root/radiance/ray/src/common/radogl.h
Revision: 3.12
Committed: Wed Apr 25 22:21:06 2012 UTC (13 years ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad4R2, rad4R2P1
Changes since 3.11: +9 -2 lines
1 /* RCSid $Id: radogl.h,v 3.11 2003/09/16 06:31:48 greg Exp $ */
2 /*
3 * Header file for Radiance - OpenGL routines.
4 */
5 #ifndef _RAD_RADOGL_H_
6 #define _RAD_RADOGL_H_
7
8 #include "standard.h"
9 #ifdef __APPLE__
10 #include <OpenGL/glu.h>
11 #else
12 #ifdef _WIN32
13 #include <windows.h>
14 #endif
15 #include <GL/glu.h>
16 #endif
17 #include "color.h"
18 #include "object.h"
19 #include "otypes.h"
20 #include "lookup.h"
21
22 #ifdef __cplusplus
23 extern "C" {
24 #endif
25
26 #define MAXLIGHTS 8 /* number of OGL light sources */
27
28 #define MAXSPECEXP 128. /* maximum allowed specular exponent */
29 #define UNKSPECEXP 25. /* value to use when exponent unknown */
30
31 typedef struct {
32 short type; /* material type (from otypes.h) */
33 short nlinks; /* number of links to this material */
34 union {
35 struct {
36 COLOR ambdiff; /* ambient and diffuse color */
37 COLOR specular; /* specular color */
38 GLfloat specexp; /* specular exponent */
39 } m; /* regular material */
40 struct {
41 COLOR emission; /* emitting component */
42 GLfloat spotdir[3]; /* spot direction */
43 GLfloat spotang; /* spot cutoff angle */
44 } l; /* light source */
45 } u; /* union of types */
46 } MATREC; /* OGL material properties */
47
48 extern double expval; /* global exposure value */
49 extern COLOR ambval; /* global ambient value */
50 extern int glightid[MAXLIGHTS]; /* OpenGL GL_LIGHTi values */
51 extern int dolights; /* are we outputting light sources? */
52 extern int domats; /* are we doing materials? */
53
54 extern LUTAB mtab; /* material/modifier lookup table */
55
56 #define issrcmat(m) ((m) != NULL && islight((m)->type) && \
57 (m)->type != MAT_GLOW)
58
59 /* defined in rgldomat.c */
60 extern void domatobj(MATREC *mp, FVECT cent);
61 extern void domatvert(MATREC *mp, FVECT v, FVECT n);
62 /* defined in rglfile.c */
63 extern int newglist(void);
64 extern void rgl_checkerr(char *where);
65 extern int rgl_filelist(int ic, char **inp, int *nl);
66 extern int rgl_octlist(char *fname, FVECT cent, RREAL *radp, int *nl);
67 extern void rgl_load(char *inpspec);
68 extern void rgl_object(char *name, FILE *fp);
69 /* defined in rglinst.c */
70 extern int o_instance(OBJREC *o);
71 extern int loadoctrees(void);
72 extern double checkoct(char *fname, FVECT cent);
73 extern int loadoct(char *fname);
74 /* defined in rglmat.c */
75 extern void rgl_matclear(void);
76 extern MATREC *getmatp(char *nam);
77 extern int o_default(OBJREC *o);
78 extern int o_unsupported(OBJREC *o);
79 extern MATREC *newmaterial(char *nam);
80 extern void freemtl(void *p);
81 extern int m_normal(OBJREC *o);
82 extern int m_aniso(OBJREC *o);
83 extern int m_glass(OBJREC *o);
84 extern int m_brdf(OBJREC *o);
85 extern int m_brdf2(OBJREC *o);
86 extern int m_light(OBJREC *o);
87 extern int m_mirror(OBJREC *o);
88 extern int m_prism(OBJREC *o);
89 /* defined in rglsrc.c */
90 extern void lightinit(void);
91 extern void lightclean(void);
92 extern void lightdefs(void);
93 extern int o_source(OBJREC *o);
94 extern int doflatsrc(MATREC *m, FVECT pos, FVECT norm, double area);
95 extern int dosphsrc(MATREC *m, FVECT pos, double area);
96 /* defined in rglsurf.c */
97 extern void setmaterial(MATREC *mp, FVECT cent, int ispoly);
98 extern double polyarea(FVECT cent, FVECT norm, int n, FVECT v[]);
99 extern int o_face(OBJREC *o);
100 extern void surfclean(void);
101 extern int o_sphere(OBJREC *o);
102 extern int o_cone(OBJREC *o);
103 extern int o_ring(OBJREC *o);
104
105
106 #ifdef __cplusplus
107 }
108 #endif
109 #endif /* _RAD_RADOGL_H_ */
110
