root/radiance/ray/src/common/readobj.c
Tue Jun 24 21:04:16 2025 UTC (5 weeks, 6 days ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.30: +6 -6 lines
Diff to previous 2.30 , to selected 1.4
perf: Turned off OBJMEMOPT by default as it seemed to do little in practice
Mon Jun 23 19:56:47 2025 UTC (6 weeks ago) by greg
Changes since 2.29: +107 -7 lines
Diff to previous 2.29 , to selected 1.4
perf: Consolidate object block memory to reduce malloc() fragmentation/overhead
Sat Jun 7 05:09:45 2025 UTC (8 weeks, 2 days ago) by greg
Changes since 2.28: +1 -2 lines
Diff to previous 2.28 , to selected 1.4
Tue Apr 22 14:51:29 2025 UTC (3 months, 1 week ago) by greg
Diff to previous 2.27 , to selected 1.4
fix: Changed some errors to warnings for pclose()
Tue Apr 22 04:45:25 2025 UTC (3 months, 1 week ago) by greg
Changes since 2.26: +7 -4 lines
Diff to previous 2.26 , to selected 1.4
fix: Added check to return value of pclose() in several tools
Sat Dec 7 02:05:30 2024 UTC (7 months, 3 weeks ago) by greg
Changes since 2.25: +11 -7 lines
Diff to previous 2.25 , to selected 1.4
perf: Skip pointless pass-through aliases during scene file load
Tue Feb 7 20:28:16 2023 UTC (2 years, 5 months ago) by greg
Changes since 2.24: +8 -1 lines
Diff to previous 2.24 , to selected 1.4
perf: added calls to flockfile()/funlockfile() for more efficient reading
Sat Oct 17 16:39:23 2020 UTC (4 years, 9 months ago) by greg
Changes since 2.23: +4 -3 lines
Diff to previous 2.23 , to selected 1.4
fix: freeing *some* objects now preserves valid modifier lookups
Sat May 4 00:36:58 2019 UTC (6 years, 3 months ago) by greg
Diff to previous 2.22 , to selected 1.4
Eliminated cases where stdin was being closed
Sat Apr 8 03:56:44 2017 UTC (8 years, 3 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.21: +19 -15 lines
Diff to previous 2.21 , to selected 1.4
ANSIficatation
Tue Feb 2 18:02:32 2016 UTC (9 years, 6 months ago) by greg
Diff to previous 2.20 , to selected 1.4
Tue Mar 30 12:42:33 2010 UTC (15 years, 4 months ago) by greg
Changes since 2.19: +11 -1 lines
Diff to previous 2.19 , to selected 1.4
Added check against tab in modifier or identifier, which breaks rtrace
Fri Jul 2 16:45:32 2004 UTC (21 years, 1 month ago) by greg
Diff to previous 2.18 , to selected 1.4
Increased buffer size for long commands/comments in Radiance scenes
Mon Oct 27 10:19:31 2003 UTC (21 years, 9 months ago) by schorsch
Diff to previous 2.17 , to selected 1.4
Wed Oct 22 02:06:34 2003 UTC (21 years, 9 months ago) by greg
Diff to previous 2.16 , to selected 1.4
Mon Jun 30 14:59:11 2003 UTC (22 years, 1 month ago) by schorsch
Diff to previous 2.15 , to selected 1.4
Fri Jun 20 00:25:49 2003 UTC (22 years, 1 month ago) by greg
Diff to previous 2.14 , to selected 1.4
Sun Jun 8 12:03:09 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 2.13: +3 -5 lines
Diff to previous 2.13 , to selected 1.4
Sat Jun 7 12:50:20 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 2.12: +8 -4 lines
Diff to previous 2.12 , to selected 1.4
Tue May 13 17:58:32 2003 UTC (22 years, 2 months ago) by greg
Diff to previous 2.11 , to selected 1.4
Tue Mar 11 19:29:04 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.10: +24 -10 lines
Diff to previous 2.10 , to selected 1.4
Mon Mar 10 17:13:29 2003 UTC (22 years, 5 months ago) by greg
Diff to previous 2.9 , to selected 1.4
Tue Feb 25 02:47:21 2003 UTC (22 years, 5 months ago) by greg
Diff to previous 2.8 , to selected 1.4
Sat Feb 22 02:07:22 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.7: +96 -10 lines
Diff to previous 2.7 , to selected 1.4
Thu Nov 5 16:51:26 1998 UTC (26 years, 9 months ago) by gwlarson
Diff to previous 2.6 , to selected 1.4
fixed problem with new object block sizing
Mon Aug 24 16:42:46 1998 UTC (26 years, 11 months ago) by gwlarson
Diff to previous 2.5 , to selected 1.4
changed object block size and increased object limit to 32 million
Thu Jul 18 17:58:01 1996 UTC (29 years ago) by greg
Diff to previous 2.4 , to selected 1.4
increased buffer size for in-line commands from 512 to 1024
Sat Jan 1 09:18:47 1994 UTC (31 years, 7 months ago) by greg
Changes since 2.3: +18 -12 lines
Diff to previous 2.3 , to selected 1.4
added warning about empty input
Fri Jun 4 15:08:20 1993 UTC (32 years, 2 months ago) by greg
Diff to previous 2.2 , to selected 1.4
removed fgets() declaration
Mon Jan 25 12:41:24 1993 UTC (32 years, 6 months ago) by greg
Diff to previous 2.1 , to selected 1.4
removed lastrno from object structure
Tue Nov 12 16:55:11 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.7 , to selected 1.4
Mon Jul 22 11:48:04 1991 UTC (34 years ago) by greg
Changes since 1.6: +10 -4 lines
Diff to previous 1.6 , to selected 1.4
eliminated calls to scanf()
Fri Jul 19 09:25:43 1991 UTC (34 years ago) by greg
Changes since 1.5: +5 -55 lines
Diff to previous 1.5 , to selected 1.4
added separate readfargs() and freefargs() routines
Tue Sep 18 09:53:35 1990 UTC (34 years, 10 months ago) by greg
Diff to previous 1.4
changed bmalloc() to call sbrk() since malloc() allocated
16K when asked for less than 8K and that's what octalloc() used before
Revision 1.4 - (view) (download) (annotate) - [selected]
Thu Sep 6 23:32:43 1990 UTC (34 years, 11 months ago) by greg
Diff to previous 1.3
added consistency checks to detect stale octrees
Thu Jan 18 23:58:57 1990 UTC (35 years, 6 months ago) by greg
Diff to previous 1.2 , to selected 1.4
Wed Oct 4 16:32:04 1989 UTC (35 years, 10 months ago) by greg
Changes since 1.1: +3 -6 lines
Diff to previous 1.1 , to selected 1.4
Added multi-line commands.
Thu Feb 2 10:34:39 1989 UTC (36 years, 6 months ago) by greg
Diff to selected 1.4
