root/radiance/ray/src/common/readmesh.c
Revision: 2.6
Committed: Fri Jun 20 00:25:49 2003 UTC (22 years, 1 month ago) by greg
2 static const char RCSid[] = "$Id: readmesh.c,v 2.5 2003/06/08 12:03:09 schorsch Exp $";
5 * Routines for reading a compiled mesh from a file
6 */
7
8 #include "standard.h"
9 #include "platform.h"
10 #include "octree.h"
11 #include "object.h"
12 #include "mesh.h"
13 #include "resolu.h"
14
15 static char *meshfn; /* input file name */
16 static FILE *meshfp; /* mesh file pointer */
17 static int objsize; /* sizeof(OBJECT) from writer */
18
19
20 static void
21 mesherror(etyp, msg) /* mesh read error */
22 int etyp;
23 char *msg;
24 {
25 char msgbuf[128];
26
27 sprintf(msgbuf, "(%s): %s", meshfn, msg);
28 error(etyp, msgbuf);
29 }
30
31
32 static long
33 mgetint(siz) /* get a siz-byte integer */
34 int siz;
35 {
36 register long r;
37
38 r = getint(siz, meshfp);
39 if (feof(meshfp))
40 mesherror(USER, "truncated mesh file");
41 return(r);
42 }
43
44
45 static double
46 mgetflt() /* get a floating point number */
47 {
48 double r;
49
50 r = getflt(meshfp);
51 if (feof(meshfp))
52 mesherror(USER, "truncated mesh file");
53 return(r);
54 }
55
56
57 static OCTREE
58 getfullnode() /* get a set, return fullnode */
59 {
60 OBJECT set[MAXSET+1];
61 register int i;
62
63 if ((set[0] = mgetint(objsize)) > MAXSET)
64 mesherror(USER, "bad set in getfullnode");
65 for (i = 1; i <= set[0]; i++)
66 set[i] = mgetint(objsize);
67 return(fullnode(set));
68 }
69
70
71 static OCTREE
72 gettree() /* get a pre-ordered octree */
73 {
74 register OCTREE ot;
75 register int i;
76
77 switch (getc(meshfp)) {
78 case OT_EMPTY:
79 return(EMPTY);
80 case OT_FULL:
81 return(getfullnode());
82 case OT_TREE:
83 if ((ot = octalloc()) == EMPTY)
84 mesherror(SYSTEM, "out of tree space in readmesh");
85 for (i = 0; i < 8; i++)
86 octkid(ot, i) = gettree();
87 return(ot);
88 case EOF:
89 mesherror(USER, "truncated mesh octree");
90 default:
91 mesherror(USER, "damaged mesh octree");
92 }
93 return NULL; /* pro forma return */
94 }
95
96
97 static void
98 skiptree() /* skip octree on input */
99 {
100 register int i;
101
102 switch (getc(meshfp)) {
103 case OT_EMPTY:
104 return;
105 case OT_FULL:
106 for (i = mgetint(objsize)*objsize; i-- > 0; )
107 if (getc(meshfp) == EOF)
108 mesherror(USER, "truncated mesh octree");
109 return;
110 case OT_TREE:
111 for (i = 0; i < 8; i++)
112 skiptree();
113 return;
114 case EOF:
115 mesherror(USER, "truncated mesh octree");
116 default:
117 mesherror(USER, "damaged mesh octree");
118 }
119 }
120
121
122 static void
123 getpatch(pp) /* load a mesh patch */
124 register MESHPATCH *pp;
125 {
126 int flags;
127 int i, j;
128 /* vertex flags */
129 flags = mgetint(1);
130 if (!(flags & MT_V) || flags & ~(MT_V|MT_N|MT_UV))
131 mesherror(USER, "bad patch flags");
132 /* allocate vertices */
133 pp->nverts = mgetint(2);
134 if (pp->nverts <= 0 || pp->nverts > 256)
135 mesherror(USER, "bad number of patch vertices");
136 pp->xyz = (uint32 (*)[3])malloc(pp->nverts*3*sizeof(uint32));
137 if (pp->xyz == NULL)
138 goto nomem;
139 if (flags & MT_N) {
140 pp->norm = (int32 *)calloc(pp->nverts, sizeof(int32));
141 if (pp->norm == NULL)
142 goto nomem;
143 } else
144 pp->norm = NULL;
145 if (flags & MT_UV) {
146 pp->uv = (uint32 (*)[2])calloc(pp->nverts, 2*sizeof(uint32));
147 if (pp->uv == NULL)
148 goto nomem;
149 } else
150 pp->uv = NULL;
151 /* vertex xyz locations */
152 for (i = 0; i < pp->nverts; i++)
153 for (j = 0; j < 3; j++)
154 pp->xyz[i][j] = mgetint(4);
155 /* vertex normals */
156 if (flags & MT_N)
157 for (i = 0; i < pp->nverts; i++)
158 pp->norm[i] = mgetint(4);
159 /* uv coordinates */
160 if (flags & MT_UV)
161 for (i = 0; i < pp->nverts; i++)
162 for (j = 0; j < 2; j++)
163 pp->uv[i][j] = mgetint(4);
164 /* local triangles */
