--- ray/src/common/readmesh.c 2004/04/29 14:36:49 2.12 +++ ray/src/common/readmesh.c 2018/11/27 06:30:05 2.16 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: readmesh.c,v 2.12 2004/04/29 14:36:49 greg Exp $"; +static const char RCSid[] = "$Id: readmesh.c,v 2.16 2018/11/27 06:30:05 greg Exp $"; #endif /* * Routines for reading a compiled mesh from a file @@ -14,10 +14,6 @@ static const char RCSid[] = "$Id: readmesh.c,v 2.12 20 #include "mesh.h" #include "resolu.h" -#ifdef getc_unlocked /* avoid horrendous overhead of flockfile */ -#define getc getc_unlocked -#endif - static char *meshfn; /* input file name */ static FILE *meshfp; /* mesh file pointer */ static int objsize; /* sizeof(OBJECT) from writer */ @@ -39,7 +35,7 @@ static long mgetint(siz) /* get a siz-byte integer */ int siz; { - register long r; + long r; r = getint(siz, meshfp); if (feof(meshfp)) @@ -64,7 +60,7 @@ static OCTREE getfullnode() /* get a set, return fullnode */ { OBJECT set[MAXSET+1]; - register int i; + int i; if ((set[0] = mgetint(objsize)) > MAXSET) mesherror(USER, "bad set in getfullnode"); @@ -77,8 +73,8 @@ getfullnode() /* get a set, return fullnode */ static OCTREE gettree() /* get a pre-ordered octree */ { - register OCTREE ot; - register int i; + OCTREE ot; + int i; switch (getc(meshfp)) { case OT_EMPTY: @@ -96,14 +92,14 @@ gettree() /* get a pre-ordered octree */ default: mesherror(USER, "damaged mesh octree"); } - return (OCTREE)NULL; /* pro forma return */ + return (OCTREE)0; /* pro forma return */ } static void skiptree() /* skip octree on input */ { - register int i; + int i; switch (getc(meshfp)) { case OT_EMPTY: @@ -127,7 +123,7 @@ skiptree() /* skip octree on input */ static void getpatch(pp) /* load a mesh patch */ -register MESHPATCH *pp; +MESHPATCH *pp; { int flags; int i, j; @@ -137,7 +133,7 @@ register MESHPATCH *pp; mesherror(USER, "bad patch flags"); /* allocate vertices */ pp->nverts = mgetint(2); - if (pp->nverts <= 0 || pp->nverts > 256) + if ((pp->nverts <= 0) | (pp->nverts > 256)) mesherror(USER, "bad number of patch vertices"); pp->xyz = (uint32 (*)[3])malloc(pp->nverts*3*sizeof(uint32)); if (pp->xyz == NULL) @@ -169,7 +165,7 @@ register MESHPATCH *pp; pp->uv[i][j] = mgetint(4); /* local triangles */ pp->ntris = mgetint(2); - if (pp->ntris < 0 || pp->ntris > 512) + if ((pp->ntris < 0) | (pp->ntris > 512)) mesherror(USER, "bad number of local triangles"); if (pp->ntris) { pp->tri = (struct PTri *)malloc(pp->ntris * @@ -196,7 +192,7 @@ register MESHPATCH *pp; } /* joiner triangles */ pp->nj1tris = mgetint(2); - if (pp->nj1tris < 0 || pp->nj1tris > 512) + if ((pp->nj1tris < 0) | (pp->nj1tris > 256)) mesherror(USER, "bad number of joiner triangles"); if (pp->nj1tris) { pp->j1tri = (struct PJoin1 *)malloc(pp->nj1tris * @@ -213,7 +209,7 @@ register MESHPATCH *pp; pp->j1tri = NULL; /* double joiner triangles */ pp->nj2tris = mgetint(2); - if (pp->nj2tris < 0 || pp->nj2tris > 256) + if ((pp->nj2tris < 0) | (pp->nj2tris > 256)) mesherror(USER, "bad number of double joiner triangles"); if (pp->nj2tris) { pp->j2tri = (struct PJoin2 *)malloc(pp->nj2tris * @@ -258,7 +254,7 @@ int flags; checkheader(meshfp, MESHFMT, flags&IO_INFO ? stdout : (FILE *)NULL); /* read format number */ objsize = getint(2, meshfp) - MESHMAGIC; - if (objsize <= 0 || objsize > MAXOBJSIZ || objsize > sizeof(long)) + if ((objsize <= 0) | (objsize > MAXOBJSIZ) | (objsize > sizeof(long))) mesherror(USER, "incompatible mesh format"); /* read boundaries */ if (flags & IO_BOUNDS) {
