root/radiance/ray/src/common/readoct.c
Revision: 2.26
Committed: Tue Sep 14 02:53:50 2004 UTC (20 years, 10 months ago) by greg
Changes since 2.25: +2 -1 lines
Added #undef for getc/putc where they were being replaced
2 static const char RCSid[] = "$Id: readoct.c,v 2.25 2004/04/29 14:36:49 greg Exp $";
5 * readoct.c - routines to read octree information.
6 */
7
8 #include "copyright.h"
9
10 #include <stdio.h>
11 #include <time.h>
12
13 #include "platform.h"
14 #include "rtprocess.h"
15 #include "standard.h"
16 #include "octree.h"
17 #include "object.h"
18 #include "otypes.h"
19 #include "resolu.h"
20
21 #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
22 #undef getc
23 #define getc getc_unlocked
24 #endif
25
26 static double ogetflt(void);
27 static long ogetint(int);
28 static char *ogetstr(char *);
29 static int nonsurfinset(OBJECT *);
30 static void octerror(int etyp, char *msg);
31 static void skiptree(void);
32 static OCTREE getfullnode(void), gettree(void);
33
34 static char *infn; /* input file specification */
35 static FILE *infp; /* input file stream */
36 static int objsize; /* size of stored OBJECT's */
37 static OBJECT objorig; /* zeroeth object */
38 static OBJECT fnobjects; /* number of objects in this file */
39
40
41 int
42 readoct(inpspec, load, scene, ofn) /* read in octree file or stream */
43 char *inpspec;
44 int load;
45 CUBE *scene;
46 char *ofn[];
47 {
48 char sbuf[512];
49 int nf;
50 int i;
51 long m;
52
53 if (inpspec == NULL) {
54 infn = "standard input";
55 infp = stdin;
56 } else if (inpspec[0] == '!') {
57 infn = inpspec;
58 if ((infp = popen(inpspec+1, "r")) == NULL) {
59 sprintf(errmsg, "cannot execute \"%s\"", inpspec);
60 error(SYSTEM, errmsg);
61 }
62 } else {
63 infn = inpspec;
64 if ((infp = fopen(inpspec, "r")) == NULL) {
65 sprintf(errmsg, "cannot open octree file \"%s\"",
66 inpspec);
67 error(SYSTEM, errmsg);
68 }
69 }
70 SET_FILE_BINARY(infp);
71 /* get header */
72 if (checkheader(infp, OCTFMT, load&IO_INFO ? stdout : (FILE *)NULL) < 0)
73 octerror(USER, "not an octree");
74 /* check format */
75 if ((objsize = ogetint(2)-OCTMAGIC) <= 0 ||
76 objsize > MAXOBJSIZ || objsize > sizeof(long))
77 octerror(USER, "incompatible octree format");
78 /* get boundaries */
79 if (load & IO_BOUNDS) {
80 for (i = 0; i < 3; i++)
81 scene->cuorg[i] = atof(ogetstr(sbuf));
82 scene->cusize = atof(ogetstr(sbuf));
83 } else {
84 for (i = 0; i < 4; i++)
85 ogetstr(sbuf);
86 }
87 objorig = nobjects; /* set object offset */
88 nf = 0; /* get object files */
89 while (*ogetstr(sbuf)) {
90 if (load & IO_SCENE)
91 readobj(sbuf);
92 if (load & IO_FILES)
93 ofn[nf] = savqstr(sbuf);
94 nf++;
95 }
96 if (load & IO_FILES)
97 ofn[nf] = NULL;
98 /* get number of objects */
99 fnobjects = m = ogetint(objsize);
100 if (fnobjects != m)
101 octerror(USER, "too many objects");
102
103 if (load & IO_TREE) /* get the octree */
104 scene->cutree = gettree();
105 else if (load & IO_SCENE && nf == 0)
106 skiptree();
107
108 if (load & IO_SCENE) { /* get the scene */
109 if (nf == 0) {
110 /* load binary scene data */
111 readscene(infp, objsize);
112
113 } else { /* consistency checks */
114 /* check object count */
115 if (nobjects != objorig+fnobjects)
116 octerror(USER, "bad object count; octree stale?");
117 /* check for non-surfaces */
118 if (dosets(nonsurfinset))
119 octerror(USER, "modifier in tree; octree stale?");
120 }
121 }
122 /* close the input */
123 if (infn[0] == '!')
