root/radiance/ray/src/common/random.h
Revision 2.15 - (view) (download) (annotate) - [selected]
Mon Jun 13 20:07:56 2005 UTC (18 years, 11 months ago) by greg
Changes since 2.14: +1 -24 lines
Diff to previous 2.14
Sun Jun 29 16:51:48 2003 UTC (20 years, 11 months ago) by greg
Changes since 2.13: +7 -6 lines
Diff to previous 2.13 , to selected 2.15
Fixed compile error with -DMC
Changes since 2.12: +1 -4 lines
Diff to previous 2.12 , to selected 2.15
Fri Jun 6 16:38:47 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.11: +12 -9 lines
Diff to previous 2.11 , to selected 2.15
*** empty log message ***
Diff to previous 2.10 , to selected 2.15
Thu Mar 27 16:33:38 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.9: +5 -1 lines
Diff to previous 2.9 , to selected 2.15
Fixed bug introduced in last update and potential bug in random.h
Diff to previous 2.8 , to selected 2.15
Changes since 2.7: +90 -6 lines
Diff to previous 2.7 , to selected 2.15
Sat Jan 9 09:15:48 1999 UTC (25 years, 4 months ago) by gwlarson
Diff to previous 2.6 , to selected 2.15
added define for random seed function
Mon Jan 5 16:42:49 1998 UTC (26 years, 4 months ago) by gregl
Diff to previous 2.5 , to selected 2.15
added check for too many urand values
Mon Dec 1 09:55:00 1997 UTC (26 years, 5 months ago) by gregl
Changes since 2.4: +10 -5 lines
Diff to previous 2.4 , to selected 2.15
Tue Feb 13 11:32:17 1996 UTC (28 years, 3 months ago) by greg
Changes since 2.3: +4 -0 lines
Diff to previous 2.3 , to selected 2.15
added MC macro for true Monte Carlo sampling
Thu Jun 9 16:40:53 1994 UTC (29 years, 11 months ago) by greg
Diff to previous 2.2 , to selected 2.15
made random() macro better for DOS (& 31-bits)
Mon Sep 21 12:02:27 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.1: +14 -6 lines
Diff to previous 2.1 , to selected 2.15
Changes for PC port
Tue Nov 12 16:54:19 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.4 , to selected 2.15
Fri May 17 13:51:29 1991 UTC (33 years ago) by greg
Changes since 1.3: +6 -1 lines
Diff to previous 1.3 , to selected 2.15
added urand() definition
Tue Dec 4 11:23:58 1990 UTC (33 years, 5 months ago) by greg
Changes since 1.2: +12 -0 lines
Diff to previous 1.2 , to selected 2.15
added defines for System V derivatives
Tue Sep 26 08:28:53 1989 UTC (34 years, 8 months ago) by greg
Diff to previous 1.1 , to selected 2.15
Changed divide by constant to multiply for efficiency
Thu Feb 2 10:34:21 1989 UTC (35 years, 3 months ago) by greg
Diff to selected 2.15
