root/radiance/ray/src/common/readoct.c
Revision: 2.34
Committed: Tue Apr 22 04:45:25 2025 UTC (3 months ago) by greg
Changes since 2.33: +7 -4 lines
fix: Added check to return value of pclose() in several tools
2 static const char RCSid[] = "$Id: readoct.c,v 2.33 2023/06/08 17:39:13 greg Exp $";
5 * readoct.c - routines to read octree information.
6 */
7
8 #include "copyright.h"
9
10 #include <stdio.h>
11 #include <time.h>
12
13 #include "platform.h"
14 #include "paths.h"
15 #include "standard.h"
16 #include "octree.h"
17 #include "object.h"
18 #include "otypes.h"
19 #include "resolu.h"
20
21 static double ogetflt(void);
22 static long ogetint(int);
23 static char *ogetstr(char *);
24 static int nonsurfintree(OCTREE ot);
25 static void octerror(int etyp, char *msg);
26 static void skiptree(void);
27 static OCTREE getfullnode(void), gettree(void);
28
29 static char *infn; /* input file specification */
30 static FILE *infp; /* input file stream */
31 static int objsize; /* size of stored OBJECT's */
32 static OBJECT objorig; /* zeroeth object */
33 static OBJECT fnobjects; /* number of objects in this file */
34
35
36 int
37 readoct( /* read in octree file or stream */
38 char *inpspec,
39 int load,
40 CUBE *scene,
41 char *ofn[]
42 )
43 {
44 time_t oct_t = 0;
45 time_t last_it = 0;
46 char sbuf[512];
47 int nf;
48 int i;
49 long m;
50
51 if (inpspec == NULL) {
52 infn = "standard input";
53 infp = stdin;
54 } else if (inpspec[0] == '!') {
55 infn = inpspec;
56 if ((infp = popen(inpspec+1, "r")) == NULL) {
57 sprintf(errmsg, "cannot execute \"%s\"", inpspec);
58 error(SYSTEM, errmsg);
59 }
60 } else {
61 infn = inpspec;
62 if ((infp = fopen(inpspec, "r")) == NULL) {
63 sprintf(errmsg, "cannot open octree file \"%s\"",
64 inpspec);
65 error(SYSTEM, errmsg);
66 }
67 oct_t = fddate(fileno(infp));
68 }
69 #ifdef getc_unlocked /* avoid stupid semaphores */
70 flockfile(infp);
71 #endif
72 SET_FILE_BINARY(infp);
73 /* get header */
74 if (checkheader(infp, OCTFMT, load&IO_INFO ? stdout : (FILE *)NULL) < 0)
75 octerror(USER, "not an octree");
76 /* check format */
77 if ((objsize = ogetint(2)-OCTMAGIC) <= 0 ||
78 objsize > MAXOBJSIZ || objsize > sizeof(long))
79 octerror(USER, "incompatible octree format");
80 /* get boundaries */
81 if (load & IO_BOUNDS) {
82 for (i = 0; i < 3; i++)
83 scene->cuorg[i] = atof(ogetstr(sbuf));
84 scene->cusize = atof(ogetstr(sbuf));
85 } else {
86 for (i = 0; i < 4; i++)
87 ogetstr(sbuf);
88 }
89 objorig = nobjects; /* set object offset */
90 nf = 0; /* get object files */
91 while (*ogetstr(sbuf)) {
92 if (load & IO_SCENE)
93 readobj(sbuf);
94 if (load & IO_FILES)
95 ofn[nf] = savqstr(sbuf);
96 if (oct_t > last_it) {
97 time_t t = fdate(sbuf);
98 if (t > last_it)
99 last_it = t;
100 }
101 nf++;
102 }
103 if (load & IO_FILES)
104 ofn[nf] = NULL;
105 /* get number of objects */
106 fnobjects = m = ogetint(objsize);
107 if (fnobjects != m)
108 octerror(USER, "too many objects");
109
110 if (load & IO_TREE) /* get the octree */
111 scene->cutree = gettree();
112 else if (load & IO_SCENE && nf == 0)
113 skiptree();
114
115 if (load & IO_SCENE) { /* get the scene */
116 if (nf == 0) {
117 /* load binary scene data */
118 readscene(infp, objsize);
119
120 } else { /* consistency checks */
121 /* check object count */
122 if (nobjects != objorig+fnobjects)
