root/radiance/ray/src/common/readoct.c
Revision: 1.1
Committed: Thu Feb 2 10:34:40 1989 UTC (36 years, 6 months ago) by greg
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * readoct.c - routines to read octree information.
9 *
10 * 7/30/85
11 */
12
13 #include "standard.h"
14
15 #include "octree.h"
16
17 #include "object.h"
18
19 #include "otypes.h"
20
21 double atof();
22 double getflt();
23 long getint();
24 char *getstr();
25 OCTREE getfullnode(), gettree();
26
27 static char *infn; /* input file name */
28 static FILE *infp; /* input file stream */
29 static OBJECT objorig; /* zeroeth object */
30 static short otypmap[NUMOTYPE+8]; /* object type map */
31
32
33 int
34 readoct(fname, load, scene, ofn) /* read in octree from file */
35 char *fname;
36 int load;
37 CUBE *scene;
38 char *ofn[];
39 {
40 char sbuf[128];
41 int nf;
42 register int i;
43
44 if (fname == NULL) {
45 infn = "standard input";
46 infp = stdin;
47 } else {
48 infn = fname;
49 if ((infp = fopen(fname, "r")) == NULL) {
50 sprintf(errmsg, "cannot open octree file \"%s\"",
51 fname);
52 error(SYSTEM, errmsg);
53 }
54 }
55 /* get header */
56 if (load & IO_INFO)
57 copyheader(infp, stdout);
58 else
59 getheader(infp, NULL);
60 /* check format */
61 if (getint(2) != OCTMAGIC)
62 octerror(USER, "bad octree");
63 /* get boundaries */
64 if (load & IO_BOUNDS) {
65 for (i = 0; i < 3; i++)
66 scene->cuorg[i] = atof(getstr(sbuf));
67 scene->cusize = atof(getstr(sbuf));
68 } else {
69 for (i = 0; i < 4; i++)
70 getstr(sbuf);
71 }
72 objorig = nobjects; /* set object offset */
73 nf = 0; /* get object files */
74 while (*getstr(sbuf)) {
75 if (load & IO_SCENE)
76 readobj(sbuf);
77 if (load & IO_FILES)
78 ofn[nf] = savqstr(sbuf);
79 nf++;
80 }
81 if (load & IO_FILES)
82 ofn[nf] = NULL;
83
84 if (load & IO_TREE) {
85 /* get the octree */
86 scene->cutree = gettree();
87 /* get the scene */
88 if (nf == 0 && load & IO_SCENE) {
89 for (i = 0; *getstr(sbuf); i++)
90 if ((otypmap[i] = otype(sbuf)) < 0) {
91 sprintf(errmsg, "unknown type \"%s\"",
92 sbuf);
93 octerror(WARNING, errmsg);
94 }
95 while (getobj() != OVOID)
96 ;
97 }
98 }
99 fclose(infp);
100 return(nf);
101 }
102
103
104 static char *
105 getstr(s) /* get null-terminated string */
106 char *s;
107 {
108 register char *cp;
109 register int c;
110
111 cp = s;
112 while ((c = getc(infp)) != EOF)
113 if ((*cp++ = c) == '\0')
114 return(s);
115
116 octerror(USER, "truncated octree");
117 }
118
119
120 static OCTREE
121 getfullnode() /* get a set, return fullnode */
122 {
123 OBJECT set[MAXSET+1];
124 register int i;
125
126 set[0] = getint(sizeof(OBJECT));
127 if (set[0] > MAXSET)
128 octerror(USER, "bad set in getfullnode");
129 for (i = 1; i <= set[0]; i++)
130 set[i] = getint(sizeof(OBJECT)) + objorig;
131 return(fullnode(set));
132 }
133
134
135 static long
136 getint(siz) /* get a siz-byte positive integer */
137 register int siz;
138 {
139 register int c;
140 register long r = 0L;
141
142 while (siz--) {
143 if ((c = getc(infp)) == EOF)
144 octerror(USER, "truncated octree");
145 r <<= 8;
146 r |= c;
147 }
148 return(r);
149 }
150
151
152 static double
153 getflt() /* get a floating point number */
154 {
155 extern double ldexp();
156 double d;
157
158 d = (double)getint(sizeof(long))/0x7fffffff;
159 return(ldexp(d, (char)getint(1))); /* sign extend */
160 }
161
162
163 static OCTREE
164 gettree() /* get a pre-ordered octree */
165 {
166 register OCTREE ot;
167 register int i;
168
169 switch (getc(infp)) {
170 case OT_EMPTY:
171 return(EMPTY);
172 case OT_FULL:
173 return(getfullnode());
174 case OT_TREE:
175 if ((ot = octalloc()) == EMPTY)
176 octerror(SYSTEM, "out of tree space in gettree");
177 for (i = 0; i < 8; i++)
178 octkid(ot, i) = gettree();
179 return(ot);
180 case EOF:
181 octerror(USER, "truncated octree");
182 default:
183 octerror(USER, "damaged octree");
184 }
185 }
186
187
188 static
189 getobj() /* get next object */
190 {
191 char sbuf[MAXSTR];
192 int obj;
193 register int i;
194 register OBJREC *objp;
195
196 i = (char)getint(1); /* sign extend */
197 if (i < 0)
198 return(OVOID); /* terminator */
199 if ((obj = newobject()) == OVOID)
200 error(SYSTEM, "out of object space");
201 objp = objptr(obj);
202 if ((objp->otype = otypmap[i]) < 0)
203 octerror(USER, "reference to unknown type");
204 if ((objp->omod = getint(sizeof(OBJECT))) != OVOID)
205 objp->omod += objorig;
206 objp->oname = savqstr(getstr(sbuf));
207 if (objp->oargs.nsargs = getint(2)) {
208 objp->oargs.sarg = (char **)bmalloc
209 (objp->oargs.nsargs*sizeof(char *));
210 if (objp->oargs.sarg == NULL)
211 goto memerr;
212 for (i = 0; i < objp->oargs.nsargs; i++)
213 objp->oargs.sarg[i] = savestr(getstr(sbuf));
214 } else
215 objp->oargs.sarg = NULL;
216 #ifdef IARGS
217 if (objp->oargs.niargs = getint(2)) {
218 objp->oargs.iarg = (long *)bmalloc
219 (objp->oargs.niargs*sizeof(long));
220 if (objp->oargs.iarg == NULL)
221 goto memerr;
222 for (i = 0; i < objp->oargs.niargs; i++)
223 objp->oargs.iarg[i] = getint(sizeof(long));
224 } else
225 objp->oargs.iarg = NULL;
226 #endif
227 if (objp->oargs.nfargs = getint(2)) {
228 objp->oargs.farg = (double *)bmalloc
229 (objp->oargs.nfargs*sizeof(double));
230 if (objp->oargs.farg == NULL)
231 goto memerr;
232 for (i = 0; i < objp->oargs.nfargs; i++)
233 objp->oargs.farg[i] = getflt();
234 } else
235 objp->oargs.farg = NULL;
236 /* initialize */
237 objp->os = NULL;
238 objp->lastrno = -1;
239 /* insert */
240 insertobject(obj);
241 return(obj);
242 memerr:
243 error(SYSTEM, "out of memory in getobj");
244 }
245
246
247 static
248 octerror(etyp, msg) /* octree error */
249 int etyp;
250 char *msg;
251 {
252 char msgbuf[128];
253
254 sprintf(msgbuf, "(%s): %s", infn, msg);
255 error(etyp, msgbuf);
256 }
