1 |
# -*- coding: utf-8 -*- |
2 |
''' pyrad_proc.py - Process and pipeline management for Python Radiance scripts |
3 |
2016 - Georg Mischler |
4 |
5 |
Use as: |
6 |
from pyradlib.pyrad_proc import PIPE, Error, ProcMixin |
7 |
8 |
For a single-file installation, include the contents of this file |
9 |
at the same place (minus the __future__ import below). |
10 |
11 |
from __future__ import division, print_function, unicode_literals |
12 |
13 |
import sys |
14 |
import subprocess |
15 |
PIPE = subprocess.PIPE |
16 |
17 |
18 |
class Error(Exception): pass |
19 |
20 |
21 |
class ProcMixin(): |
22 |
'''Process and pipeline management for Python Radiance scripts |
23 |
24 |
def raise_on_error(self, actstr, e): |
25 |
if hasattr(e, 'strerror'): eb = e.strerror |
26 |
elif isinstance(e, self._strtypes): eb = e |
27 |
else: eb = e |
28 |
if isinstance(eb, type(b'')): |
29 |
estr = eb.decode(encoding='utf-8', errors='ignore') |
30 |
else: estr = eb |
31 |
raise Error('Unable to %s - %s' % (actstr, estr)) # |
32 |
33 |
def __configure_subprocess(self): |
34 |
'''Prevent subprocess module failure in frozen scripts on Windows. |
35 |
Prevent console windows from popping up when not console based. |
36 |
Make sure we use the version-specific string types. |
37 |
38 |
# On Windows, sys.stdxxx may not be available when: |
39 |
# - built as *.exe with "pyinstaller --noconsole" |
40 |
# - invoked via CreateProcess() and stream not redirected |
41 |
try: |
42 |
sys.__stdin__.fileno() |
43 |
self._stdin = sys.stdin |
44 |
except: self._stdin = PIPE |
45 |
try: |
46 |
sys.__stdout__.fileno() |
47 |
self._stdout = sys.stdout |
48 |
except: self._stdout = PIPE |
49 |
try: |
50 |
sys.__stderr__.fileno() |
51 |
self._stderr = sys.stderr |
52 |
# keep subprocesses from opening their own console. |
53 |
except: self._stderr = PIPE |
54 |
if hasattr(subprocess, 'STARTUPINFO'): |
55 |
si = subprocess.STARTUPINFO() |
56 |
si.dwFlags |= subprocess.STARTF_USESHOWWINDOW |
57 |
self._pipeargs = {'startupinfo':si} |
58 |
else: self._pipeargs = {} |
59 |
# type names vary between Py2.7 and 3.x |
60 |
self._strtypes = (type(b''), type(u'')) |
61 |
# private attribute to indicate established configuration |
62 |
self.__proc_mixin_setup = True |
63 |
64 |
def qjoin(self, sl): |
65 |
'''Join a list with quotes around each element containing whitespace. |
66 |
We only use this to display command lines on sys.stderr, the actual |
67 |
Popen() calls are made with the original list. |
68 |
69 |
def _q(s): |
70 |
if ' ' in s or '\t' in s or ';' in s: |
71 |
return "'" + s + "'" |
72 |
return s |
73 |
return ' '.join([_q(s) for s in sl]) |
74 |
75 |
def __parse_args(self, _in, out): |
76 |
try: self.__proc_mixin_setup |
77 |
except AttributeError: self.__configure_subprocess() |
78 |
instr = '' |
79 |
if _in == PIPE: |
80 |
stdin = _in |
81 |
elif isinstance(_in, self._strtypes): |
82 |
if not getattr(self, 'donothing', None): |
83 |
stdin = open(_in, 'rb') |
84 |
else: stdin = None |
85 |
instr = ' < "%s"' % _in |
86 |
elif hasattr(_in, 'read'): |
87 |
stdin = _in |
88 |
instr = ' < "%s"' % _in.name |
89 |
else: stdin = self._stdin |
90 |
outstr = '' |
91 |
if out == PIPE: |
92 |
stdout = out |
93 |
elif isinstance(out, self._strtypes): |
94 |
95 |
stdout = open(out, 'wb') |
96 |
else: stdout = None |
97 |
outstr = ' > "%s"' % out |
98 |
elif hasattr(out, 'write'): |
99 |
stdout = out |
100 |
outstr = ' > "%s"' % out.name |
101 |
else: stdout = self._stdout |
102 |
return stdin, stdout, instr, outstr |
103 |
104 |
def call_one(self, cmdl, actstr, _in=None, out=None, |
105 |
universal_newlines=False): |
106 |
'''Create a single subprocess, possibly with an incoming and outgoing |
107 |
pipe at each end. |
108 |
- cmdl |
109 |
A list of strings, leading with the name of the executable (without |
110 |
the *.exe suffix), followed by individual arguments. |
111 |
- actstr |
112 |
A text string of the form "do something". |
113 |
Used in verbose mode as "### do someting\\n### [command line]" |
114 |
Used in error messages as "Scriptname: Unable to do something". |
115 |
- _in / out |
116 |
What to do with the input and output pipes of the process: |
117 |
* a filename as string |
118 |
Open file and use for reading/writing. |
119 |
* a file like object |
120 |
Use for reading/writing |
121 |
* PIPE |
122 |
Pipe will be available in returned object for reading/writing. |
123 |
* None (default) |
