root/radiance/ray/src/common/radogl.h
Tue Sep 16 06:31:48 2003 UTC (20 years, 8 months ago) by greg
Diff to previous 3.10 , to selected 3.8
Fixed prototype for freemtl() to match function pointer in lookup.h
Mon Jul 14 22:23:59 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 3.9: +5 -4 lines
Diff to previous 3.9 , to selected 3.8
Changes since 3.8: +1 -4 lines
Diff to previous 3.8
Revision 3.8 - (view) (download) (annotate) - [selected]
Changes since 3.7: +2 -2 lines
Diff to previous 3.7
Fri Jun 6 16:38:47 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 3.6: +12 -44 lines
Diff to previous 3.6 , to selected 3.8
*** empty log message ***
Wed Apr 23 02:28:06 2003 UTC (21 years ago) by greg
Changes since 3.5: +2 -0 lines
Diff to previous 3.5 , to selected 3.8
Added check for mesh primitive and warning when encountered
Changes since 3.4: +2 -57 lines
Diff to previous 3.4 , to selected 3.8
Changes since 3.3: +145 -8 lines
Diff to previous 3.3 , to selected 3.8
Wed Oct 21 17:48:06 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 3.2: +1 -1 lines
Diff to previous 3.2 , to selected 3.8
modifications to avoid problems with redeclared BYTE type
Wed Jul 15 17:52:34 1998 UTC (25 years, 10 months ago) by gwlarson
Changes since 3.1: +1 -0 lines
Diff to previous 3.1 , to selected 3.8
change lightid to glightid and made global for convenience
Tue Jun 9 11:18:36 1998 UTC (25 years, 11 months ago) by gwlarson
Diff to selected 3.8
