root/radiance/ray/src/common/radogl.h
Sun Mar 6 01:13:17 2016 UTC (8 years, 3 months ago) by schorsch
CVS Tags: HEAD, rad5R1, rad5R2, rad5R3, rad5R4
Diff to previous 3.12
Wed Apr 25 22:21:06 2012 UTC (12 years, 1 month ago) by greg
Changes since 3.11: +9 -2 lines
Diff to previous 3.11
Tue Sep 16 06:31:48 2003 UTC (20 years, 9 months ago) by greg
Diff to previous 3.10
Fixed prototype for freemtl() to match function pointer in lookup.h
Mon Jul 14 22:23:59 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 3.9: +5 -4 lines
Diff to previous 3.9
Changes since 3.8: +1 -4 lines
Diff to previous 3.8
Changes since 3.7: +2 -2 lines
Diff to previous 3.7
Fri Jun 6 16:38:47 2003 UTC (21 years ago) by schorsch
Changes since 3.6: +12 -44 lines
Diff to previous 3.6
*** empty log message ***
Wed Apr 23 02:28:06 2003 UTC (21 years, 1 month ago) by greg
Changes since 3.5: +2 -0 lines
Diff to previous 3.5
Added check for mesh primitive and warning when encountered
Changes since 3.4: +2 -57 lines
Diff to previous 3.4
Changes since 3.3: +145 -8 lines
Diff to previous 3.3
Wed Oct 21 17:48:06 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 3.2: +1 -1 lines
Diff to previous 3.2
modifications to avoid problems with redeclared BYTE type
Wed Jul 15 17:52:34 1998 UTC (25 years, 11 months ago) by gwlarson
Changes since 3.1: +1 -0 lines
change lightid to glightid and made global for convenience
Tue Jun 9 11:18:36 1998 UTC (26 years ago) by gwlarson
