root/radiance/ray/src/common/radogl.h
Revision: 3.8
Committed: Thu Jun 26 00:58:09 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 3.7: +2 -2 lines
1 /* RCSid $Id: radogl.h,v 3.7 2003/06/06 16:38:47 schorsch Exp $ */
2 /*
3 * Header file for Radiance - OpenGL routines.
4 */
5 #ifndef _RAD_RADOGL_H_
6 #define _RAD_RADOGL_H_
7 #ifdef __cplusplus
8 extern "C" {
9 #endif
10
11
12 #include "copyright.h"
13
14 #include "standard.h"
15 #include <GL/glu.h>
16 #include "color.h"
17 #include "object.h"
18 #include "otypes.h"
19 #include "lookup.h"
20
21 #define MAXLIGHTS 8 /* number of OGL light sources */
22
23 #define MAXSPECEXP 128. /* maximum allowed specular exponent */
24 #define UNKSPECEXP 25. /* value to use when exponent unknown */
25
26 typedef struct {
27 short type; /* material type (from otypes.h) */
28 short nlinks; /* number of links to this material */
29 union {
30 struct {
31 COLOR ambdiff; /* ambient and diffuse color */
32 COLOR specular; /* specular color */
33 GLfloat specexp; /* specular exponent */
34 } m; /* regular material */
35 struct {
36 COLOR emission; /* emitting component */
37 GLfloat spotdir[3]; /* spot direction */
38 GLfloat spotang; /* spot cutoff angle */
39 } l; /* light source */
40 } u; /* union of types */
41 } MATREC; /* OGL material properties */
42
43 extern double expval; /* global exposure value */
44 extern COLOR ambval; /* global ambient value */
45 extern int glightid[MAXLIGHTS]; /* OpenGL GL_LIGHTi values */
46 extern int dolights; /* are we outputting light sources? */
47 extern int domats; /* are we doing materials? */
48
49 extern LUTAB mtab; /* material/modifier lookup table */
50
51 #define issrcmat(m) ((m) != NULL && islight((m)->type) && \
52 (m)->type != MAT_GLOW)
53
54 /* defined in rgldomat.c */
55 extern void domatobj(MATREC *mp, FVECT cent);
56 extern void domatvert(MATREC *mp, FVECT v, FVECT n);
57 /* defined in rglfile.c */
58 extern int newglist(void);
59 extern void rgl_checkerr(char *where);
60 extern int rgl_filelist(int ic, char **inp, int *nl);
61 extern int rgl_octlist(char *fname, FVECT cent, RREAL *radp, int *nl);
62 extern void rgl_load(char *inpspec);
63 extern void rgl_object(char *name, FILE *fp);
64 /* defined in rglinst.c */
65 extern int o_instance(OBJREC *o);
66 extern int loadoctrees(void);
67 extern double checkoct(char *fname, FVECT cent);
68 extern int loadoct(char *fname);
69 /* defined in rglmat.c */
70 extern void rgl_matclear(void);
71 extern MATREC *getmatp(char *nam);
72 extern int o_default(OBJREC *o);
73 extern int o_unsupported(OBJREC *o);
74 extern MATREC *newmaterial(char *nam);
75 extern void freemtl(MATREC *mp);
76 extern int m_normal(OBJREC *o);
77 extern int m_aniso(OBJREC *o);
78 extern int m_glass(OBJREC *o);
79 extern int m_brdf(OBJREC *o);
80 extern int m_brdf2(OBJREC *o);
81 extern int m_light(OBJREC *o);
82 extern int m_mirror(OBJREC *o);
83 extern int m_prism(OBJREC *o);
84 /* defined in rglsrc.c */
85 extern void lightinit(void);
86 extern void lightclean(void);
87 extern void lightdefs(void);
88 extern int o_source(OBJREC *o);
89 extern int doflatsrc(MATREC *m, FVECT pos, FVECT norm, double area);
90 extern int dosphsrc(MATREC *m, FVECT pos, double area);
91 /* defined in rglsurf.c */
92 extern void setmaterial(MATREC *mp, FVECT cent, int ispoly);
93 extern double polyarea(FVECT cent, FVECT norm, int n, FVECT v[]);
94 extern int o_face(OBJREC *o);
95 extern void surfclean(void);
96 extern int o_sphere(OBJREC *o);
97 extern int o_cone(OBJREC *o);
98 extern int o_ring(OBJREC *o);
99
100
101 #ifdef __cplusplus
102 }
103 #endif
104 #endif /* _RAD_RADOGL_H_ */
105
