root/radiance/ray/src/common/random.h
Thu Apr 21 02:52:40 2022 UTC (3 years, 1 month ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 2.23: +5 -3 lines
Diff to previous 2.23 , to selected 1.1
perf(cnt): improved randomness of cnt -s option with new irandom(modulus) call
Sun Mar 6 01:13:17 2016 UTC (9 years, 3 months ago) by schorsch
Changes since 2.22: +2 -3 lines
Diff to previous 2.22 , to selected 1.1
Thu Jul 16 05:08:57 2015 UTC (9 years, 10 months ago) by greg
Changes since 2.21: +4 -3 lines
Diff to previous 2.21 , to selected 1.1
Added required #include for drand48()
Wed May 27 08:42:06 2015 UTC (10 years ago) by greg
Changes since 2.20: +1 -4 lines
Diff to previous 2.20 , to selected 1.1
Fixed includes and prototypes
Wed May 27 08:37:26 2015 UTC (10 years ago) by greg
Changes since 2.19: +2 -10 lines
Diff to previous 2.19 , to selected 1.1
Make drand48() the standard random number generator even with -DBSD
Mon Jan 26 20:04:30 2015 UTC (10 years, 4 months ago) by greg
Changes since 2.18: +3 -1 lines
Diff to previous 2.18 , to selected 1.1
Added needed include file for rand() and RAND_MAX under Windows
Sat Apr 9 15:39:16 2011 UTC (14 years, 1 month ago) by greg
Diff to previous 2.17 , to selected 1.1
Fixed range of rand() -> double conversion
Wed Apr 5 15:21:53 2006 UTC (19 years, 2 months ago) by greg
Diff to previous 2.16 , to selected 1.1
Eliminated redundant parens
Wed Apr 5 06:22:56 2006 UTC (19 years, 2 months ago) by greg
Diff to previous 2.15 , to selected 1.1
Made -u+ option truly random
Mon Jun 13 20:07:56 2005 UTC (19 years, 11 months ago) by greg
Changes since 2.14: +1 -24 lines
Diff to previous 2.14 , to selected 1.1
Sun Jun 29 16:51:48 2003 UTC (21 years, 11 months ago) by greg
Changes since 2.13: +7 -6 lines
Diff to previous 2.13 , to selected 1.1
Fixed compile error with -DMC
Fri Jun 27 06:53:21 2003 UTC (21 years, 11 months ago) by greg
Changes since 2.12: +1 -4 lines
Diff to previous 2.12 , to selected 1.1
Fri Jun 6 16:38:47 2003 UTC (22 years ago) by schorsch
Changes since 2.11: +12 -9 lines
Diff to previous 2.11 , to selected 1.1
*** empty log message ***
Thu Jun 5 19:29:34 2003 UTC (22 years ago) by schorsch
Diff to previous 2.10 , to selected 1.1
Thu Mar 27 16:33:38 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.9: +5 -1 lines
Diff to previous 2.9 , to selected 1.1
Fixed bug introduced in last update and potential bug in random.h
Tue Feb 25 02:47:21 2003 UTC (22 years, 3 months ago) by greg
Diff to previous 2.8 , to selected 1.1
Changes since 2.7: +90 -6 lines
Diff to previous 2.7 , to selected 1.1
Sat Jan 9 09:15:48 1999 UTC (26 years, 5 months ago) by gwlarson
Diff to previous 2.6 , to selected 1.1
added define for random seed function
Mon Jan 5 16:42:49 1998 UTC (27 years, 5 months ago) by gregl
Diff to previous 2.5 , to selected 1.1
added check for too many urand values
Mon Dec 1 09:55:00 1997 UTC (27 years, 6 months ago) by gregl
Changes since 2.4: +10 -5 lines
Diff to previous 2.4 , to selected 1.1
Tue Feb 13 11:32:17 1996 UTC (29 years, 3 months ago) by greg
Changes since 2.3: +4 -0 lines
Diff to previous 2.3 , to selected 1.1
added MC macro for true Monte Carlo sampling
Thu Jun 9 16:40:53 1994 UTC (31 years ago) by greg
Diff to previous 2.2 , to selected 1.1
made random() macro better for DOS (& 31-bits)
Mon Sep 21 12:02:27 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.1: +14 -6 lines
Diff to previous 2.1 , to selected 1.1
Changes for PC port
Tue Nov 12 16:54:19 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 1.4 , to selected 1.1
Fri May 17 13:51:29 1991 UTC (34 years ago) by greg
Changes since 1.3: +6 -1 lines
Diff to previous 1.3 , to selected 1.1
added urand() definition
Tue Dec 4 11:23:58 1990 UTC (34 years, 6 months ago) by greg
Changes since 1.2: +12 -0 lines
Diff to previous 1.2 , to selected 1.1
added defines for System V derivatives
Tue Sep 26 08:28:53 1989 UTC (35 years, 8 months ago) by greg
Diff to previous 1.1
Changed divide by constant to multiply for efficiency
Revision 1.1 - (view) (download) (annotate) - [selected]
Thu Feb 2 10:34:21 1989 UTC (36 years, 4 months ago) by greg
