root/radiance/ray/src/common/pyradlib/pyrad_proc.py
Revision: 1.2
Committed: Wed Mar 30 18:02:06 2016 UTC (9 years, 1 month ago) by schorsch
Content type: text/x-python
Changes since 1.1: +42 -59 lines
unify argument parsing
1 # -*- coding: utf-8 -*-
2 ''' pyrad_proc.py - Process and pipeline management for Python Radiance scripts
3 2016 - Georg Mischler
4
5 Use as:
6 from pyradlib.pyrad_proc import PIPE, Error, ProcMixin
7
8 For a single-file installation, include the contents of this file
9 at the same place (minus the __future__ import below).
10 '''
11 from __future__ import division, print_function, unicode_literals
12
13 import sys
14 import subprocess
15 PIPE = subprocess.PIPE
16
17
18 class Error(Exception): pass
19
20
21 class ProcMixin():
22 '''Process and pipeline management for Python Radiance scripts
23 '''
24 def raise_on_error(self, actstr, e):
25 raise Error('Unable to %s - %s' % (actstr, str(e)))
26
27 def __configure_subprocess(self):
28 '''Prevent subprocess module failure in frozen scripts on Windows.
29 Prevent console windows from popping up when not console based.
30 Make sure we use the version-specific string types.
31 '''
32 # On Windows, sys.stdxxx may not be available when:
33 # - built as *.exe with "pyinstaller --noconsole"
34 # - invoked via CreateProcess() and stream not redirected
35 try:
36 sys.__stdin__.fileno()
37 self._stdin = sys.stdin
38 except: self._stdin = PIPE
39 try:
40 sys.__stdout__.fileno()
41 self._stdout = sys.stdout
42 except: self._stdout = PIPE
43 try:
44 sys.__stderr__.fileno()
45 self._stderr = sys.stderr
46 # keep subprocesses from opening their own console.
47 except: self._stderr = PIPE
48 if hasattr(subprocess, 'STARTUPINFO'):
49 si = subprocess.STARTUPINFO()
50 si.dwFlags |= subprocess.STARTF_USESHOWWINDOW
51 self._pipeargs = {'startupinfo':si}
52 else: self._pipeargs = {}
53 # type names vary between Py2.7 and 3.x
54 self._strtypes = (type(b''), type(u''))
55 # private attribute to indicate established configuration
56 self.__proc_mixin_setup = True
57
58 def qjoin(self, sl):
59 '''Join a list with quotes around each element containing whitespace.
60 We only use this to display command lines on sys.stderr, the actual
61 Popen() calls are made with the original list.
62 '''
63 def _q(s):
64 if ' ' in s or '\t' in s or ';' in s:
65 return "'" + s + "'"
66 return s
67 return ' '.join([_q(s) for s in sl])
68
69 def __parse_args(self, _in, out):
70 try: self.__proc_mixin_setup
71 except AttributeError: self.__configure_subprocess()
72 instr = ''
73 if _in == PIPE:
74 stdin = _in
75 elif isinstance(_in, self._strtypes):
76 stdin = open(_in, 'rb')
77 instr = ' < "%s"' % _in
78 elif hasattr(_in, 'read'):
79 stdin = _in
80 instr = ' < "%s"' % _in.name
81 else: stdin = self._stdin
82 outstr = ''
83 if out == PIPE:
84 stdout = out
85 elif isinstance(out, self._strtypes):
86 stdout = open(out, 'wb')
87 outstr = ' > "%s"' % out
88 elif hasattr(out, 'write'):
89 stdout = out
90 outstr = ' > "%s"' % out.name
91 else: stdout = self._stdout
92 return stdin, stdout, instr, outstr
93
94 def call_one(self, cmdl, actstr, _in=None, out=None,
95 universal_newlines=False):
96 '''Create a single subprocess, possibly with an incoming and outgoing
97 pipe at each end.
98 - cmdl
99 A list of strings, leading with the name of the executable (without
100 the *.exe suffix), followed by individual arguments.
101 - actstr
102 A text string of the form "do something".
103 Used in verbose mode as "### do someting\\n### [command line]"
104 Used in error messages as "Scriptname: Unable to do something".
105 - _in / out
106 What to do with the input and output pipes of the process:
107 * a filename as string
108 Open file and use for reading/writing.
109 * a file like object
110 Use for reading/writing
111 * PIPE
112 Pipe will be available in returned object for reading/writing.
113 * None (default)
114 System stdin/stdout will be used if available
115 If _in or out is a PIPE, the caller should call p.wait() on the
116 returned Popen instance after writing to and closing it.
117 '''
118 stdin, stdout, instr, outstr = self.__parse_args(_in, out)
119 if getattr(self, 'verbose', None):
120 sys.stderr.write('### %s \n' % actstr)
121 sys.stderr.write(self.qjoin(cmdl) + instr + outstr + '\n')
122 if not getattr(self, 'donothing', None):
123 try: p = subprocess.Popen(cmdl,
124 stdin=stdin, stdout=stdout, stderr=self._stderr,
125 universal_newlines=universal_newlines, **self._pipeargs)
126 except Exception as e:
127 self.raise_on_error(actstr, str(e))
128 if stdin != PIPE and stdout != PIPE:
129 # caller needs to wait after reading or writing (else deadlock)
130 res = p.wait()
131 if res != 0:
132 self.raise_on_error(actstr,
133 'Nonzero exit (%d) from command [%s].'
