root/radiance/ray/src/common/pyradlib/pyrad_proc.py
Revision: 1.3
Committed: Sat Apr 2 15:52:48 2016 UTC (9 years, 3 months ago) by schorsch
Content type: text/x-python
Changes since 1.2: +17 -9 lines
more robustness
1 # -*- coding: utf-8 -*-
2 ''' pyrad_proc.py - Process and pipeline management for Python Radiance scripts
3 2016 - Georg Mischler
4
5 Use as:
6 from pyradlib.pyrad_proc import PIPE, Error, ProcMixin
7
8 For a single-file installation, include the contents of this file
9 at the same place (minus the __future__ import below).
10 '''
11 from __future__ import division, print_function, unicode_literals
12
13 import sys
14 import subprocess
15 PIPE = subprocess.PIPE
16
17
18 class Error(Exception): pass
19
20
21 class ProcMixin():
22 '''Process and pipeline management for Python Radiance scripts
23 '''
24 def raise_on_error(self, actstr, e):
25 if hasattr(e, 'strerror'): eb = e.strerror
26 elif isinstance(e, self._strtypes): eb = e
27 else: eb = e
28 if isinstance(eb, type(b'')):
29 estr = eb.decode(encoding='utf-8', errors='ignore')
30 else: estr = eb
31 raise Error('Unable to %s - %s' % (actstr, estr)) #
32
33 def __configure_subprocess(self):
34 '''Prevent subprocess module failure in frozen scripts on Windows.
35 Prevent console windows from popping up when not console based.
36 Make sure we use the version-specific string types.
37 '''
38 # On Windows, sys.stdxxx may not be available when:
39 # - built as *.exe with "pyinstaller --noconsole"
40 # - invoked via CreateProcess() and stream not redirected
41 try:
42 sys.__stdin__.fileno()
43 self._stdin = sys.stdin
44 except: self._stdin = PIPE
45 try:
46 sys.__stdout__.fileno()
47 self._stdout = sys.stdout
48 except: self._stdout = PIPE
49 try:
50 sys.__stderr__.fileno()
51 self._stderr = sys.stderr
52 # keep subprocesses from opening their own console.
53 except: self._stderr = PIPE
54 if hasattr(subprocess, 'STARTUPINFO'):
55 si = subprocess.STARTUPINFO()
56 si.dwFlags |= subprocess.STARTF_USESHOWWINDOW
57 self._pipeargs = {'startupinfo':si}
58 else: self._pipeargs = {}
59 # type names vary between Py2.7 and 3.x
60 self._strtypes = (type(b''), type(u''))
61 # private attribute to indicate established configuration
62 self.__proc_mixin_setup = True
63
64 def qjoin(self, sl):
65 '''Join a list with quotes around each element containing whitespace.
66 We only use this to display command lines on sys.stderr, the actual
67 Popen() calls are made with the original list.
68 '''
69 def _q(s):
70 if ' ' in s or '\t' in s or ';' in s:
71 return "'" + s + "'"
72 return s
73 return ' '.join([_q(s) for s in sl])
74
75 def __parse_args(self, _in, out):
76 try: self.__proc_mixin_setup
77 except AttributeError: self.__configure_subprocess()
78 instr = ''
79 if _in == PIPE:
80 stdin = _in
81 elif isinstance(_in, self._strtypes):
82 if self.donothing: stdin = None
83 else: stdin = open(_in, 'rb')
84 instr = ' < "%s"' % _in
85 elif hasattr(_in, 'read'):
86 stdin = _in
87 instr = ' < "%s"' % _in.name
88 else: stdin = self._stdin
89 outstr = ''
90 if out == PIPE:
91 stdout = out
92 elif isinstance(out, self._strtypes):
93 if self.donothing: stdout = None
94 else: stdout = open(out, 'wb')
95 outstr = ' > "%s"' % out
96 elif hasattr(out, 'write'):
97 stdout = out
98 outstr = ' > "%s"' % out.name
99 else: stdout = self._stdout
100 return stdin, stdout, instr, outstr
101
102 def call_one(self, cmdl, actstr, _in=None, out=None,
103 universal_newlines=False):
104 '''Create a single subprocess, possibly with an incoming and outgoing
105 pipe at each end.
106 - cmdl
107 A list of strings, leading with the name of the executable (without
108 the *.exe suffix), followed by individual arguments.
109 - actstr
110 A text string of the form "do something".
111 Used in verbose mode as "### do someting\\n### [command line]"
112 Used in error messages as "Scriptname: Unable to do something".
113 - _in / out
114 What to do with the input and output pipes of the process:
115 * a filename as string
116 Open file and use for reading/writing.
117 * a file like object
118 Use for reading/writing
119 * PIPE
120 Pipe will be available in returned object for reading/writing.
121 * None (default)
122 System stdin/stdout will be used if available
123 If _in or out is a PIPE, the caller should call p.wait() on the
124 returned Popen instance after writing to and closing it.
125 '''
126 stdin, stdout, instr, outstr = self.__parse_args(_in, out)
127 if getattr(self, 'verbose', None):
128 sys.stderr.write('### %s \n' % actstr)
129 sys.stderr.write(self.qjoin(cmdl) + instr + outstr + '\n')
130 if not getattr(self, 'donothing', None):
131 try: p = subprocess.Popen(cmdl,
132 stdin=stdin, stdout=stdout, stderr=self._stderr,
133 universal_newlines=universal_newlines, **self._pipeargs)
134 except Exception as e:
135 self.raise_on_error(actstr, e)
136 if stdin != PIPE and stdout != PIPE:
137 # caller needs to wait after reading or writing (else deadlock)
138 res = p.wait()
139 if res != 0:
140 self.raise_on_error(actstr,
141 'Nonzero exit (%d) from command [%s].'
