--- ray/src/common/readoct.c 1991/08/05 08:58:52 1.13 +++ ray/src/common/readoct.c 2003/10/27 10:19:31 2.24 @@ -1,77 +1,87 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: readoct.c,v 2.24 2003/10/27 10:19:31 schorsch Exp $"; #endif - /* * readoct.c - routines to read octree information. - * - * 7/30/85 */ -#include "standard.h" +#include "copyright.h" -#include "octree.h" +#include +#include +#include "platform.h" +#include "rtprocess.h" +#include "standard.h" +#include "octree.h" #include "object.h" - #include "otypes.h" +#include "resolu.h" -extern double atof(); -static double getflt(); -static long getint(); -static char *getstr(); -static OCTREE getfullnode(), gettree(); +static double ogetflt(void); +static long ogetint(int); +static char *ogetstr(char *); +static int nonsurfinset(OBJECT *); +static void octerror(int etyp, char *msg); +static void skiptree(void); +static OCTREE getfullnode(void), gettree(void); -static char *infn; /* input file name */ +static char *infn; /* input file specification */ static FILE *infp; /* input file stream */ +static int objsize; /* size of stored OBJECT's */ static OBJECT objorig; /* zeroeth object */ -static short otypmap[NUMOTYPE+8]; /* object type map */ +static OBJECT fnobjects; /* number of objects in this file */ int -readoct(fname, load, scene, ofn) /* read in octree from file */ -char *fname; +readoct(inpspec, load, scene, ofn) /* read in octree file or stream */ +char *inpspec; int load; CUBE *scene; char *ofn[]; { - extern int fputs(); char sbuf[512]; int nf; - OBJECT fnobjects; - register int i; + int i; + long m; - if (fname == NULL) { + if (inpspec == NULL) { infn = "standard input"; infp = stdin; + } else if (inpspec[0] == '!') { + infn = inpspec; + if ((infp = popen(inpspec+1, "r")) == NULL) { + sprintf(errmsg, "cannot execute \"%s\"", inpspec); + error(SYSTEM, errmsg); + } } else { - infn = fname; - if ((infp = fopen(fname, "r")) == NULL) { + infn = inpspec; + if ((infp = fopen(inpspec, "r")) == NULL) { sprintf(errmsg, "cannot open octree file \"%s\"", - fname); + inpspec); error(SYSTEM, errmsg); } } + SET_FILE_BINARY(infp); /* get header */ - if (checkheader(infp, OCTFMT, load&IO_INFO ? stdout : NULL) < 0) + if (checkheader(infp, OCTFMT, load&IO_INFO ? stdout : (FILE *)NULL) < 0) octerror(USER, "not an octree"); /* check format */ - if (getint(2) != OCTMAGIC) + if ((objsize = ogetint(2)-OCTMAGIC) <= 0 || + objsize > MAXOBJSIZ || objsize > sizeof(long)) octerror(USER, "incompatible octree format"); /* get boundaries */ if (load & IO_BOUNDS) { for (i = 0; i < 3; i++) - scene->cuorg[i] = atof(getstr(sbuf)); - scene->cusize = atof(getstr(sbuf)); + scene->cuorg[i] = atof(ogetstr(sbuf)); + scene->cusize = atof(ogetstr(sbuf)); } else { for (i = 0; i < 4; i++) - getstr(sbuf); + ogetstr(sbuf); } objorig = nobjects; /* set object offset */ nf = 0; /* get object files */ - while (*getstr(sbuf)) { + while (*ogetstr(sbuf)) { if (load & IO_SCENE) readobj(sbuf); if (load & IO_FILES) @@ -81,103 +91,99 @@ char *ofn[]; if (load & IO_FILES) ofn[nf] = NULL; /* get number of objects */ - fnobjects = getint(sizeof(OBJECT)); + fnobjects = m = ogetint(objsize); + if (fnobjects != m) + octerror(USER, "too many objects"); - if (load & IO_TREE) { - /* get the octree */ + if (load & IO_TREE) /* get the octree */ scene->cutree = gettree(); - /* get the scene */ - if (nf == 0 && load & IO_SCENE) { - for (i = 0; *getstr(sbuf); i++) - if ((otypmap[i] = otype(sbuf)) < 0) { - sprintf(errmsg, "unknown type \"%s\"", - sbuf); - octerror(WARNING, errmsg); - } - while (getobj() != OVOID) - ; - } else if (load & IO_SCENE) { /* consistency checks */ - /* check object count */ - if (nobjects != objorig+fnobjects) - octerror(USER, "bad object count; octree stale?"); - /* check for non-surfaces */ - if (nonsurfinset(objorig, fnobjects)) - octerror(USER, "non-surface in set; octree stale?"); - } + else if (load & IO_SCENE && nf == 0) + skiptree(); + + if (load & IO_SCENE) { /* get the scene */ + if (nf == 0) { + /* load binary scene data */ + readscene(infp, objsize); + + } else { /* consistency checks */ + /* check object count */ + if (nobjects != objorig+fnobjects) + octerror(USER, "bad object count; octree stale?"); + /* check for non-surfaces */ + if (dosets(nonsurfinset)) + octerror(USER, "modifier in tree; octree stale?"); + } } - fclose(infp); + /* close the input */ + if (infn[0] == '!') + pclose(infp); + else + fclose(infp); return(nf); } static char * -getstr(s) /* get null-terminated string */ +ogetstr(s) /* get null-terminated string */ char *s; { - register char *cp; - register int c; + extern char *getstr(); - cp = s; - while ((c = getc(infp)) != EOF) - if ((*cp++ = c) == '\0') - return(s); - - octerror(USER, "truncated octree"); + if (getstr(s, infp) == NULL) + octerror(USER, "truncated octree"); + return(s); } static OCTREE getfullnode() /* get a set, return fullnode */ { - OBJECT set[MAXSET+1]; + OBJECT set[MAXSET+1]; register int i; + register long m; - set[0] = getint(sizeof(OBJECT)); - if (set[0] > MAXSET) + if ((set[0] = ogetint(objsize)) > MAXSET) octerror(USER, "bad set in getfullnode"); - for (i = 1; i <= set[0]; i++) - set[i] = getint(sizeof(OBJECT)) + objorig; + for (i = 1; i <= set[0]; i++) { + m = ogetint(objsize) + objorig; + if ((set[i] = m) != m) + octerror(USER, "too many objects"); + } return(fullnode(set)); } static long -getint(siz) /* get a siz-byte integer */ -register int siz; +ogetint(siz) /* get a siz-byte integer */ +int siz; { - register int c; + extern long getint(); register long r; - if ((c = getc(infp)) == EOF) - goto end_file; - r = 0x80&c ? -1<<8|c : c; /* sign extend */ - while (--siz > 0) { - if ((c = getc(infp)) == EOF) - goto end_file; - r <<= 8; - r |= c; - } + r = getint(siz, infp); + if (feof(infp)) + octerror(USER, "truncated octree"); return(r); -end_file: - octerror(USER, "truncated octree"); } static double -getflt() /* get a floating point number */ +ogetflt() /* get a floating point number */ { - extern double ldexp(); - double d; + extern double getflt(); + double r; - d = (double)getint(4)/0x7fffffff; - return(ldexp(d, (int)getint(1))); + r = getflt(infp); + if (feof(infp)) + octerror(USER, "truncated octree"); + return(r); } static OCTREE gettree() /* get a pre-ordered octree */ { - register OCTREE ot; + register OCTREE ot; register int i; switch (getc(infp)) { @@ -196,69 +202,51 @@ gettree() /* get a pre-ordered octree */ default: octerror(USER, "damaged octree"); } + return EMPTY; /* pro forma return */ } -static -getobj() /* get next object */ +static int +nonsurfinset(os) /* check set for modifier */ +register OBJECT *os; { - char sbuf[MAXSTR]; - int obj; + register OBJECT s; register int i; - register OBJREC *objp; - i = getint(1); - if (i == -1) - return(OVOID); /* terminator */ - if ((obj = newobject()) == OVOID) - error(SYSTEM, "out of object space"); - objp = objptr(obj); - if ((objp->otype = otypmap[i]) < 0) - octerror(USER, "reference to unknown type"); - if ((objp->omod = getint(sizeof(OBJECT))) != OVOID) - objp->omod += objorig; - objp->oname = savqstr(getstr(sbuf)); - if (objp->oargs.nsargs = getint(2)) { - objp->oargs.sarg = (char **)bmalloc - (objp->oargs.nsargs*sizeof(char *)); - if (objp->oargs.sarg == NULL) - goto memerr; - for (i = 0; i < objp->oargs.nsargs; i++) - objp->oargs.sarg[i] = savestr(getstr(sbuf)); - } else - objp->oargs.sarg = NULL; -#ifdef IARGS - if (objp->oargs.niargs = getint(2)) { - objp->oargs.iarg = (long *)bmalloc - (objp->oargs.niargs*sizeof(long)); - if (objp->oargs.iarg == NULL) - goto memerr; - for (i = 0; i < objp->oargs.niargs; i++) - objp->oargs.iarg[i] = getint(4); - } else - objp->oargs.iarg = NULL; -#endif - if (objp->oargs.nfargs = getint(2)) { - objp->oargs.farg = (double *)bmalloc - (objp->oargs.nfargs*sizeof(double)); - if (objp->oargs.farg == NULL) - goto memerr; - for (i = 0; i < objp->oargs.nfargs; i++) - objp->oargs.farg[i] = getflt(); - } else - objp->oargs.farg = NULL; - /* initialize */ - objp->os = NULL; - objp->lastrno = -1; - /* insert */ - insertobject(obj); - return(obj); -memerr: - error(SYSTEM, "out of memory in getobj"); + for (i = *os; i-- > 0; ) + if ((s = *++os) >= objorig && s < objorig+fnobjects && + ismodifier(objptr(s)->otype)) + return(1); + return(0); } -static +static void +skiptree(void) /* skip octree on input */ +{ + register int i; + + switch (getc(infp)) { + case OT_EMPTY: + return; + case OT_FULL: + for (i = ogetint(objsize)*objsize; i-- > 0; ) + if (getc(infp) == EOF) + octerror(USER, "truncated octree"); + return; + case OT_TREE: + for (i = 0; i < 8; i++) + skiptree(); + return; + case EOF: + octerror(USER, "truncated octree"); + default: + octerror(USER, "damaged octree"); + } +} + + +static void octerror(etyp, msg) /* octree error */ int etyp; char *msg;