124 pclose(infp);
125 else
126 fclose(infp);
127 return(nf);
128 }
129
130
131 static char *
132 ogetstr(s) /* get null-terminated string */
133 char *s;
134 {
135 extern char *getstr();
136
137 if (getstr(s, infp) == NULL)
138 octerror(USER, "truncated octree");
139 return(s);
140 }
141
142
143 static OCTREE
144 getfullnode() /* get a set, return fullnode */
145 {
146 OBJECT set[MAXSET+1];
147 register int i;
148 register long m;
149
150 if ((set[0] = ogetint(objsize)) > MAXSET)
151 octerror(USER, "bad set in getfullnode");
152 for (i = 1; i <= set[0]; i++) {
153 m = ogetint(objsize) + objorig;
154 if ((set[i] = m) != m)
155 octerror(USER, "too many objects");
156 }
157 return(fullnode(set));
158 }
159
160
161 static long
162 ogetint(siz) /* get a siz-byte integer */
163 int siz;
164 {
165 extern long getint();
166 register long r;
167
168 r = getint(siz, infp);
169 if (feof(infp))
170 octerror(USER, "truncated octree");
171 return(r);
172 }
173
174
175 static double
176 ogetflt() /* get a floating point number */
177 {
178 extern double getflt();
179 double r;
180
181 r = getflt(infp);
182 if (feof(infp))
183 octerror(USER, "truncated octree");
184 return(r);
185 }
186
187
188 static OCTREE
189 gettree() /* get a pre-ordered octree */
190 {
191 register OCTREE ot;
192 register int i;
193
194 switch (getc(infp)) {
195 case OT_EMPTY:
196 return(EMPTY);
197 case OT_FULL:
198 return(getfullnode());
199 case OT_TREE:
200 if ((ot = octalloc()) == EMPTY)
201 octerror(SYSTEM, "out of tree space in gettree");
202 for (i = 0; i < 8; i++)
203 octkid(ot, i) = gettree();
204 return(ot);
205 case EOF:
206 octerror(USER, "truncated octree");
207 default:
208 octerror(USER, "damaged octree");
209 }
210 return EMPTY; /* pro forma return */
211 }
212
213
214 static int
215 nonsurfinset(os) /* check set for modifier */
216 register OBJECT *os;
217 {
218 register OBJECT s;
219 register int i;
220
221 for (i = *os; i-- > 0; )
222 if ((s = *++os) >= objorig && s < objorig+fnobjects &&
223 ismodifier(objptr(s)->otype))
224 return(1);
225 return(0);
226 }
227
228
229 static void
230 skiptree(void) /* skip octree on input */
231 {
232 register int i;
233
234 switch (getc(infp)) {
235 case OT_EMPTY:
236 return;
237 case OT_FULL:
238 for (i = ogetint(objsize)*objsize; i-- > 0; )
239 if (getc(infp) == EOF)
240 octerror(USER, "truncated octree");
241 return;
242 case OT_TREE:
243 for (i = 0; i < 8; i++)
244 skiptree();
245 return;
246 case EOF:
247 octerror(USER, "truncated octree");
248 default:
249 octerror(USER, "damaged octree");
250 }
251 }
252
253
254 static void
255 octerror(etyp, msg) /* octree error */
256 int etyp;
257 char *msg;
258 {
259 char msgbuf[128];
260
261 sprintf(msgbuf, "(%s): %s", infn, msg);
262 error(etyp, msgbuf);
263 }