134 % (res, self.qjoin(cmdl)+instr+outstr+'\n'))
135 return p
136
137 def call_two(self, cmdl_1, cmdl_2, actstr_1, actstr_2, _in=None, out=None,
138 universal_newlines=False):
139 '''Create two processes, chained via a pipe, possibly with an incoming
140 and outgoing pipe at each end.
141 Returns a tuple of two Popen instances.
142 Arguments are equivalent to call_one(), with _in and out applying
143 to the ends of the chain.
144 If _in or out is PIPE, the caller should call p.wait() on both
145 returned popen instances after writing to and closing the first on .
146 '''
147 stdin, stdout, instr, outstr = self.__parse_args(_in, out)
148 if getattr(self, 'verbose', None):
149 sys.stderr.write('### %s \n' % actstr_1)
150 sys.stderr.write('### %s \n' % actstr_2)
151 sys.stderr.write(self.qjoin(cmdl_1) + instr + ' | ')
152 if not getattr(self, 'donothing', None):
153 try: p1 = subprocess.Popen(cmdl_1,
154 stdin=stdin, stdout=PIPE, stderr=self._stderr,
155 **self._pipeargs)
156 except Exception as e:
157 self.raise_on_error(actstr_1, str(e))
158 if getattr(self, 'verbose', None):
159 sys.stderr.write(self.qjoin(cmdl_2) + outstr + '\n')
160 if not getattr(self, 'donothing', None):
161 try:
162 p2 = subprocess.Popen(cmdl_2,
163 stdin=p1.stdout, stdout=stdout, stderr=self._stderr,
164 universal_newlines=universal_newlines, **self._pipeargs)
165 p1.stdout.close()
166 except Exception as e:
167 self.raise_on_error(actstr_2, str(e))
168 if stdin != PIPE and stdout != PIPE:
169 # caller needs to wait after reading or writing (else deadlock)
170 res = p1.wait()
171 if res != 0:
172 self.raise_on_error(actstr_1,
173 'Nonzero exit (%d) from command [%s].'
174 % (res, self.qjoin(cmdl_1)))
175 res = p2.wait()
176 if res != 0:
177 self.raise_on_error(actstr_2,
178 'Nonzero exit (%d) from command [%s].'
179 % (res, self.qjoin(cmdl_2)))
180 return p1, p2
181
182 def call_many(self, cmdlines, actstr, _in=None, out=None,
183 universal_newlines=False):
184 '''Create a series of N processes, chained via pipes, possibly with an
185 incoming and outgoing pipe at each end.
186 Returns a tuple of N subprocess.Popen instances.
187 Depending on the values of _in and out, the first and last may be
188 available to write to or read from respectively.
189 Most arguments are equivalent to call_one(), with
190 - cmdlines
191 a list of N command argument lists
192 - _in / out
193 applying to the ends of the chain.
194 If _in or out is PIPE, the caller should call p.wait() on all
195 returned Popen instances after writing to and closing the first one.
196 '''
197 if len(cmdlines) == 1:
198 # other than direct call_one(), this returns a one-item tuple!
199 return (self.call_one(cmdlines[0], actstr, _in=_in, out=out,
200 universal_newlines=universal_newlines),)
201 stdin, stdout, instr, outstr = self.__parse_args(_in, out)
202 procs = []
203 if getattr(self, 'verbose', None):
204 sys.stderr.write('### %s \n' % actstr)
205 sys.stderr.write(self.qjoin(cmdlines[0]) + instr + ' | ')
206 if not getattr(self, 'donothing', None):
207 try:
208 prevproc = subprocess.Popen(cmdlines[0], stdin=stdin,
209 stdout=PIPE, stderr=self._stderr, **self._pipeargs)
210 procs.append(prevproc)
211 except Exception as e:
212 self.raise_on_error(actstr, str(e))
213
214 for cmdl in cmdlines[1:-1]:
215 if getattr(self, 'verbose', None):
216 sys.stderr.write(self.qjoin(cmdl) + ' | ')
217 if not getattr(self, 'donothing', None):
218 try:
219 nextproc = subprocess.Popen(cmdl, stdin=prevproc.stdout,
220 stdout=PIPE, stderr=self._stderr, **self._pipeargs)
221 procs.append(nextproc)
222 prevproc.stdout.close()
223 prevproc = nextproc
224 except Exception as e:
225 self.raise_on_error(actstr, str(e))
226
227 if getattr(self, 'verbose', None):
228 sys.stderr.write(self.qjoin(cmdlines[-1]) + outstr + '\n')
229 if not getattr(self, 'donothing', None):
230 try:
231 lastproc = subprocess.Popen(cmdlines[-1], stdin=prevproc.stdout,
232 stdout=stdout, stderr=self._stderr,
233 universal_newlines=universal_newlines, **self._pipeargs)
234 prevproc.stdout.close()
235 procs.append(lastproc)
236 prevproc.stdout.close()
237 except Exception as e:
238 self.raise_on_error(actstr, str(e))
239
240 if stdin != PIPE and stdout!= PIPE:
241 # caller needs to wait after reading or writing (else deadlock)
242 for proc, cmdl in zip(procs, cmdlines):
243 res = proc.wait()
244 if res != 0:
245 self.raise_on_error(actstr,
246 'Nonzero exit (%d) from command [%s].'
247 % (res, self.qjoin(cmdl)))
248 return procs
249
250
251 ### end of proc_mixin.py