142 % (res, self.qjoin(cmdl)+instr+outstr+'\n'))
143 return p
144
145 def call_two(self, cmdl_1, cmdl_2, actstr_1, actstr_2, _in=None, out=None,
146 universal_newlines=False):
147 '''Create two processes, chained via a pipe, possibly with an incoming
148 and outgoing pipe at each end.
149 Returns a tuple of two Popen instances.
150 Arguments are equivalent to call_one(), with _in and out applying
151 to the ends of the chain.
152 If _in or out is PIPE, the caller should call p.wait() on both
153 returned popen instances after writing to and closing the first on .
154 '''
155 stdin, stdout, instr, outstr = self.__parse_args(_in, out)
156 if getattr(self, 'verbose', None):
157 sys.stderr.write('### %s \n' % actstr_1)
158 sys.stderr.write('### %s \n' % actstr_2)
159 sys.stderr.write(self.qjoin(cmdl_1) + instr + ' | ')
160 if not getattr(self, 'donothing', None):
161 try: p1 = subprocess.Popen(cmdl_1,
162 stdin=stdin, stdout=PIPE, stderr=self._stderr,
163 **self._pipeargs)
164 except Exception as e:
165 self.raise_on_error(actstr_1, e)
166 if getattr(self, 'verbose', None):
167 sys.stderr.write(self.qjoin(cmdl_2) + outstr + '\n')
168 if not getattr(self, 'donothing', None):
169 try:
170 p2 = subprocess.Popen(cmdl_2,
171 stdin=p1.stdout, stdout=stdout, stderr=self._stderr,
172 universal_newlines=universal_newlines, **self._pipeargs)
173 p1.stdout.close()
174 except Exception as e:
175 self.raise_on_error(actstr_2, e)
176 if stdin != PIPE and stdout != PIPE:
177 # caller needs to wait after reading or writing (else deadlock)
178 res = p1.wait()
179 if res != 0:
180 self.raise_on_error(actstr_1,
181 'Nonzero exit (%d) from command [%s].'
182 % (res, self.qjoin(cmdl_1)))
183 res = p2.wait()
184 if res != 0:
185 self.raise_on_error(actstr_2,
186 'Nonzero exit (%d) from command [%s].'
187 % (res, self.qjoin(cmdl_2)))
188 return p1, p2
189
190 def call_many(self, cmdlines, actstr, _in=None, out=None,
191 universal_newlines=False):
192 '''Create a series of N processes, chained via pipes, possibly with an
193 incoming and outgoing pipe at each end.
194 Returns a tuple of N subprocess.Popen instances.
195 Depending on the values of _in and out, the first and last may be
196 available to write to or read from respectively.
197 Most arguments are equivalent to call_one(), with
198 - cmdlines
199 a list of N command argument lists
200 - _in / out
201 applying to the ends of the chain.
202 If _in or out is PIPE, the caller should call p.wait() on all
203 returned Popen instances after writing to and closing the first one.
204 '''
205 if len(cmdlines) == 1:
206 # other than direct call_one(), this returns a one-item tuple!
207 return (self.call_one(cmdlines[0], actstr, _in=_in, out=out,
208 universal_newlines=universal_newlines),)
209 stdin, stdout, instr, outstr = self.__parse_args(_in, out)
210 procs = []
211 if getattr(self, 'verbose', None):
212 sys.stderr.write('### %s \n' % actstr)
213 sys.stderr.write(self.qjoin(cmdlines[0]) + instr + ' | ')
214 if not getattr(self, 'donothing', None):
215 try:
216 prevproc = subprocess.Popen(cmdlines[0], stdin=stdin,
217 stdout=PIPE, stderr=self._stderr, **self._pipeargs)
218 procs.append(prevproc)
219 except Exception as e:
220 self.raise_on_error(actstr, e)
221
222 for cmdl in cmdlines[1:-1]:
223 if getattr(self, 'verbose', None):
224 sys.stderr.write(self.qjoin(cmdl) + ' | ')
225 if not getattr(self, 'donothing', None):
226 try:
227 nextproc = subprocess.Popen(cmdl, stdin=prevproc.stdout,
228 stdout=PIPE, stderr=self._stderr, **self._pipeargs)
229 procs.append(nextproc)
230 prevproc.stdout.close()
231 prevproc = nextproc
232 except Exception as e:
233 self.raise_on_error(actstr, e)
234
235 if getattr(self, 'verbose', None):
236 sys.stderr.write(self.qjoin(cmdlines[-1]) + outstr + '\n')
237 if not getattr(self, 'donothing', None):
238 try:
239 lastproc = subprocess.Popen(cmdlines[-1], stdin=prevproc.stdout,
240 stdout=stdout, stderr=self._stderr,
241 universal_newlines=universal_newlines, **self._pipeargs)
242 prevproc.stdout.close()
243 procs.append(lastproc)
244 prevproc.stdout.close()
245 except Exception as e:
246 self.raise_on_error(actstr, e)
247
248 if stdin != PIPE and stdout!= PIPE:
249 # caller needs to wait after reading or writing (else deadlock)
250 for proc, cmdl in zip(procs, cmdlines):
251 res = proc.wait()
252 if res != 0:
253 self.raise_on_error(actstr,
254 'Nonzero exit (%d) from command [%s].'
255 % (res, self.qjoin(cmdl)))
256 return procs
257
258
259 ### end of proc_mixin.py
