ANSIficatation
Added check against tab in modifier or identifier, which breaks rtrace
Increased buffer size for long commands/comments in Radiance scenes
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
fixed problem with new object block sizing
changed object block size and increased object limit to 32 million
increased buffer size for in-line commands from 512 to 1024
added warning about empty input
removed fgets() declaration
removed lastrno from object structure
eliminated calls to scanf()
added separate readfargs() and freefargs() routines
changed bmalloc() to call sbrk() since malloc() allocated 16K when asked for less than 8K and that's what octalloc() used before
added consistency checks to detect stale octrees
Added multi-line commands.
