root/radiance/ray/src/common/radogl.h
Revision: 3.4
Committed: Sat Feb 22 02:07:22 2003 UTC (22 years, 3 months ago) by greg
Changes since 3.3: +145 -8 lines
1 /* RCSid: $Id$ */
2 /*
3 * Header file for Radiance - OpenGL routines.
4 */
5
6 /* ====================================================================
7 * The Radiance Software License, Version 1.0
8 *
9 * Copyright (c) 1990 - 2002 The Regents of the University of California,
10 * through Lawrence Berkeley National Laboratory. All rights reserved.
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 *
16 * 1. Redistributions of source code must retain the above copyright
17 * notice, this list of conditions and the following disclaimer.
18 *
19 * 2. Redistributions in binary form must reproduce the above copyright
20 * notice, this list of conditions and the following disclaimer in
21 * the documentation and/or other materials provided with the
22 * distribution.
23 *
24 * 3. The end-user documentation included with the redistribution,
25 * if any, must include the following acknowledgment:
26 * "This product includes Radiance software
27 * (http://radsite.lbl.gov/)
28 * developed by the Lawrence Berkeley National Laboratory
29 * (http://www.lbl.gov/)."
30 * Alternately, this acknowledgment may appear in the software itself,
31 * if and wherever such third-party acknowledgments normally appear.
32 *
33 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
34 * and "The Regents of the University of California" must
35 * not be used to endorse or promote products derived from this
36 * software without prior written permission. For written
37 * permission, please contact [email protected].
38 *
39 * 5. Products derived from this software may not be called "Radiance",
40 * nor may "Radiance" appear in their name, without prior written
41 * permission of Lawrence Berkeley National Laboratory.
42 *
43 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
44 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
45 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
46 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
47 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
48 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
49 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
50 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
51 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
52 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
53 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
54 * SUCH DAMAGE.
55 * ====================================================================
56 *
57 * This software consists of voluntary contributions made by many
58 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
59 * information on Lawrence Berkeley National Laboratory, please see
60 * <http://www.lbl.gov/>.
61 */
62
63 #include "standard.h"
64 #include <GL/glu.h>
65 #include "color.h"
66 #include "object.h"
67 #include "otypes.h"
68 #include "lookup.h"
69
70 #define MAXLIGHTS 8 /* number of OGL light sources */
71
72 #define MAXSPECEXP 128. /* maximum allowed specular exponent */
73 #define UNKSPECEXP 25. /* value to use when exponent unknown */
74
75 typedef struct {
76 short type; /* material type (from otypes.h) */
77 short nlinks; /* number of links to this material */
78 union {
79 struct {
80 COLOR ambdiff; /* ambient and diffuse color */
81 COLOR specular; /* specular color */
82 GLfloat specexp; /* specular exponent */
83 } m; /* regular material */
84 struct {
85 COLOR emission; /* emitting component */
86 GLfloat spotdir[3]; /* spot direction */
87 GLfloat spotang; /* spot cutoff angle */
88 } l; /* light source */
89 } u; /* union of types */
90 } MATREC; /* OGL material properties */
91
92 extern double expval; /* global exposure value */
93 extern COLOR ambval; /* global ambient value */
94 extern int glightid[MAXLIGHTS]; /* OpenGL GL_LIGHTi values */
95 extern int dolights; /* are we outputting light sources? */
96 extern int domats; /* are we doing materials? */
97
98 extern LUTAB mtab; /* material/modifier lookup table */
99
100 #define issrcmat(m) ((m) != NULL && islight((m)->type) && \
101 (m)->type != MAT_GLOW)
102
103 #ifdef NOPROTO
104
105 extern void domatobj();
106 extern void domatvert();
107 extern int newglist();
108 extern void rgl_checkerr();
109 extern int rgl_filelist();
110 extern int rgl_octlist();
111 extern void rgl_load();
112 extern void rgl_object();
113 extern int o_instance();
114 extern int loadoctrees();
115 extern double checkoct();
116 extern int loadoct();
117 extern void rgl_matclear();
118 extern MATREC *getmatp();
119 extern int o_default();
120 extern MATREC *newmaterial();
121 extern void freemtl();
122 extern int m_normal();
123 extern int m_aniso();
124 extern int m_glass();
125 extern int m_brdf();
126 extern int m_brdf2();
127 extern int m_light();
128 extern int m_mirror();
129 extern int m_prism();
130 extern void lightinit();
131 extern void lightclean();
132 extern void lightdefs();
133 extern int o_source();
134 extern int doflatsrc();
135 extern int dosphsrc();
136 extern void setmaterial();
137 extern double polyarea();
138 extern int o_face();
139 extern void surfclean();
140 extern int o_sphere();
141 extern int o_cone();
142 extern int o_ring();
143
144 #else
145 /* defined in rgldomat.c */
146 extern void domatobj(MATREC *mp, FVECT cent);
147 extern void domatvert(MATREC *mp, FVECT v, FVECT n);
148 /* defined in rglfile.c */
149 extern int newglist(void);
150 extern void rgl_checkerr(char *where);
151 extern int rgl_filelist(int ic, char **inp, int *nl);
152 extern int rgl_octlist(char *fname, FVECT cent, FLOAT *radp, int *nl);
153 extern void rgl_load(char *inpspec);
154 extern void rgl_object(char *name, FILE *fp);
155 /* defined in rglinst.c */
156 extern int o_instance(OBJREC *o);
157 extern int loadoctrees(void);
158 extern double checkoct(char *fname, FVECT cent);
159 extern int loadoct(char *fname);
160 /* defined in rglmat.c */
161 extern void rgl_matclear(void);
162 extern MATREC *getmatp(char *nam);
163 extern int o_default(OBJREC *o);
164 extern MATREC *newmaterial(char *nam);
165 extern void freemtl(MATREC *mp);
166 extern int m_normal(OBJREC *o);
167 extern int m_aniso(OBJREC *o);
168 extern int m_glass(OBJREC *o);
169 extern int m_brdf(OBJREC *o);
170 extern int m_brdf2(OBJREC *o);
171 extern int m_light(OBJREC *o);
172 extern int m_mirror(OBJREC *o);
173 extern int m_prism(OBJREC *o);
174 /* defined in rglsrc.c */
175 extern void lightinit(void);
176 extern void lightclean(void);
177 extern void lightdefs(void);
178 extern int o_source(OBJREC *o);
179 extern int doflatsrc(MATREC *m, FVECT pos, FVECT norm, double area);
180 extern int dosphsrc(MATREC *m, FVECT pos, double area);
181 /* defined in rglsurf.c */
182 extern void setmaterial(MATREC *mp, FVECT cent, int ispoly);
183 extern double polyarea(FVECT cent, FVECT norm, int n, FVECT v[]);
184 extern int o_face(OBJREC *o);
185 extern void surfclean(void);
186 extern int o_sphere(OBJREC *o);
187 extern int o_cone(OBJREC *o);
188 extern int o_ring(OBJREC *o);
189
190 #endif
