root/radiance/ray/src/common/random.c
Revision: 3.2
Committed: Fri Nov 5 03:31:36 2004 UTC (20 years, 6 months ago) by greg
State: FILE REMOVED
Error occurred while calculating annotation data.
2 static const char RCSid[] = "$Id: random.c,v 3.1 2003/02/22 02:07:22 greg Exp $";
4 #ifndef lint
5 static char sccsid[] = "@(#)random.c 1.1 87/12/17 SMI"; /* from UCB 4.2 83/01/02 */
6 #endif
7
8 #include <stdio.h>
9
10 /*
11 * random.c:
12 * An improved random number generation package. In addition to the standard
13 * rand()/srand() like interface, this package also has a special state info
14 * interface. The initstate() routine is called with a seed, an array of
15 * bytes, and a count of how many bytes are being passed in; this array is then
16 * initialized to contain information for random number generation with that
17 * much state information. Good sizes for the amount of state information are
18 * 32, 64, 128, and 256 bytes. The state can be switched by calling the
19 * setstate() routine with the same array as was initiallized with initstate().
20 * By default, the package runs with 128 bytes of state information and
21 * generates far better random numbers than a linear congruential generator.
22 * If the amount of state information is less than 32 bytes, a simple linear
23 * congruential R.N.G. is used.
24 * Internally, the state information is treated as an array of longs; the
25 * zeroeth element of the array is the type of R.N.G. being used (small
26 * integer); the remainder of the array is the state information for the
27 * R.N.G. Thus, 32 bytes of state information will give 7 longs worth of
28 * state information, which will allow a degree seven polynomial. (Note: the
29 * zeroeth word of state information also has some other information stored
30 * in it -- see setstate() for details).
31 * The random number generation technique is a linear feedback shift register
32 * approach, employing trinomials (since there are fewer terms to sum up that
33 * way). In this approach, the least significant bit of all the numbers in
34 * the state table will act as a linear feedback shift register, and will have
35 * period 2^deg - 1 (where deg is the degree of the polynomial being used,
36 * assuming that the polynomial is irreducible and primitive). The higher
37 * order bits will have longer periods, since their values are also influenced
38 * by pseudo-random carries out of the lower bits. The total period of the
39 * generator is approximately deg*(2**deg - 1); thus doubling the amount of
40 * state information has a vast influence on the period of the generator.
41 * Note: the deg*(2**deg - 1) is an approximation only good for large deg,
42 * when the period of the shift register is the dominant factor. With deg
43 * equal to seven, the period is actually much longer than the 7*(2**7 - 1)
44 * predicted by this formula.
45 */
46
47
48
49 /*
50 * For each of the currently supported random number generators, we have a
51 * break value on the amount of state information (you need at least this
52 * many bytes of state info to support this random number generator), a degree
53 * for the polynomial (actually a trinomial) that the R.N.G. is based on, and
54 * the separation between the two lower order coefficients of the trinomial.
55 */
56
57 #define TYPE_0 0 /* linear congruential */
58 #define BREAK_0 8
59 #define DEG_0 0
60 #define SEP_0 0
61
62 #define TYPE_1 1 /* x**7 + x**3 + 1 */
63 #define BREAK_1 32
64 #define DEG_1 7
65 #define SEP_1 3
66
67 #define TYPE_2 2 /* x**15 + x + 1 */
68 #define BREAK_2 64
69 #define DEG_2 15
70 #define SEP_2 1
71
72 #define TYPE_3 3 /* x**31 + x**3 + 1 */
73 #define BREAK_3 128
74 #define DEG_3 31
75 #define SEP_3 3
76
77 #define TYPE_4 4 /* x**63 + x + 1 */
78 #define BREAK_4 256
79 #define DEG_4 63
80 #define SEP_4 1
81
82 extern long random();
83
84 /*
85 * Array versions of the above information to make code run faster -- relies
86 * on fact that TYPE_i == i.
87 */
88
89 #define MAX_TYPES 5 /* max number of types above */
90
91 static int degrees[ MAX_TYPES ] = { DEG_0, DEG_1, DEG_2,
92 DEG_3, DEG_4 };
93
94 static int seps[ MAX_TYPES ] = { SEP_0, SEP_1, SEP_2,
95 SEP_3, SEP_4 };
96
97
98
99 /*
100 * Initially, everything is set up as if from :
101 * initstate( 1, &randtbl, 128 );
102 * Note that this initialization takes advantage of the fact that srandom()
103 * advances the front and rear pointers 10*rand_deg times, and hence the
104 * rear pointer which starts at 0 will also end up at zero; thus the zeroeth
105 * element of the state information, which contains info about the current
106 * position of the rear pointer is just
107 * MAX_TYPES*(rptr - state) + TYPE_3 == TYPE_3.
