input */
register int i;
@@ -302,70 +244,7 @@ skiptree() /* skip octree on input */
-static
-getobj() /* get next object */
- char sbuf[MAXSTR];
- int obj;
- register int i;
- register long m;
- register OBJREC *objp;
- i = ogetint(1);
- if (i == -1)
- return(OVOID); /* terminator */
- if ((obj = newobject()) == OVOID)
- error(SYSTEM, "out of object space");
- objp = objptr(obj);
- if ((objp->otype = otypmap[i]) < 0)
- octerror(USER, "reference to unknown type");
- if ((m = ogetint(objsize)) != OVOID) {
- m += objorig;
- if ((OBJECT)m != m)
- octerror(USER, "too many objects");
- objp->omod = m;
- objp->oname = savqstr(ogetstr(sbuf));
- if (objp->oargs.nsargs = ogetint(2)) {
- objp->oargs.sarg = (char **)malloc
- (objp->oargs.nsargs*sizeof(char *));
- if (objp->oargs.sarg == NULL)
- goto memerr;
- for (i = 0; i < objp->oargs.nsargs; i++)
- objp->oargs.sarg[i] = savestr(ogetstr(sbuf));
- } else
- objp->oargs.sarg = NULL;
-#ifdef IARGS
- if (objp->oargs.niargs = ogetint(2)) {
- objp->oargs.iarg = (long *)malloc
- (objp->oargs.niargs*sizeof(long));
- if (objp->oargs.iarg == NULL)
- goto memerr;
- for (i = 0; i < objp->oargs.niargs; i++)
- objp->oargs.iarg[i] = ogetint(4);
- } else
- objp->oargs.iarg = NULL;
-#endif
- if (objp->oargs.nfargs = ogetint(2)) {
- objp->oargs.farg = (FLOAT *)malloc
- (objp->oargs.nfargs*sizeof(FLOAT));
- if (objp->oargs.farg == NULL)
- goto memerr;
- for (i = 0; i < objp->oargs.nfargs; i++)
- objp->oargs.farg[i] = ogetflt();
- } else
- objp->oargs.farg = NULL;
- /* initialize */
- objp->os = NULL;
- /* insert */
- insertobject(obj);
- return(obj);
-memerr:
- error(SYSTEM, "out of memory in getobj");
-static
+static void
octerror(etyp, msg) /* octree error */
int etyp;
char *msg;
