root/radiance/ray/src/common/radogl.h
Revision: 3.9
Committed: Fri Jun 27 06:53:21 2003 UTC (21 years, 11 months ago) by greg
Changes since 3.8: +1 -4 lines
1 /* RCSid $Id: radogl.h,v 3.8 2003/06/26 00:58:09 schorsch Exp $ */
2 /*
3 * Header file for Radiance - OpenGL routines.
4 */
5 #ifndef _RAD_RADOGL_H_
6 #define _RAD_RADOGL_H_
7 #ifdef __cplusplus
8 extern "C" {
9 #endif
10
11 #include "standard.h"
12 #include <GL/glu.h>
13 #include "color.h"
14 #include "object.h"
15 #include "otypes.h"
16 #include "lookup.h"
17
18 #define MAXLIGHTS 8 /* number of OGL light sources */
19
20 #define MAXSPECEXP 128. /* maximum allowed specular exponent */
21 #define UNKSPECEXP 25. /* value to use when exponent unknown */
22
23 typedef struct {
24 short type; /* material type (from otypes.h) */
25 short nlinks; /* number of links to this material */
26 union {
27 struct {
28 COLOR ambdiff; /* ambient and diffuse color */
29 COLOR specular; /* specular color */
30 GLfloat specexp; /* specular exponent */
31 } m; /* regular material */
32 struct {
33 COLOR emission; /* emitting component */
34 GLfloat spotdir[3]; /* spot direction */
35 GLfloat spotang; /* spot cutoff angle */
36 } l; /* light source */
37 } u; /* union of types */
38 } MATREC; /* OGL material properties */
39
40 extern double expval; /* global exposure value */
41 extern COLOR ambval; /* global ambient value */
42 extern int glightid[MAXLIGHTS]; /* OpenGL GL_LIGHTi values */
43 extern int dolights; /* are we outputting light sources? */
44 extern int domats; /* are we doing materials? */
45
46 extern LUTAB mtab; /* material/modifier lookup table */
47
48 #define issrcmat(m) ((m) != NULL && islight((m)->type) && \
49 (m)->type != MAT_GLOW)
50
51 /* defined in rgldomat.c */
52 extern void domatobj(MATREC *mp, FVECT cent);
53 extern void domatvert(MATREC *mp, FVECT v, FVECT n);
54 /* defined in rglfile.c */
55 extern int newglist(void);
56 extern void rgl_checkerr(char *where);
57 extern int rgl_filelist(int ic, char **inp, int *nl);
58 extern int rgl_octlist(char *fname, FVECT cent, RREAL *radp, int *nl);
59 extern void rgl_load(char *inpspec);
60 extern void rgl_object(char *name, FILE *fp);
61 /* defined in rglinst.c */
62 extern int o_instance(OBJREC *o);
63 extern int loadoctrees(void);
64 extern double checkoct(char *fname, FVECT cent);
65 extern int loadoct(char *fname);
66 /* defined in rglmat.c */
67 extern void rgl_matclear(void);
68 extern MATREC *getmatp(char *nam);
69 extern int o_default(OBJREC *o);
70 extern int o_unsupported(OBJREC *o);
71 extern MATREC *newmaterial(char *nam);
72 extern void freemtl(MATREC *mp);
73 extern int m_normal(OBJREC *o);
74 extern int m_aniso(OBJREC *o);
75 extern int m_glass(OBJREC *o);
76 extern int m_brdf(OBJREC *o);
77 extern int m_brdf2(OBJREC *o);
78 extern int m_light(OBJREC *o);
79 extern int m_mirror(OBJREC *o);
80 extern int m_prism(OBJREC *o);
81 /* defined in rglsrc.c */
82 extern void lightinit(void);
83 extern void lightclean(void);
84 extern void lightdefs(void);
85 extern int o_source(OBJREC *o);
86 extern int doflatsrc(MATREC *m, FVECT pos, FVECT norm, double area);
87 extern int dosphsrc(MATREC *m, FVECT pos, double area);
88 /* defined in rglsurf.c */
89 extern void setmaterial(MATREC *mp, FVECT cent, int ispoly);
90 extern double polyarea(FVECT cent, FVECT norm, int n, FVECT v[]);
91 extern int o_face(OBJREC *o);
92 extern void surfclean(void);
93 extern int o_sphere(OBJREC *o);
94 extern int o_cone(OBJREC *o);
95 extern int o_ring(OBJREC *o);
96
97
98 #ifdef __cplusplus
99 }
100 #endif
101 #endif /* _RAD_RADOGL_H_ */
102
