--- ray/src/common/radogl.h 2003/04/23 02:28:06 3.6 +++ ray/src/common/radogl.h 2003/06/26 00:58:09 3.8 @@ -1,8 +1,14 @@ -/* RCSid $Id: radogl.h,v 3.6 2003/04/23 02:28:06 greg Exp $ */ +/* RCSid $Id: radogl.h,v 3.8 2003/06/26 00:58:09 schorsch Exp $ */ /* * Header file for Radiance - OpenGL routines. */ +#ifndef _RAD_RADOGL_H_ +#define _RAD_RADOGL_H_ +#ifdef __cplusplus +extern "C" { +#endif + #include "copyright.h" #include "standard.h" @@ -45,49 +51,6 @@ extern LUTAB mtab; /* material/modifier lookup table #define issrcmat(m) ((m) != NULL && islight((m)->type) && \ (m)->type != MAT_GLOW) -#ifdef NOPROTO - -extern void domatobj(); -extern void domatvert(); -extern int newglist(); -extern void rgl_checkerr(); -extern int rgl_filelist(); -extern int rgl_octlist(); -extern void rgl_load(); -extern void rgl_object(); -extern int o_instance(); -extern int loadoctrees(); -extern double checkoct(); -extern int loadoct(); -extern void rgl_matclear(); -extern MATREC *getmatp(); -extern int o_default(); -extern int o_unsupported(); -extern MATREC *newmaterial(); -extern void freemtl(); -extern int m_normal(); -extern int m_aniso(); -extern int m_glass(); -extern int m_brdf(); -extern int m_brdf2(); -extern int m_light(); -extern int m_mirror(); -extern int m_prism(); -extern void lightinit(); -extern void lightclean(); -extern void lightdefs(); -extern int o_source(); -extern int doflatsrc(); -extern int dosphsrc(); -extern void setmaterial(); -extern double polyarea(); -extern int o_face(); -extern void surfclean(); -extern int o_sphere(); -extern int o_cone(); -extern int o_ring(); - -#else /* defined in rgldomat.c */ extern void domatobj(MATREC *mp, FVECT cent); extern void domatvert(MATREC *mp, FVECT v, FVECT n); @@ -95,7 +58,7 @@ extern void domatvert(MATREC *mp, FVECT v, FVECT n); extern int newglist(void); extern void rgl_checkerr(char *where); extern int rgl_filelist(int ic, char **inp, int *nl); -extern int rgl_octlist(char *fname, FVECT cent, FLOAT *radp, int *nl); +extern int rgl_octlist(char *fname, FVECT cent, RREAL *radp, int *nl); extern void rgl_load(char *inpspec); extern void rgl_object(char *name, FILE *fp); /* defined in rglinst.c */ @@ -134,4 +97,9 @@ extern int o_sphere(OBJREC *o); extern int o_cone(OBJREC *o); extern int o_ring(OBJREC *o); + +#ifdef __cplusplus +} #endif +#endif /* _RAD_RADOGL_H_ */ +
