root/radiance/ray/src/common/readobj.c
Tue Mar 30 12:42:33 2010 UTC (14 years, 2 months ago) by greg
Changes since 2.19: +11 -1 lines
Diff to previous 2.19 , to selected 2.13
Added check against tab in modifier or identifier, which breaks rtrace
Fri Jul 2 16:45:32 2004 UTC (19 years, 11 months ago) by greg
Diff to previous 2.18 , to selected 2.13
Increased buffer size for long commands/comments in Radiance scenes
Mon Oct 27 10:19:31 2003 UTC (20 years, 7 months ago) by schorsch
Diff to previous 2.17 , to selected 2.13
Wed Oct 22 02:06:34 2003 UTC (20 years, 8 months ago) by greg
Diff to previous 2.16 , to selected 2.13
Diff to previous 2.15 , to selected 2.13
Fri Jun 20 00:25:49 2003 UTC (21 years ago) by greg
Sun Jun 8 12:03:09 2003 UTC (21 years ago) by schorsch
Changes since 2.13: +3 -5 lines
Diff to previous 2.13
Revision 2.13 - (view) (download) (annotate) - [selected]
Sat Jun 7 12:50:20 2003 UTC (21 years ago) by schorsch
Changes since 2.12: +8 -4 lines
Diff to previous 2.12
Tue May 13 17:58:32 2003 UTC (21 years, 1 month ago) by greg
Tue Mar 11 19:29:04 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.10: +24 -10 lines
Mon Mar 10 17:13:29 2003 UTC (21 years, 3 months ago) by greg
Sat Feb 22 02:07:22 2003 UTC (21 years, 4 months ago) by greg
Changes since 2.7: +96 -10 lines
Thu Nov 5 16:51:26 1998 UTC (25 years, 7 months ago) by gwlarson
fixed problem with new object block sizing
Mon Aug 24 16:42:46 1998 UTC (25 years, 10 months ago) by gwlarson
changed object block size and increased object limit to 32 million
Thu Jul 18 17:58:01 1996 UTC (27 years, 11 months ago) by greg
increased buffer size for in-line commands from 512 to 1024
Sat Jan 1 09:18:47 1994 UTC (30 years, 5 months ago) by greg
Changes since 2.3: +18 -12 lines
added warning about empty input
Fri Jun 4 15:08:20 1993 UTC (31 years ago) by greg
removed fgets() declaration
Mon Jan 25 12:41:24 1993 UTC (31 years, 5 months ago) by greg
removed lastrno from object structure
Tue Nov 12 16:55:11 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.7 , to selected 2.13
Mon Jul 22 11:48:04 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.6: +10 -4 lines
Diff to previous 1.6 , to selected 2.13
eliminated calls to scanf()
Fri Jul 19 09:25:43 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.5: +5 -55 lines
Diff to previous 1.5 , to selected 2.13
added separate readfargs() and freefargs() routines
Tue Sep 18 09:53:35 1990 UTC (33 years, 9 months ago) by greg
Diff to previous 1.4 , to selected 2.13
changed bmalloc() to call sbrk() since malloc() allocated
16K when asked for less than 8K and that's what octalloc() used before
Thu Sep 6 23:32:43 1990 UTC (33 years, 9 months ago) by greg
Diff to previous 1.3 , to selected 2.13
added consistency checks to detect stale octrees
Thu Jan 18 23:58:57 1990 UTC (34 years, 5 months ago) by greg
Diff to previous 1.2 , to selected 2.13
Wed Oct 4 16:32:04 1989 UTC (34 years, 8 months ago) by greg
Changes since 1.1: +3 -6 lines
Diff to previous 1.1 , to selected 2.13
Added multi-line commands.
Thu Feb 2 10:34:39 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 2.13
