root/radiance/ray/src/common/readoct.c
Revision: 2.36
Committed: Wed Apr 23 01:57:04 2025 UTC (3 weeks, 5 days ago) by greg
Changes since 2.35: +8 -12 lines
Error occurred while calculating annotation data.
fix: Functio prototypes and other fixes to reduce compiler warnings
2 static const char RCSid[] = "$Id: readoct.c,v 2.35 2025/04/22 14:51:29 greg Exp $";
5 * readoct.c - routines to read octree information.
6 */
7
8 #include "copyright.h"
9
10 #include <stdio.h>
11 #include <time.h>
12
13 #include "platform.h"
14 #include "paths.h"
15 #include "standard.h"
16 #include "octree.h"
17 #include "object.h"
18 #include "otypes.h"
19 #include "resolu.h"
20
21 static double ogetflt(void);
22 static long ogetint(int);
23 static char *ogetstr(char *);
24 static int nonsurfintree(OCTREE ot);
25 static void octerror(int etyp, char *msg);
26 static void skiptree(void);
27 static OCTREE getfullnode(void), gettree(void);
28
29 static char *infn; /* input file specification */
30 static FILE *infp; /* input file stream */
31 static int objsize; /* size of stored OBJECT's */
32 static OBJECT objorig; /* zeroeth object */
33 static OBJECT fnobjects; /* number of objects in this file */
34
35
36 int
37 readoct( /* read in octree file or stream */
38 char *inpspec,
39 int load,
40 CUBE *scene,
41 char *ofn[]
42 )
43 {
44 time_t oct_t = 0;
45 time_t last_it = 0;
46 char sbuf[512];
47 int nf;
48 int i;
49 long m;
50
51 if (inpspec == NULL) {
52 infn = "standard input";
53 infp = stdin;
54 } else if (inpspec[0] == '!') {
55 infn = inpspec;
56 if ((infp = popen(inpspec+1, "r")) == NULL) {
57 sprintf(errmsg, "cannot execute \"%s\"", inpspec);
58 error(SYSTEM, errmsg);
59 }
60 } else {
61 infn = inpspec;
62 if ((infp = fopen(inpspec, "r")) == NULL) {
63 sprintf(errmsg, "cannot open octree file \"%s\"",
64 inpspec);
65 error(SYSTEM, errmsg);
66 }
67 oct_t = fddate(fileno(infp));
68 }
69 #ifdef getc_unlocked /* avoid stupid semaphores */
70 flockfile(infp);
71 #endif
72 SET_FILE_BINARY(infp);
73 /* get header */
74 if (checkheader(infp, OCTFMT, load&IO_INFO ? stdout : (FILE *)NULL) < 0)
75 octerror(USER, "not an octree");
76 /* check format */
77 if ((objsize = ogetint(2)-OCTMAGIC) <= 0 ||
78 objsize > MAXOBJSIZ || objsize > sizeof(long))
79 octerror(USER, "incompatible octree format");
80 /* get boundaries */
81 if (load & IO_BOUNDS) {
82 for (i = 0; i < 3; i++)
83 scene->cuorg[i] = atof(ogetstr(sbuf));
84 scene->cusize = atof(ogetstr(sbuf));
85 } else {
86 for (i = 0; i < 4; i++)
87 ogetstr(sbuf);
88 }
89 objorig = nobjects; /* set object offset */
90 nf = 0; /* get object files */
91 while (*ogetstr(sbuf)) {
92 if (load & IO_SCENE)
93 readobj(sbuf);
94 if (load & IO_FILES)
95 ofn[nf] = savqstr(sbuf);
96 if (oct_t > last_it) {
97 time_t t = fdate(sbuf);
98 if (t > last_it)
99 last_it = t;
100 }
101 nf++;
102 }
103 if (load & IO_FILES)
104 ofn[nf] = NULL;
105 /* get number of objects */
106 fnobjects = m = ogetint(objsize);
107 if (fnobjects != m)
108 octerror(USER, "too many objects");
109
110 if (load & IO_TREE) /* get the octree */
111 scene->cutree = gettree();
112 else if (load & IO_SCENE && nf == 0)
113 skiptree();
114
115 if (load & IO_SCENE) { /* get the scene */
116 if (nf == 0) {
117 /* load binary scene data */
118 readscene(infp, objsize);
