root/radiance/ray/src/common/readoct.c
Revision: 2.33
Committed: Thu Jun 8 17:39:13 2023 UTC (23 months ago) by greg
Changes since 2.32: +10 -2 lines
perf: Avoid calling nonsurfintree() when octree newer than input files
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.33 static const char RCSid[] = "$Id: readoct.c,v 2.32 2023/02/07 20:28:16 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * readoct.c - routines to read octree information.
6 greg 2.13 */
7
8 greg 2.14 #include "copyright.h"
9 greg 1.1
10 schorsch 2.17 #include <stdio.h>
11 greg 2.19 #include <time.h>
12 schorsch 2.17
13 greg 2.23 #include "platform.h"
14 greg 2.29 #include "paths.h"
15 greg 1.1 #include "standard.h"
16     #include "octree.h"
17     #include "object.h"
18     #include "otypes.h"
19 schorsch 2.17 #include "resolu.h"
20 greg 1.1
21 schorsch 2.20 static double ogetflt(void);
22     static long ogetint(int);
23     static char *ogetstr(char *);
24 greg 2.27 static int nonsurfintree(OCTREE ot);
25 schorsch 2.17 static void octerror(int etyp, char *msg);
26     static void skiptree(void);
27 schorsch 2.20 static OCTREE getfullnode(void), gettree(void);
28 greg 1.1
29 greg 2.13 static char *infn; /* input file specification */
30 greg 1.1 static FILE *infp; /* input file stream */
31 greg 1.14 static int objsize; /* size of stored OBJECT's */
32 greg 1.1 static OBJECT objorig; /* zeroeth object */
33 greg 2.12 static OBJECT fnobjects; /* number of objects in this file */
34 greg 1.1
35
36     int
37 greg 2.27 readoct( /* read in octree file or stream */
38     char *inpspec,
39     int load,
40     CUBE *scene,
41     char *ofn[]
42     )
43 greg 1.1 {
44 greg 2.33 time_t oct_t = 0;
45     time_t last_it = 0;
46 greg 1.11 char sbuf[512];
47 greg 1.1 int nf;
48 greg 2.15 int i;
49 greg 1.15 long m;
50 greg 1.1
51 greg 2.13 if (inpspec == NULL) {
52 greg 1.1 infn = "standard input";
53     infp = stdin;
54 greg 2.13 } else if (inpspec[0] == '!') {
55     infn = inpspec;
56     if ((infp = popen(inpspec+1, "r")) == NULL) {
57     sprintf(errmsg, "cannot execute \"%s\"", inpspec);
58     error(SYSTEM, errmsg);
59     }
60 greg 1.1 } else {
61 greg 2.13 infn = inpspec;
62     if ((infp = fopen(inpspec, "r")) == NULL) {
63 greg 1.1 sprintf(errmsg, "cannot open octree file \"%s\"",
64 greg 2.13 inpspec);
65 greg 1.1 error(SYSTEM, errmsg);
66     }
67 greg 2.33 oct_t = fddate(fileno(infp));
68 greg 1.1 }
69 greg 2.32 #ifdef getc_unlocked /* avoid stupid semaphores */
70     flockfile(infp);
71     #endif
72 schorsch 2.16 SET_FILE_BINARY(infp);
73 greg 1.1 /* get header */
74 greg 2.11 if (checkheader(infp, OCTFMT, load&IO_INFO ? stdout : (FILE *)NULL) < 0)
75 greg 1.12 octerror(USER, "not an octree");
76 greg 1.1 /* check format */
77 greg 2.4 if ((objsize = ogetint(2)-OCTMAGIC) <= 0 ||
78 greg 1.14 objsize > MAXOBJSIZ || objsize > sizeof(long))
79 greg 1.12 octerror(USER, "incompatible octree format");
80 greg 1.1 /* get boundaries */
81     if (load & IO_BOUNDS) {
82     for (i = 0; i < 3; i++)
83 greg 2.4 scene->cuorg[i] = atof(ogetstr(sbuf));
84     scene->cusize = atof(ogetstr(sbuf));
85 greg 1.1 } else {
86     for (i = 0; i < 4; i++)
87 greg 2.4 ogetstr(sbuf);
88 greg 1.1 }
89     objorig = nobjects; /* set object offset */
90     nf = 0; /* get object files */
91 greg 2.4 while (*ogetstr(sbuf)) {
92 greg 1.1 if (load & IO_SCENE)
93     readobj(sbuf);
94     if (load & IO_FILES)
95     ofn[nf] = savqstr(sbuf);
96 greg 2.33 if (oct_t > last_it) {
97     time_t t = fdate(sbuf);
98     if (t > last_it)
99     last_it = t;
100     }
101 greg 1.1 nf++;
102     }
103     if (load & IO_FILES)
104     ofn[nf] = NULL;
105 greg 1.8 /* get number of objects */
106 greg 2.4 fnobjects = m = ogetint(objsize);
107 greg 1.15 if (fnobjects != m)
108     octerror(USER, "too many objects");
109 greg 1.1
110 greg 2.13 if (load & IO_TREE) /* get the octree */
111 greg 1.1 scene->cutree = gettree();
112 greg 2.5 else if (load & IO_SCENE && nf == 0)
113     skiptree();
114
115 schorsch 2.21 if (load & IO_SCENE) { /* get the scene */
116 greg 2.5 if (nf == 0) {
117 greg 2.15 /* load binary scene data */
118     readscene(infp, objsize);
119
120 greg 2.5 } else { /* consistency checks */
121     /* check object count */
122     if (nobjects != objorig+fnobjects)
123     octerror(USER, "bad object count; octree stale?");
124     /* check for non-surfaces */
125 greg 2.33 if (oct_t <= last_it && nonsurfintree(scene->cutree))
126 greg 2.5 octerror(USER, "modifier in tree; octree stale?");
127     }
128 schorsch 2.21 }
129 greg 2.13 /* close the input */
130     if (infn[0] == '!')