108 */
109
110 static long randtbl[ DEG_3 + 1 ] = { TYPE_3,
111 0x9a319039, 0x32d9c024, 0x9b663182, 0x5da1f342,
112 0xde3b81e0, 0xdf0a6fb5, 0xf103bc02, 0x48f340fb,
113 0x7449e56b, 0xbeb1dbb0, 0xab5c5918, 0x946554fd,
114 0x8c2e680f, 0xeb3d799f, 0xb11ee0b7, 0x2d436b86,
115 0xda672e2a, 0x1588ca88, 0xe369735d, 0x904f35f7,
116 0xd7158fd6, 0x6fa6f051, 0x616e6b96, 0xac94efdc,
117 0x36413f93, 0xc622c298, 0xf5a42ab8, 0x8a88d77b,
118 0xf5ad9d0e, 0x8999220b, 0x27fb47b9 };
119
120 /*
121 * fptr and rptr are two pointers into the state info, a front and a rear
122 * pointer. These two pointers are always rand_sep places aparts, as they cycle
123 * cyclically through the state information. (Yes, this does mean we could get
124 * away with just one pointer, but the code for random() is more efficient this
125 * way). The pointers are left positioned as they would be from the call
126 * initstate( 1, randtbl, 128 )
127 * (The position of the rear pointer, rptr, is really 0 (as explained above
128 * in the initialization of randtbl) because the state table pointer is set
129 * to point to randtbl[1] (as explained below).
130 */
131
132 static long *fptr = &randtbl[ SEP_3 + 1 ];
133 static long *rptr = &randtbl[ 1 ];
134
135
136
137 /*
138 * The following things are the pointer to the state information table,
139 * the type of the current generator, the degree of the current polynomial
140 * being used, and the separation between the two pointers.
141 * Note that for efficiency of random(), we remember the first location of
142 * the state information, not the zeroeth. Hence it is valid to access
143 * state[-1], which is used to store the type of the R.N.G.
144 * Also, we remember the last location, since this is more efficient than
145 * indexing every time to find the address of the last element to see if
146 * the front and rear pointers have wrapped.
147 */
148
149 static long *state = &randtbl[ 1 ];
150
151 static int rand_type = TYPE_3;
152 static int rand_deg = DEG_3;
153 static int rand_sep = SEP_3;
154
155 static long *end_ptr = &randtbl[ DEG_3 + 1 ];
156
157
158
159 /*
160 * srandom:
161 * Initialize the random number generator based on the given seed. If the
162 * type is the trivial no-state-information type, just remember the seed.
163 * Otherwise, initializes state[] based on the given "seed" via a linear
164 * congruential generator. Then, the pointers are set to known locations
165 * that are exactly rand_sep places apart. Lastly, it cycles the state
166 * information a given number of times to get rid of any initial dependencies
167 * introduced by the L.C.R.N.G.
168 * Note that the initialization of randtbl[] for default usage relies on
169 * values produced by this routine.
170 */
171
172 srandom( x )
173
174 unsigned x;
175 {
176 register int i, j;
177
178 if( rand_type == TYPE_0 ) {
179 state[ 0 ] = x;
180 }
181 else {
182 j = 1;
183 state[ 0 ] = x;
184 for( i = 1; i < rand_deg; i++ ) {
185 state[i] = 1103515245*state[i - 1] + 12345;
186 }
187 fptr = &state[ rand_sep ];
188 rptr = &state[ 0 ];
189 for( i = 0; i < 10*rand_deg; i++ ) random();
190 }
191 }
192
193
194
195 /*
196 * initstate:
197 * Initialize the state information in the given array of n bytes for
198 * future random number generation. Based on the number of bytes we
199 * are given, and the break values for the different R.N.G.'s, we choose
200 * the best (largest) one we can and set things up for it. srandom() is
201 * then called to initialize the state information.
202 * Note that on return from srandom(), we set state[-1] to be the type
203 * multiplexed with the current value of the rear pointer; this is so
204 * successive calls to initstate() won't lose this information and will
205 * be able to restart with setstate().
206 * Note: the first thing we do is save the current state, if any, just like
207 * setstate() so that it doesn't matter when initstate is called.
208 * Returns a pointer to the old state.
