root/radiance/ray/src/common/readfargs.c
Thu Jun 12 22:12:20 2014 UTC (10 years ago) by greg
Changes since 2.10: +10 -8 lines
ANSIfication
Changes since 2.9: +3 -3 lines
Changes since 2.6: +76 -22 lines
Tue Aug 25 10:20:30 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 2.5: +2 -10 lines
added include of standard.h to readfargs.c
Wed Sep 8 09:12:36 1993 UTC (30 years, 9 months ago) by greg
Changes since 2.4: +4 -0 lines
added conditional declaration of atof()
Fri Jun 4 14:28:52 1993 UTC (31 years ago) by greg
Changes since 2.3: +2 -3 lines
Removed unnecessary declaration of atof()
Tue May 18 09:26:05 1993 UTC (31 years, 1 month ago) by greg
Changes since 2.2: +14 -16 lines
prettied up macros a bit
Thu Dec 19 14:45:52 1991 UTC (32 years, 6 months ago) by greg
Tue Nov 12 16:55:59 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.3
Wed Oct 23 13:43:19 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.2: +3 -1 lines
Diff to previous 1.2
Mon Jul 22 11:23:00 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.1: +24 -12 lines
Diff to previous 1.1
removed scanf calls from readfargs
Fri Jul 19 09:24:41 1991 UTC (32 years, 11 months ago) by greg