131     pclose(infp);
132 greg 2.31 else if (infp != stdin)
133 greg 2.13 fclose(infp);
134 greg 2.32 #ifdef getc_unlocked
135     else
136     funlockfile(infp);
137     #endif
138 greg 1.1 return(nf);
139     }
140
141
142     static char *
143 greg 2.27 ogetstr(char *s) /* get null-terminated string */
144 greg 1.1 {
145 greg 2.4 extern char *getstr();
146 greg 1.1
147 greg 2.4 if (getstr(s, infp) == NULL)
148     octerror(USER, "truncated octree");
149     return(s);
150 greg 1.1 }
151
152
153     static OCTREE
154     getfullnode() /* get a set, return fullnode */
155     {
156 greg 2.7 OBJECT set[MAXSET+1];
157 greg 1.1 register int i;
158 greg 1.14 register long m;
159 greg 1.1
160 greg 2.4 if ((set[0] = ogetint(objsize)) > MAXSET)
161 greg 1.1 octerror(USER, "bad set in getfullnode");
162 greg 1.14 for (i = 1; i <= set[0]; i++) {
163 greg 2.4 m = ogetint(objsize) + objorig;
164 greg 1.15 if ((set[i] = m) != m)
165 greg 1.14 octerror(USER, "too many objects");
166     }
167 greg 1.1 return(fullnode(set));
168     }
169
170
171     static long
172 greg 2.27 ogetint(int siz) /* get a siz-byte integer */
173 greg 1.1 {
174 greg 2.4 extern long getint();
175 greg 1.3 register long r;
176 greg 1.1
177 greg 2.4 r = getint(siz, infp);
178     if (feof(infp))
179     octerror(USER, "truncated octree");
180 greg 1.1 return(r);
181     }
182
183
184     static double
185 greg 2.4 ogetflt() /* get a floating point number */
186 greg 1.1 {
187 greg 2.4 extern double getflt();
188 greg 2.7 double r;
189 greg 1.1
190 greg 2.4 r = getflt(infp);
191     if (feof(infp))
192     octerror(USER, "truncated octree");
193     return(r);
194 greg 1.1 }
195
196
197     static OCTREE
198     gettree() /* get a pre-ordered octree */
199     {
200 greg 2.7 register OCTREE ot;
201 greg 1.1 register int i;
202
203     switch (getc(infp)) {
204     case OT_EMPTY:
205     return(EMPTY);
206     case OT_FULL:
207     return(getfullnode());
208     case OT_TREE:
209     if ((ot = octalloc()) == EMPTY)
210     octerror(SYSTEM, "out of tree space in gettree");
211     for (i = 0; i < 8; i++)
212     octkid(ot, i) = gettree();
213     return(ot);
214 greg 2.5 case EOF:
215     octerror(USER, "truncated octree");
216     default:
217     octerror(USER, "damaged octree");
218     }
219 greg 2.22 return EMPTY; /* pro forma return */
220 greg 2.12 }
221
222
223     static int
224 greg 2.27 nonsurfintree(OCTREE ot) /* check tree for modifiers */
225 greg 2.12 {
226 greg 2.27 OBJECT set[MAXSET+1];
227 greg 2.12 register int i;
228
229 greg 2.27 if (isempty(ot))
230     return(0);
231     if (istree(ot)) {
232     for (i = 0; i < 8; i++)
233     if (nonsurfintree(octkid(ot, i)))
234     return(1);
235     return(0);
236     }
237     objset(set, ot);
238 greg 2.28 for (i = set[0]; i > 0; i-- )
239 greg 2.27 if (ismodifier(objptr(set[i])->otype))
240 greg 2.12 return(1);
241     return(0);
242 greg 2.5 }
243
244
245 schorsch 2.17 static void
246     skiptree(void) /* skip octree on input */
247 greg 2.5 {
248     register int i;
249
250     switch (getc(infp)) {
251     case OT_EMPTY:
252     return;
253     case OT_FULL:
254 greg 2.6 for (i = ogetint(objsize)*objsize; i-- > 0; )
255     if (getc(infp) == EOF)
256     octerror(USER, "truncated octree");
257 greg 2.5 return;
258     case OT_TREE:
259     for (i = 0; i < 8; i++)
260     skiptree();
261     return;
262 greg 1.1 case EOF:
263     octerror(USER, "truncated octree");
264     default:
265     octerror(USER, "damaged octree");
266     }
267     }
268
269
270 schorsch 2.17 static void
271 greg 2.27 octerror(int etyp, char *msg) /* octree error */
272 greg 1.1 {
273     char msgbuf[128];
274
275     sprintf(msgbuf, "(%s): %s", infn, msg);
276     error(etyp, msgbuf);
277     }