209 */
210
211 char *
212 initstate( seed, arg_state, n )
213
214 unsigned seed; /* seed for R. N. G. */
215 char *arg_state; /* pointer to state array */
216 int n; /* # bytes of state info */
217 {
218 register char *ostate = (char *)( &state[ -1 ] );
219
220 if( rand_type == TYPE_0 ) state[ -1 ] = rand_type;
221 else state[ -1 ] = MAX_TYPES*(rptr - state) + rand_type;
222 if( n < BREAK_1 ) {
223 if( n < BREAK_0 ) {
224 fprintf( stderr, "initstate: not enough state (%d bytes) with which to do jack; ignored.\n" );
225 return;
226 }
227 rand_type = TYPE_0;
228 rand_deg = DEG_0;
229 rand_sep = SEP_0;
230 }
231 else {
232 if( n < BREAK_2 ) {
233 rand_type = TYPE_1;
234 rand_deg = DEG_1;
235 rand_sep = SEP_1;
236 }
237 else {
238 if( n < BREAK_3 ) {
239 rand_type = TYPE_2;
240 rand_deg = DEG_2;
241 rand_sep = SEP_2;
242 }
243 else {
244 if( n < BREAK_4 ) {
245 rand_type = TYPE_3;
246 rand_deg = DEG_3;
247 rand_sep = SEP_3;
248 }
249 else {
250 rand_type = TYPE_4;
251 rand_deg = DEG_4;
252 rand_sep = SEP_4;
253 }
254 }
255 }
256 }
257 state = &( ( (long *)arg_state )[1] ); /* first location */
258 end_ptr = &state[ rand_deg ]; /* must set end_ptr before srandom */
259 srandom( seed );
260 if( rand_type == TYPE_0 ) state[ -1 ] = rand_type;
261 else state[ -1 ] = MAX_TYPES*(rptr - state) + rand_type;
262 return( ostate );
263 }
264
265
266
267 /*
268 * setstate:
269 * Restore the state from the given state array.
270 * Note: it is important that we also remember the locations of the pointers
271 * in the current state information, and restore the locations of the pointers
272 * from the old state information. This is done by multiplexing the pointer
273 * location into the zeroeth word of the state information.
274 * Note that due to the order in which things are done, it is OK to call
275 * setstate() with the same state as the current state.
276 * Returns a pointer to the old state information.
277 */
278
279 char *
280 setstate( arg_state )
281
282 char *arg_state;
283 {
284 register long *new_state = (long *)arg_state;
285 register int type = new_state[0]%MAX_TYPES;
286 register int rear = new_state[0]/MAX_TYPES;
287 char *ostate = (char *)( &state[ -1 ] );
288
289 if( rand_type == TYPE_0 ) state[ -1 ] = rand_type;
290 else state[ -1 ] = MAX_TYPES*(rptr - state) + rand_type;
291 switch( type ) {
292 case TYPE_0:
293 case TYPE_1:
294 case TYPE_2:
295 case TYPE_3:
296 case TYPE_4:
297 rand_type = type;
298 rand_deg = degrees[ type ];
299 rand_sep = seps[ type ];
300 break;
301
302 default:
303 fprintf( stderr, "setstate: state info has been munged; not changed.\n" );
304 }
305 state = &new_state[ 1 ];
306 if( rand_type != TYPE_0 ) {
307 rptr = &state[ rear ];
308 fptr = &state[ (rear + rand_sep)%rand_deg ];
309 }
310 end_ptr = &state[ rand_deg ]; /* set end_ptr too */
311 return( ostate );
312 }
313
314
315
316 /*
317 * random:
318 * If we are using the trivial TYPE_0 R.N.G., just do the old linear
319 * congruential bit. Otherwise, we do our fancy trinomial stuff, which is the
320 * same in all ther other cases due to all the global variables that have been
321 * set up. The basic operation is to add the number at the rear pointer into
322 * the one at the front pointer. Then both pointers are advanced to the next
323 * location cyclically in the table. The value returned is the sum generated,
324 * reduced to 31 bits by throwing away the "least random" low bit.
325 * Note: the code takes advantage of the fact that both the front and
326 * rear pointers can't wrap on the same call by not testing the rear
327 * pointer if the front one has wrapped.
328 * Returns a 31-bit random number.
329 */
330
331 long
332 random()
333 {
334 long i;
335
336 if( rand_type == TYPE_0 ) {
337 i = state[0] = ( state[0]*1103515245 + 12345 )&0x7fffffff;
338 }
339 else {
340 *fptr += *rptr;
341 i = (*fptr >> 1)&0x7fffffff; /* chucking least random bit */
342 if( ++fptr >= end_ptr ) {
343 fptr = state;
344 ++rptr;
345 }
346 else {
347 if( ++rptr >= end_ptr ) rptr = state;
348 }
349 }
350 return( i );
351 }
352
