root/Development/ray/src/common/readmesh.c
Revision: 2.13
Committed: Tue Sep 14 02:53:50 2004 UTC (21 years, 3 months ago) by greg
CVS Tags: rad4R0, rad3R9, rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6
Added #undef for getc/putc where they were being replaced
2 static const char RCSid[] = "$Id: readmesh.c,v 2.12 2004/04/29 14:36:49 greg Exp $";
5 * Routines for reading a compiled mesh from a file
6 */
7
8 #include <time.h>
9
10 #include "platform.h"
11 #include "standard.h"
12 #include "octree.h"
13 #include "object.h"
14 #include "mesh.h"
15 #include "resolu.h"
16
17 #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
18 #undef getc
19 #define getc getc_unlocked
20 #endif
21
22 static char *meshfn; /* input file name */
23 static FILE *meshfp; /* mesh file pointer */
24 static int objsize; /* sizeof(OBJECT) from writer */
25
26
27 static void
28 mesherror(etyp, msg) /* mesh read error */
29 int etyp;
30 char *msg;
31 {
32 char msgbuf[128];
33
34 sprintf(msgbuf, "(%s): %s", meshfn, msg);
35 error(etyp, msgbuf);
36 }
37
38
39 static long
40 mgetint(siz) /* get a siz-byte integer */
41 int siz;
42 {
43 register long r;
44
45 r = getint(siz, meshfp);
46 if (feof(meshfp))
47 mesherror(USER, "truncated mesh file");
48 return(r);
49 }
50
51
52 static double
53 mgetflt() /* get a floating point number */
54 {
55 double r;
56
57 r = getflt(meshfp);
58 if (feof(meshfp))
59 mesherror(USER, "truncated mesh file");
60 return(r);
61 }
62
63
64 static OCTREE
65 getfullnode() /* get a set, return fullnode */
66 {
67 OBJECT set[MAXSET+1];
68 register int i;
69
70 if ((set[0] = mgetint(objsize)) > MAXSET)
71 mesherror(USER, "bad set in getfullnode");
72 for (i = 1; i <= set[0]; i++)
73 set[i] = mgetint(objsize);
74 return(fullnode(set));
75 }
76
77
78 static OCTREE
79 gettree() /* get a pre-ordered octree */
80 {
81 register OCTREE ot;
82 register int i;
83
84 switch (getc(meshfp)) {
85 case OT_EMPTY:
86 return(EMPTY);
87 case OT_FULL:
88 return(getfullnode());
89 case OT_TREE:
90 if ((ot = octalloc()) == EMPTY)
91 mesherror(SYSTEM, "out of tree space in readmesh");
92 for (i = 0; i < 8; i++)
93 octkid(ot, i) = gettree();
94 return(ot);
95 case EOF:
96 mesherror(USER, "truncated mesh octree");
97 default:
98 mesherror(USER, "damaged mesh octree");
99 }
100 return (OCTREE)NULL; /* pro forma return */
101 }
102
103
104 static void
105 skiptree() /* skip octree on input */
106 {
107 register int i;
108
109 switch (getc(meshfp)) {
110 case OT_EMPTY:
111 return;
112 case OT_FULL:
113 for (i = mgetint(objsize)*objsize; i-- > 0; )
114 if (getc(meshfp) == EOF)
115 mesherror(USER, "truncated mesh octree");
116 return;
117 case OT_TREE:
118 for (i = 0; i < 8; i++)
119 skiptree();
120 return;
121 case EOF:
122 mesherror(USER, "truncated mesh octree");
123 default:
124 mesherror(USER, "damaged mesh octree");
125 }
126 }
127
128
129 static void
130 getpatch(pp) /* load a mesh patch */
131 register MESHPATCH *pp;
132 {
133 int flags;
134 int i, j;
135 /* vertex flags */
136 flags = mgetint(1);
137 if (!(flags & MT_V) || flags & ~(MT_V|MT_N|MT_UV))
138 mesherror(USER, "bad patch flags");
139 /* allocate vertices */
140 pp->nverts = mgetint(2);
141 if (pp->nverts <= 0 || pp->nverts > 256)
142 mesherror(USER, "bad number of patch vertices");
143 pp->xyz = (uint32 (*)[3])malloc(pp->nverts*3*sizeof(uint32));
144 if (pp->xyz == NULL)
145 goto nomem;
146 if (flags & MT_N) {
147 pp->norm = (int32 *)calloc(pp->nverts, sizeof(int32));
148 if (pp->norm == NULL)
149 goto nomem;
150 } else
151 pp->norm = NULL;
152 if (flags & MT_UV) {
153 pp->uv = (uint32 (*)[2])calloc(pp->nverts, 2*sizeof(uint32));
154 if (pp->uv == NULL)
155 goto nomem;
156 } else
157 pp->uv = NULL;
158 /* vertex xyz locations */
159 for (i = 0; i < pp->nverts; i++)
160 for (j = 0; j < 3; j++)
161 pp->xyz[i][j] = mgetint(4);
162 /* vertex normals */
163 if (flags & MT_N)
164 for (i = 0; i < pp->nverts; i++)
165 pp->norm[i] = mgetint(4);
166 /* uv coordinates */
