root/radiance/ray/src/common/readmesh.c
Tue Feb 7 20:28:16 2023 UTC (16 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 2.18: +8 -1 lines
perf: added calls to flockfile()/funlockfile() for more efficient reading
Mon Jul 12 17:42:51 2021 UTC (2 years, 11 months ago) by greg
Changes since 2.17: +7 -7 lines
perf: minor efficiency improvements
Sat May 4 00:36:58 2019 UTC (5 years, 1 month ago) by greg
Changes since 2.16: +3 -2 lines
Eliminated cases where stdin was being closed
Tue Nov 27 06:30:05 2018 UTC (5 years, 6 months ago) by greg
Changes since 2.15: +12 -12 lines
Corrected single-joiner triangle count check
Fri Mar 4 00:21:21 2016 UTC (8 years, 3 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.14: +1 -6 lines
Wed Dec 15 17:26:28 2010 UTC (13 years, 6 months ago) by greg
Unimportant change to avoid compiler warning
Tue Sep 14 02:53:50 2004 UTC (19 years, 9 months ago) by greg
Added #undef for getc/putc where they were being replaced
Thu Apr 29 14:36:49 2004 UTC (20 years, 1 month ago) by greg
Changes since 2.11: +5 -1 lines
Added macros to avoid flockfile(3) overhead
Fri Jan 30 00:08:31 2004 UTC (20 years, 4 months ago) by greg
Thu Sep 18 16:53:53 2003 UTC (20 years, 9 months ago) by greg
Wed Jul 30 10:11:06 2003 UTC (20 years, 10 months ago) by schorsch
Wed Jul 16 01:32:53 2003 UTC (20 years, 11 months ago) by greg
Minor compile fixes
Fri Jun 20 00:25:49 2003 UTC (21 years ago) by greg
Sun Jun 8 12:03:09 2003 UTC (21 years ago) by schorsch
Sat Jun 7 12:50:20 2003 UTC (21 years ago) by schorsch
Changes since 2.3: +17 -15 lines
Changes since 2.2: +2 -4 lines
Fri Mar 14 21:27:46 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.1: +21 -1 lines
Tue Mar 11 17:08:55 2003 UTC (21 years, 3 months ago) by greg
Diff to selected 2.11
