root/radiance/ray/src/common/readobj.c
Sat May 4 00:36:58 2019 UTC (6 years ago) by greg
Diff to previous 2.22
Eliminated cases where stdin was being closed
Sat Apr 8 03:56:44 2017 UTC (8 years, 1 month ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.21: +19 -15 lines
Diff to previous 2.21
ANSIficatation
Tue Feb 2 18:02:32 2016 UTC (9 years, 3 months ago) by greg
Diff to previous 2.20
Tue Mar 30 12:42:33 2010 UTC (15 years, 2 months ago) by greg
Changes since 2.19: +11 -1 lines
Diff to previous 2.19
Added check against tab in modifier or identifier, which breaks rtrace
Fri Jul 2 16:45:32 2004 UTC (20 years, 11 months ago) by greg
Diff to previous 2.18
Increased buffer size for long commands/comments in Radiance scenes
Mon Oct 27 10:19:31 2003 UTC (21 years, 7 months ago) by schorsch
Diff to previous 2.17
Wed Oct 22 02:06:34 2003 UTC (21 years, 7 months ago) by greg
Diff to previous 2.16
Mon Jun 30 14:59:11 2003 UTC (21 years, 11 months ago) by schorsch
Diff to previous 2.15
Fri Jun 20 00:25:49 2003 UTC (21 years, 11 months ago) by greg
Diff to previous 2.14
Sun Jun 8 12:03:09 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.13: +3 -5 lines
Diff to previous 2.13
Sat Jun 7 12:50:20 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.12: +8 -4 lines
Diff to previous 2.12
Tue May 13 17:58:32 2003 UTC (22 years ago) by greg
Tue Mar 11 19:29:04 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.10: +24 -10 lines
Mon Mar 10 17:13:29 2003 UTC (22 years, 2 months ago) by greg
Tue Feb 25 02:47:21 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.7: +96 -10 lines
Thu Nov 5 16:51:26 1998 UTC (26 years, 7 months ago) by gwlarson
fixed problem with new object block sizing
Mon Aug 24 16:42:46 1998 UTC (26 years, 9 months ago) by gwlarson
changed object block size and increased object limit to 32 million
Thu Jul 18 17:58:01 1996 UTC (28 years, 10 months ago) by greg
increased buffer size for in-line commands from 512 to 1024
Sat Jan 1 09:18:47 1994 UTC (31 years, 5 months ago) by greg
Changes since 2.3: +18 -12 lines
added warning about empty input
Fri Jun 4 15:08:20 1993 UTC (32 years ago) by greg
removed fgets() declaration
Mon Jan 25 12:41:24 1993 UTC (32 years, 4 months ago) by greg
removed lastrno from object structure
Tue Nov 12 16:55:11 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 1.7
Mon Jul 22 11:48:04 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.6: +10 -4 lines
Diff to previous 1.6
eliminated calls to scanf()
Fri Jul 19 09:25:43 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.5: +5 -55 lines
Diff to previous 1.5
added separate readfargs() and freefargs() routines
Tue Sep 18 09:53:35 1990 UTC (34 years, 8 months ago) by greg
Diff to previous 1.4
changed bmalloc() to call sbrk() since malloc() allocated
16K when asked for less than 8K and that's what octalloc() used before
Thu Sep 6 23:32:43 1990 UTC (34 years, 9 months ago) by greg
Diff to previous 1.3
added consistency checks to detect stale octrees
Thu Jan 18 23:58:57 1990 UTC (35 years, 4 months ago) by greg
Diff to previous 1.2
Wed Oct 4 16:32:04 1989 UTC (35 years, 8 months ago) by greg
Changes since 1.1: +3 -6 lines
Diff to previous 1.1
Added multi-line commands.
Thu Feb 2 10:34:39 1989 UTC (36 years, 4 months ago) by greg