119
120 } else { /* consistency checks */
121 /* check object count */
122 if (nobjects != objorig+fnobjects)
123 octerror(USER, "bad object count; octree stale?");
124 /* check for non-surfaces */
125 if (oct_t <= last_it && nonsurfintree(scene->cutree))
126 octerror(USER, "modifier in tree; octree stale?");
127 }
128 }
129 /* close the input */
130 if (inpspec[0] == '!') {
131 if (pclose(infp) != 0) {
132 sprintf(errmsg, "bad status from \"%s\"", inpspec);
133 error(WARNING, errmsg);
134 }
135 } else if (infp != stdin)
136 fclose(infp);
137 #ifdef getc_unlocked
138 else
139 funlockfile(infp);
140 #endif
141 return(nf);
142 }
143
144
145 static char *
146 ogetstr(char *s) /* get null-terminated string */
147 {
148 if (getstr(s, infp) == NULL)
149 octerror(USER, "truncated octree");
150 return(s);
151 }
152
153
154 static OCTREE
155 getfullnode() /* get a set, return fullnode */
156 {
157 OBJECT set[MAXSET+1];
158 int i;
159 long m;
160
161 if ((set[0] = ogetint(objsize)) > MAXSET)
162 octerror(USER, "bad set in getfullnode");
163 for (i = 1; i <= set[0]; i++) {
164 m = ogetint(objsize) + objorig;
165 if ((set[i] = m) != m)
166 octerror(USER, "too many objects");
167 }
168 return(fullnode(set));
169 }
170
171
172 static long
173 ogetint(int siz) /* get a siz-byte integer */
174 {
175 long r;
176
177 r = getint(siz, infp);
178 if (feof(infp))
179 octerror(USER, "truncated octree");
180 return(r);
181 }
182
183
184 static double
185 ogetflt() /* get a floating point number */
186 {
187 double r;
188
189 r = getflt(infp);
190 if (feof(infp))
191 octerror(USER, "truncated octree");
192 return(r);
193 }
194
195
196 static OCTREE
197 gettree() /* get a pre-ordered octree */
198 {
199 OCTREE ot;
200 int i;
201
202 switch (getc(infp)) {
203 case OT_EMPTY:
204 return(EMPTY);
205 case OT_FULL:
206 return(getfullnode());
207 case OT_TREE:
208 if ((ot = octalloc()) == EMPTY)
209 octerror(SYSTEM, "out of tree space in gettree");
210 for (i = 0; i < 8; i++)
211 octkid(ot, i) = gettree();
212 return(ot);
213 case EOF:
214 octerror(USER, "truncated octree");
215 default:
216 octerror(USER, "damaged octree");
217 }
218 return EMPTY; /* pro forma return */
219 }
220
221
222 static int
223 nonsurfintree(OCTREE ot) /* check tree for modifiers */
224 {
225 OBJECT set[MAXSET+1];
226 int i;
227
228 if (isempty(ot))
229 return(0);
230 if (istree(ot)) {
231 for (i = 0; i < 8; i++)
232 if (nonsurfintree(octkid(ot, i)))
233 return(1);
234 return(0);
235 }
236 objset(set, ot);
237 for (i = set[0]; i > 0; i-- )
238 if (ismodifier(objptr(set[i])->otype))
239 return(1);
240 return(0);
241 }
242
243
244 static void
245 skiptree(void) /* skip octree on input */
246 {
247 int i;
248
249 switch (getc(infp)) {
250 case OT_EMPTY:
251 return;
252 case OT_FULL:
253 for (i = ogetint(objsize)*objsize; i-- > 0; )
254 if (getc(infp) == EOF)
255 octerror(USER, "truncated octree");
256 return;
257 case OT_TREE:
258 for (i = 0; i < 8; i++)
259 skiptree();
260 return;
261 case EOF:
262 octerror(USER, "truncated octree");
263 default:
264 octerror(USER, "damaged octree");
265 }
266 }
267
268
269 static void
270 octerror(int etyp, char *msg) /* octree error */
271 {
272 char msgbuf[128];
273
274 sprintf(msgbuf, "(%s): %s", infn, msg);
275 error(etyp, msgbuf);
276 }
