root/radiance/ray/src/common/readoct.c
Revision: 2.1
Committed: Tue Nov 12 16:55:01 1991 UTC (33 years, 8 months ago) by greg
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * readoct.c - routines to read octree information.
9 *
10 * 7/30/85
11 */
12
13 #include "standard.h"
14
15 #include "octree.h"
16
17 #include "object.h"
18
19 #include "otypes.h"
20
21 extern double atof();
22 static double getflt();
23 static long getint();
24 static char *getstr();
25 static int getobj(), octerror();
26 static OCTREE getfullnode(), gettree();
27
28 static char *infn; /* input file name */
29 static FILE *infp; /* input file stream */
30 static int objsize; /* size of stored OBJECT's */
31 static OBJECT objorig; /* zeroeth object */
32 static short otypmap[NUMOTYPE+8]; /* object type map */
33
34
35 int
36 readoct(fname, load, scene, ofn) /* read in octree from file */
37 char *fname;
38 int load;
39 CUBE *scene;
40 char *ofn[];
41 {
42 extern int fputs();
43 char sbuf[512];
44 int nf;
45 OBJECT fnobjects;
46 register int i;
47 long m;
48
49 if (fname == NULL) {
50 infn = "standard input";
51 infp = stdin;
52 } else {
53 infn = fname;
54 if ((infp = fopen(fname, "r")) == NULL) {
55 sprintf(errmsg, "cannot open octree file \"%s\"",
56 fname);
57 error(SYSTEM, errmsg);
58 }
59 }
60 /* get header */
61 if (checkheader(infp, OCTFMT, load&IO_INFO ? stdout : NULL) < 0)
62 octerror(USER, "not an octree");
63 /* check format */
64 if ((objsize = getint(2)-OCTMAGIC) <= 0 ||
65 objsize > MAXOBJSIZ || objsize > sizeof(long))
66 octerror(USER, "incompatible octree format");
67 /* get boundaries */
68 if (load & IO_BOUNDS) {
69 for (i = 0; i < 3; i++)
70 scene->cuorg[i] = atof(getstr(sbuf));
71 scene->cusize = atof(getstr(sbuf));
72 } else {
73 for (i = 0; i < 4; i++)
74 getstr(sbuf);
75 }
76 objorig = nobjects; /* set object offset */
77 nf = 0; /* get object files */
78 while (*getstr(sbuf)) {
79 if (load & IO_SCENE)
80 readobj(sbuf);
81 if (load & IO_FILES)
82 ofn[nf] = savqstr(sbuf);
83 nf++;
84 }
85 if (load & IO_FILES)
86 ofn[nf] = NULL;
87 /* get number of objects */
88 fnobjects = m = getint(objsize);
89 if (fnobjects != m)
90 octerror(USER, "too many objects");
91
92 if (load & IO_TREE) {
93 /* get the octree */
94 scene->cutree = gettree();
95 /* get the scene */
96 if (nf == 0 && load & IO_SCENE) {
97 for (i = 0; *getstr(sbuf); i++)
98 if ((otypmap[i] = otype(sbuf)) < 0) {
99 sprintf(errmsg, "unknown type \"%s\"",
100 sbuf);
101 octerror(WARNING, errmsg);
102 }
103 while (getobj() != OVOID)
104 ;
105 } else if (load & IO_SCENE) { /* consistency checks */
106 /* check object count */
107 if (nobjects != objorig+fnobjects)
108 octerror(USER, "bad object count; octree stale?");
109 /* check for non-surfaces */
110 if (nonsurfinset(objorig, fnobjects))
111 octerror(USER, "non-surface in set; octree stale?");
112 }
113 }
114 fclose(infp);
115 return(nf);
116 }
117
118
119 static char *
120 getstr(s) /* get null-terminated string */
121 char *s;
122 {
123 register char *cp;
124 register int c;
125
126 cp = s;
127 while ((c = getc(infp)) != EOF)
128 if ((*cp++ = c) == '\0')
129 return(s);
130
131 octerror(USER, "truncated octree");
132 }
133
134
135 static OCTREE
136 getfullnode() /* get a set, return fullnode */
137 {
138 OBJECT set[MAXSET+1];
139 register int i;
140 register long m;
141
