root/Development/ray/src/common/radogl.h
Sun Mar 6 01:13:17 2016 UTC (9 years, 8 months ago) by schorsch
CVS Tags: HEAD, rad5R1, rad5R2, rad5R3, rad5R4, rad6R0
Diff to previous 3.12 , to selected 3.10
Wed Apr 25 22:21:06 2012 UTC (13 years, 6 months ago) by greg
Changes since 3.11: +9 -2 lines
Diff to previous 3.11 , to selected 3.10
Tue Sep 16 06:31:48 2003 UTC (22 years, 1 month ago) by greg
Diff to previous 3.10
Fixed prototype for freemtl() to match function pointer in lookup.h
Revision 3.10 - (view) (download) (annotate) - [selected]
Mon Jul 14 22:23:59 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 3.9: +5 -4 lines
Diff to previous 3.9
Fri Jun 27 06:53:21 2003 UTC (22 years, 4 months ago) by greg
Changes since 3.8: +1 -4 lines
Diff to previous 3.8 , to selected 3.10
Thu Jun 26 00:58:09 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 3.7: +2 -2 lines
Diff to previous 3.7 , to selected 3.10
Fri Jun 6 16:38:47 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 3.6: +12 -44 lines
Diff to previous 3.6 , to selected 3.10
*** empty log message ***
Wed Apr 23 02:28:06 2003 UTC (22 years, 6 months ago) by greg
Changes since 3.5: +2 -0 lines
Diff to previous 3.5 , to selected 3.10
Added check for mesh primitive and warning when encountered
Tue Feb 25 02:47:21 2003 UTC (22 years, 8 months ago) by greg
Changes since 3.4: +2 -57 lines
Diff to previous 3.4 , to selected 3.10
Sat Feb 22 02:07:22 2003 UTC (22 years, 8 months ago) by greg
Changes since 3.3: +145 -8 lines
Diff to previous 3.3 , to selected 3.10
Wed Oct 21 17:48:06 1998 UTC (27 years ago) by gwlarson
Changes since 3.2: +1 -1 lines
Diff to previous 3.2 , to selected 3.10
modifications to avoid problems with redeclared BYTE type
Wed Jul 15 17:52:34 1998 UTC (27 years, 4 months ago) by gwlarson
Changes since 3.1: +1 -0 lines
Diff to previous 3.1 , to selected 3.10
change lightid to glightid and made global for convenience
Tue Jun 9 11:18:36 1998 UTC (27 years, 5 months ago) by gwlarson
Diff to selected 3.10