167 if (flags & MT_UV)
168 for (i = 0; i < pp->nverts; i++)
169 for (j = 0; j < 2; j++)
170 pp->uv[i][j] = mgetint(4);
171 /* local triangles */
172 pp->ntris = mgetint(2);
173 if (pp->ntris < 0 || pp->ntris > 512)
174 mesherror(USER, "bad number of local triangles");
175 if (pp->ntris) {
176 pp->tri = (struct PTri *)malloc(pp->ntris *
177 sizeof(struct PTri));
178 if (pp->tri == NULL)
179 goto nomem;
180 for (i = 0; i < pp->ntris; i++) {
181 pp->tri[i].v1 = mgetint(1);
182 pp->tri[i].v2 = mgetint(1);
183 pp->tri[i].v3 = mgetint(1);
184 }
185 } else
186 pp->tri = NULL;
187 /* local triangle material(s) */
188 if (mgetint(2) > 1) {
189 pp->trimat = (int16 *)malloc(pp->ntris*sizeof(int16));
190 if (pp->trimat == NULL)
191 goto nomem;
192 for (i = 0; i < pp->ntris; i++)
193 pp->trimat[i] = mgetint(2);
194 } else {
195 pp->solemat = mgetint(2);
196 pp->trimat = NULL;
197 }
198 /* joiner triangles */
199 pp->nj1tris = mgetint(2);
200 if (pp->nj1tris < 0 || pp->nj1tris > 512)
201 mesherror(USER, "bad number of joiner triangles");
202 if (pp->nj1tris) {
203 pp->j1tri = (struct PJoin1 *)malloc(pp->nj1tris *
204 sizeof(struct PJoin1));
205 if (pp->j1tri == NULL)
206 goto nomem;
207 for (i = 0; i < pp->nj1tris; i++) {
208 pp->j1tri[i].v1j = mgetint(4);
209 pp->j1tri[i].v2 = mgetint(1);
210 pp->j1tri[i].v3 = mgetint(1);
211 pp->j1tri[i].mat = mgetint(2);
212 }
213 } else
214 pp->j1tri = NULL;
215 /* double joiner triangles */
216 pp->nj2tris = mgetint(2);
217 if (pp->nj2tris < 0 || pp->nj2tris > 256)
218 mesherror(USER, "bad number of double joiner triangles");
219 if (pp->nj2tris) {
220 pp->j2tri = (struct PJoin2 *)malloc(pp->nj2tris *
221 sizeof(struct PJoin2));
222 if (pp->j2tri == NULL)
223 goto nomem;
224 for (i = 0; i < pp->nj2tris; i++) {
225 pp->j2tri[i].v1j = mgetint(4);
226 pp->j2tri[i].v2j = mgetint(4);
227 pp->j2tri[i].v3 = mgetint(1);
228 pp->j2tri[i].mat = mgetint(2);
229 }
230 } else
231 pp->j2tri = NULL;
232 return;
233 nomem:
234 error(SYSTEM, "out of mesh memory in getpatch");
235 }
236
237
238 void
239 readmesh(mp, path, flags) /* read in mesh structures */
240 MESH *mp;
241 char *path;
242 int flags;
243 {
244 char *err;
245 char sbuf[64];
246 int i;
247 /* check what's loaded */
248 flags &= (IO_INFO|IO_BOUNDS|IO_TREE|IO_SCENE) & ~mp->ldflags;
249 /* open input file */
250 if (path == NULL) {
251 meshfn = "standard input";
252 meshfp = stdin;
253 } else if ((meshfp = fopen(meshfn=path, "r")) == NULL) {
254 sprintf(errmsg, "cannot open mesh file \"%s\"", path);
255 error(SYSTEM, errmsg);
256 }
257 SET_FILE_BINARY(meshfp);
258 /* read header */
259 checkheader(meshfp, MESHFMT, flags&IO_INFO ? stdout : (FILE *)NULL);
260 /* read format number */
261 objsize = getint(2, meshfp) - MESHMAGIC;
262 if (objsize <= 0 || objsize > MAXOBJSIZ || objsize > sizeof(long))
263 mesherror(USER, "incompatible mesh format");
264 /* read boundaries */
265 if (flags & IO_BOUNDS) {
266 for (i = 0; i < 3; i++)
267 mp->mcube.cuorg[i] = atof(getstr(sbuf, meshfp));
268 mp->mcube.cusize = atof(getstr(sbuf, meshfp));
269 for (i = 0; i < 2; i++) {
270 mp->uvlim[0][i] = mgetflt();
271 mp->uvlim[1][i] = mgetflt();
272 }
273 } else {
274 for (i = 0; i < 4; i++)
275 getstr(sbuf, meshfp);
276 for (i = 0; i < 4; i++)
277 mgetflt();
278 }
279 /* read the octree */
280 if (flags & IO_TREE)
281 mp->mcube.cutree = gettree();
282 else if (flags & IO_SCENE)
283 skiptree();
284 /* read materials and patches */
285 if (flags & IO_SCENE) {
286 mp->mat0 = nobjects;
287 readscene(meshfp, objsize);
288 mp->nmats = nobjects - mp->mat0;
289 mp->npatches = mgetint(4);
290 mp->patch = (MESHPATCH *)calloc(mp->npatches,
291 sizeof(MESHPATCH));
292 if (mp->patch == NULL)
293 mesherror(SYSTEM, "out of patch memory");
294 for (i = 0; i < mp->npatches; i++)
295 getpatch(&mp->patch[i]);
296 }
297 /* clean up */
298 fclose(meshfp);
299 mp->ldflags |= flags;
300 /* verify data */
301 if ((err = checkmesh(mp)) != NULL)
302 mesherror(USER, err);
303 }