142 if ((set[0] = getint(objsize)) > MAXSET)
143 octerror(USER, "bad set in getfullnode");
144 for (i = 1; i <= set[0]; i++) {
145 m = getint(objsize) + objorig;
146 if ((set[i] = m) != m)
147 octerror(USER, "too many objects");
148 }
149 return(fullnode(set));
150 }
151
152
153 static long
154 getint(siz) /* get a siz-byte integer */
155 register int siz;
156 {
157 register int c;
158 register long r;
159
160 if ((c = getc(infp)) == EOF)
161 goto end_file;
162 r = 0x80&c ? -1<<8|c : c; /* sign extend */
163 while (--siz > 0) {
164 if ((c = getc(infp)) == EOF)
165 goto end_file;
166 r <<= 8;
167 r |= c;
168 }
169 return(r);
170 end_file:
171 octerror(USER, "truncated octree");
172 }
173
174
175 static double
176 getflt() /* get a floating point number */
177 {
178 extern double ldexp();
179 double d;
180
181 d = (double)getint(4)/0x7fffffff;
182 return(ldexp(d, (int)getint(1)));
183 }
184
185
186 static OCTREE
187 gettree() /* get a pre-ordered octree */
188 {
189 register OCTREE ot;
190 register int i;
191
192 switch (getc(infp)) {
193 case OT_EMPTY:
194 return(EMPTY);
195 case OT_FULL:
196 return(getfullnode());
197 case OT_TREE:
198 if ((ot = octalloc()) == EMPTY)
199 octerror(SYSTEM, "out of tree space in gettree");
200 for (i = 0; i < 8; i++)
201 octkid(ot, i) = gettree();
202 return(ot);
203 case EOF:
204 octerror(USER, "truncated octree");
205 default:
206 octerror(USER, "damaged octree");
207 }
208 }
209
210
211 static
212 getobj() /* get next object */
213 {
214 char sbuf[MAXSTR];
215 int obj;
216 register int i;
217 register long m;
218 register OBJREC *objp;
219
220 i = getint(1);
221 if (i == -1)
222 return(OVOID); /* terminator */
223 if ((obj = newobject()) == OVOID)
224 error(SYSTEM, "out of object space");
225 objp = objptr(obj);
226 if ((objp->otype = otypmap[i]) < 0)
227 octerror(USER, "reference to unknown type");
228 if ((m = getint(objsize)) != OVOID) {
229 m += objorig;
230 if ((OBJECT)m != m)
231 octerror(USER, "too many objects");
232 }
233 objp->omod = m;
234 objp->oname = savqstr(getstr(sbuf));
235 if (objp->oargs.nsargs = getint(2)) {
236 objp->oargs.sarg = (char **)bmalloc
237 (objp->oargs.nsargs*sizeof(char *));
238 if (objp->oargs.sarg == NULL)
239 goto memerr;
240 for (i = 0; i < objp->oargs.nsargs; i++)
241 objp->oargs.sarg[i] = savestr(getstr(sbuf));
242 } else
243 objp->oargs.sarg = NULL;
244 #ifdef IARGS
245 if (objp->oargs.niargs = getint(2)) {
246 objp->oargs.iarg = (long *)bmalloc
247 (objp->oargs.niargs*sizeof(long));
248 if (objp->oargs.iarg == NULL)
249 goto memerr;
250 for (i = 0; i < objp->oargs.niargs; i++)
251 objp->oargs.iarg[i] = getint(4);
252 } else
253 objp->oargs.iarg = NULL;
254 #endif
255 if (objp->oargs.nfargs = getint(2)) {
256 objp->oargs.farg = (FLOAT *)bmalloc
257 (objp->oargs.nfargs*sizeof(FLOAT));
258 if (objp->oargs.farg == NULL)
259 goto memerr;
260 for (i = 0; i < objp->oargs.nfargs; i++)
261 objp->oargs.farg[i] = getflt();
262 } else
263 objp->oargs.farg = NULL;
264 /* initialize */
265 objp->os = NULL;
266 objp->lastrno = -1;
267 /* insert */
268 insertobject(obj);
269 return(obj);
270 memerr:
271 error(SYSTEM, "out of memory in getobj");
272 }
273
274
275 static
276 octerror(etyp, msg) /* octree error */
277 int etyp;
278 char *msg;
279 {
280 char msgbuf[128];
281
282 sprintf(msgbuf, "(%s): %s", infn, msg);
283 error(etyp, msgbuf);
284 }