123 octerror(USER, "bad object count; octree stale?");
124 /* check for non-surfaces */
125 if (oct_t <= last_it && nonsurfintree(scene->cutree))
126 octerror(USER, "modifier in tree; octree stale?");
127 }
128 }
129 /* close the input */
130 if (inpspec[0] == '!') {
131 if (pclose(infp) != 0) {
132 sprintf(errmsg, "bad status from \"%s\"", inpspec);
133 error(USER, errmsg);
134 }
135 } else if (infp != stdin)
136 fclose(infp);
137 #ifdef getc_unlocked
138 else
139 funlockfile(infp);
140 #endif
141 return(nf);
142 }
143
144
145 static char *
146 ogetstr(char *s) /* get null-terminated string */
147 {
148 extern char *getstr();
149
150 if (getstr(s, infp) == NULL)
151 octerror(USER, "truncated octree");
152 return(s);
153 }
154
155
156 static OCTREE
157 getfullnode() /* get a set, return fullnode */
158 {
159 OBJECT set[MAXSET+1];
160 register int i;
161 register long m;
162
163 if ((set[0] = ogetint(objsize)) > MAXSET)
164 octerror(USER, "bad set in getfullnode");
165 for (i = 1; i <= set[0]; i++) {
166 m = ogetint(objsize) + objorig;
167 if ((set[i] = m) != m)
168 octerror(USER, "too many objects");
169 }
170 return(fullnode(set));
171 }
172
173
174 static long
175 ogetint(int siz) /* get a siz-byte integer */
176 {
177 extern long getint();
178 register long r;
179
180 r = getint(siz, infp);
181 if (feof(infp))
182 octerror(USER, "truncated octree");
183 return(r);
184 }
185
186
187 static double
188 ogetflt() /* get a floating point number */
189 {
190 extern double getflt();
191 double r;
192
193 r = getflt(infp);
194 if (feof(infp))
195 octerror(USER, "truncated octree");
196 return(r);
197 }
198
199
200 static OCTREE
201 gettree() /* get a pre-ordered octree */
202 {
203 register OCTREE ot;
204 register int i;
205
206 switch (getc(infp)) {
207 case OT_EMPTY:
208 return(EMPTY);
209 case OT_FULL:
210 return(getfullnode());
211 case OT_TREE:
212 if ((ot = octalloc()) == EMPTY)
213 octerror(SYSTEM, "out of tree space in gettree");
214 for (i = 0; i < 8; i++)
215 octkid(ot, i) = gettree();
216 return(ot);
217 case EOF:
218 octerror(USER, "truncated octree");
219 default:
220 octerror(USER, "damaged octree");
221 }
222 return EMPTY; /* pro forma return */
223 }
224
225
226 static int
227 nonsurfintree(OCTREE ot) /* check tree for modifiers */
228 {
229 OBJECT set[MAXSET+1];
230 register int i;
231
232 if (isempty(ot))
233 return(0);
234 if (istree(ot)) {
235 for (i = 0; i < 8; i++)
236 if (nonsurfintree(octkid(ot, i)))
237 return(1);
238 return(0);
239 }
240 objset(set, ot);
241 for (i = set[0]; i > 0; i-- )
242 if (ismodifier(objptr(set[i])->otype))
243 return(1);
244 return(0);
245 }
246
247
248 static void
249 skiptree(void) /* skip octree on input */
250 {
251 register int i;
252
253 switch (getc(infp)) {
254 case OT_EMPTY:
255 return;
256 case OT_FULL:
257 for (i = ogetint(objsize)*objsize; i-- > 0; )
258 if (getc(infp) == EOF)
259 octerror(USER, "truncated octree");
260 return;
261 case OT_TREE:
262 for (i = 0; i < 8; i++)
263 skiptree();
264 return;
265 case EOF:
266 octerror(USER, "truncated octree");
267 default:
268 octerror(USER, "damaged octree");
269 }
270 }
271
272
273 static void
274 octerror(int etyp, char *msg) /* octree error */
275 {
276 char msgbuf[128];
277
278 sprintf(msgbuf, "(%s): %s", infn, msg);
279 error(etyp, msgbuf);
280 }