124 |
System stdin/stdout will be used if available |
125 |
If _in or out is a PIPE, the caller should call p.wait() on the |
126 |
returned Popen instance after writing to and closing it. |
127 |
128 |
stdin, stdout, instr, outstr = self.__parse_args(_in, out) |
129 |
if getattr(self, 'verbose', None): |
130 |
sys.stderr.write('### %s \n' % actstr) |
131 |
sys.stderr.write(self.qjoin(cmdl) + instr + outstr + '\n') |
132 |
133 |
try: p = subprocess.Popen(cmdl, |
134 |
stdin=stdin, stdout=stdout, stderr=self._stderr, |
135 |
universal_newlines=universal_newlines, **self._pipeargs) |
136 |
except Exception as e: |
137 |
self.raise_on_error(actstr, e) |
138 |
if stdin != PIPE and stdout != PIPE: |
139 |
# caller needs to wait after reading or writing (else deadlock) |
140 |
res = p.wait() |
141 |
if res != 0: |
142 |
self.raise_on_error(actstr, |
143 |
'Nonzero exit (%d) from command [%s].' |
144 |
% (res, self.qjoin(cmdl)+instr+outstr+'\n')) |
145 |
return p |
146 |
147 |
def call_two(self, cmdl_1, cmdl_2, actstr_1, actstr_2, _in=None, out=None, |
148 |
149 |
'''Create two processes, chained via a pipe, possibly with an incoming |
150 |
and outgoing pipe at each end. |
151 |
Returns a tuple of two Popen instances. |
152 |
Arguments are equivalent to call_one(), with _in and out applying |
153 |
to the ends of the chain. |
154 |
If _in or out is PIPE, the caller should call p.wait() on both |
155 |
returned popen instances after writing to and closing the first on . |
156 |
157 |
158 |
159 |
sys.stderr.write('### %s \n' % actstr_1) |
160 |
sys.stderr.write('### %s \n' % actstr_2) |
161 |
sys.stderr.write(self.qjoin(cmdl_1) + instr + ' | ') |
162 |
163 |
try: p1 = subprocess.Popen(cmdl_1, |
164 |
stdin=stdin, stdout=PIPE, stderr=self._stderr, |
165 |
**self._pipeargs) |
166 |
167 |
self.raise_on_error(actstr_1, e) |
168 |
169 |
sys.stderr.write(self.qjoin(cmdl_2) + outstr + '\n') |
170 |
171 |
try: |
172 |
p2 = subprocess.Popen(cmdl_2, |
173 |
stdin=p1.stdout, stdout=stdout, stderr=self._stderr, |
174 |
175 |
p1.stdout.close() |
176 |
177 |
self.raise_on_error(actstr_2, e) |
178 |
179 |
180 |
res = p1.wait() |
181 |
if res != 0: |
182 |
self.raise_on_error(actstr_1, |
183 |
184 |
% (res, self.qjoin(cmdl_1))) |
185 |
res = p2.wait() |
186 |
if res != 0: |
187 |
self.raise_on_error(actstr_2, |
188 |
189 |
% (res, self.qjoin(cmdl_2))) |
190 |
return p1, p2 |
191 |
192 |
def call_many(self, cmdlines, actstr, _in=None, out=None, |
193 |
194 |
'''Create a series of N processes, chained via pipes, possibly with an |
195 |
incoming and outgoing pipe at each end. |
196 |
Returns a tuple of N subprocess.Popen instances. |
197 |
Depending on the values of _in and out, the first and last may be |
198 |
available to write to or read from respectively. |
199 |
Most arguments are equivalent to call_one(), with |
200 |
- cmdlines |
201 |
a list of N command argument lists |
202 |
- _in / out |
203 |
applying to the ends of the chain. |
204 |
If _in or out is PIPE, the caller should call p.wait() on all |
205 |
returned Popen instances after writing to and closing the first one. |
206 |
207 |
if len(cmdlines) == 1: |
208 |
# other than direct call_one(), this returns a one-item tuple! |
209 |
return (self.call_one(cmdlines[0], actstr, _in=_in, out=out, |
210 |
universal_newlines=universal_newlines),) |
211 |
212 |
procs = [] |
213 |
214 |
215 |
sys.stderr.write(self.qjoin(cmdlines[0]) + instr + ' | ') |
216 |
217 |
try: |
218 |
prevproc = subprocess.Popen(cmdlines[0], stdin=stdin, |
219 |
stdout=PIPE, stderr=self._stderr, **self._pipeargs) |
220 |
procs.append(prevproc) |
221 |
222 |
223 |
224 |
for cmdl in cmdlines[1:-1]: |
225 |
226 |
sys.stderr.write(self.qjoin(cmdl) + ' | ') |
227 |
228 |
try: |
229 |
nextproc = subprocess.Popen(cmdl, stdin=prevproc.stdout, |
230 |
231 |
procs.append(nextproc) |
232 |
prevproc.stdout.close() |
233 |
prevproc = nextproc |
234 |
235 |
236 |
237 |
238 |
sys.stderr.write(self.qjoin(cmdlines[-1]) + outstr + '\n') |
239 |
240 |
try: |
241 |
lastproc = subprocess.Popen(cmdlines[-1], stdin=prevproc.stdout, |
242 |
243 |
244 |
245 |
procs.append(lastproc) |
246 |
247 |
248 |
249 |
250 |
if stdin != PIPE and stdout!= PIPE: |
251 |
252 |
for proc, cmdl in zip(procs, cmdlines): |
253 |
res = proc.wait() |
254 |
if res != 0: |
255 |
256 |
257 |
% (res, self.qjoin(cmdl))) |
258 |
return procs |
259 |
260 |
261 |
### end of proc_mixin.py |