165 pp->ntris = mgetint(2);
166 if (pp->ntris < 0 || pp->ntris > 512)
167 mesherror(USER, "bad number of local triangles");
168 if (pp->ntris) {
169 pp->tri = (struct PTri *)malloc(pp->ntris *
170 sizeof(struct PTri));
171 if (pp->tri == NULL)
172 goto nomem;
173 for (i = 0; i < pp->ntris; i++) {
174 pp->tri[i].v1 = mgetint(1);
175 pp->tri[i].v2 = mgetint(1);
176 pp->tri[i].v3 = mgetint(1);
177 }
178 } else
179 pp->tri = NULL;
180 /* local triangle material(s) */
181 if (mgetint(2) > 1) {
182 pp->trimat = (int16 *)malloc(pp->ntris*sizeof(int16));
183 if (pp->trimat == NULL)
184 goto nomem;
185 for (i = 0; i < pp->ntris; i++)
186 pp->trimat[i] = mgetint(2);
187 } else {
188 pp->solemat = mgetint(2);
189 pp->trimat = NULL;
190 }
191 /* joiner triangles */
192 pp->nj1tris = mgetint(2);
193 if (pp->nj1tris < 0 || pp->nj1tris > 512)
194 mesherror(USER, "bad number of joiner triangles");
195 if (pp->nj1tris) {
196 pp->j1tri = (struct PJoin1 *)malloc(pp->nj1tris *
197 sizeof(struct PJoin1));
198 if (pp->j1tri == NULL)
199 goto nomem;
200 for (i = 0; i < pp->nj1tris; i++) {
201 pp->j1tri[i].v1j = mgetint(4);
202 pp->j1tri[i].v2 = mgetint(1);
203 pp->j1tri[i].v3 = mgetint(1);
204 pp->j1tri[i].mat = mgetint(2);
205 }
206 } else
207 pp->j1tri = NULL;
208 /* double joiner triangles */
209 pp->nj2tris = mgetint(2);
210 if (pp->nj2tris < 0 || pp->nj2tris > 256)
211 mesherror(USER, "bad number of double joiner triangles");
212 if (pp->nj2tris) {
213 pp->j2tri = (struct PJoin2 *)malloc(pp->nj2tris *
214 sizeof(struct PJoin2));
215 if (pp->j2tri == NULL)
216 goto nomem;
217 for (i = 0; i < pp->nj2tris; i++) {
218 pp->j2tri[i].v1j = mgetint(4);
219 pp->j2tri[i].v2j = mgetint(4);
220 pp->j2tri[i].v3 = mgetint(1);
221 pp->j2tri[i].mat = mgetint(2);
222 }
223 } else
224 pp->j2tri = NULL;
225 return;
226 nomem:
227 error(SYSTEM, "out of mesh memory in getpatch");
228 }
229
230
231 void
232 readmesh(mp, path, flags) /* read in mesh structures */
233 MESH *mp;
234 char *path;
235 int flags;
236 {
237 char *err;
238 char sbuf[64];
239 int i;
240 /* check what's loaded */
241 flags &= (IO_INFO|IO_BOUNDS|IO_TREE|IO_SCENE) & ~mp->ldflags;
242 /* open input file */
243 if (path == NULL) {
244 meshfn = "standard input";
245 meshfp = stdin;
246 } else if ((meshfp = fopen(meshfn=path, "r")) == NULL) {
247 sprintf(errmsg, "cannot open mesh file \"%s\"", path);
248 error(SYSTEM, errmsg);
249 }
250 SET_FILE_BINARY(meshfp);
251 /* read header */
252 checkheader(meshfp, MESHFMT, flags&IO_INFO ? stdout : (FILE *)NULL);
253 /* read format number */
254 objsize = getint(2, meshfp) - MESHMAGIC;
255 if (objsize <= 0 || objsize > MAXOBJSIZ || objsize > sizeof(long))
256 mesherror(USER, "incompatible mesh format");
257 /* read boundaries */
258 if (flags & IO_BOUNDS) {
259 for (i = 0; i < 3; i++)
260 mp->mcube.cuorg[i] = atof(getstr(sbuf, meshfp));
261 mp->mcube.cusize = atof(getstr(sbuf, meshfp));
262 for (i = 0; i < 2; i++) {
263 mp->uvlim[0][i] = mgetflt();
264 mp->uvlim[1][i] = mgetflt();
265 }
266 } else {
267 for (i = 0; i < 4; i++)
268 getstr(sbuf, meshfp);
269 for (i = 0; i < 4; i++)
270 mgetflt();
271 }
272 /* read the octree */
273 if (flags & IO_TREE)
274 mp->mcube.cutree = gettree();
275 else if (flags & IO_SCENE)
276 skiptree();
277 /* read materials and patches */
278 if (flags & IO_SCENE) {
279 mp->mat0 = nobjects;
280 readscene(meshfp, objsize);
281 mp->nmats = nobjects - mp->mat0;
282 mp->npatches = mgetint(4);
283 mp->patch = (MESHPATCH *)calloc(mp->npatches,
284 sizeof(MESHPATCH));
285 if (mp->patch == NULL)
286 mesherror(SYSTEM, "out of patch memory");
287 for (i = 0; i < mp->npatches; i++)
288 getpatch(&mp->patch[i]);
289 }
290 /* clean up */
291 fclose(meshfp);
292 mp->ldflags |= flags;
293 /* verify data */
294 if ((err = checkmesh(mp)) != NULL)
295 mesherror(USER, err);
296 }
