root/Development/ray/src/common/pyradlib/pyrad_proc.py
Revision: 1.5
Committed: Wed Apr 27 16:29:48 2016 UTC (9 years, 8 months ago) by schorsch
Content type: text/x-python
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, HEAD
Changes since 1.4: +3 -3 lines
yet some more robustness
1 # -*- coding: utf-8 -*-
2 ''' pyrad_proc.py - Process and pipeline management for Python Radiance scripts
3 2016 - Georg Mischler
4
5 Use as:
6 from pyradlib.pyrad_proc import PIPE, Error, ProcMixin
7
8 For a single-file installation, include the contents of this file
9 at the same place (minus the __future__ import below).
10 '''
11 from __future__ import division, print_function, unicode_literals
12
13 import sys
14 import subprocess
15 PIPE = subprocess.PIPE
16
17
18 class Error(Exception): pass
19
20
21 class ProcMixin():
22 '''Process and pipeline management for Python Radiance scripts
23 '''
24 def raise_on_error(self, actstr, e):
25 try: self._strtypes
26 except AttributeError: self.__configure_subprocess()
27 if hasattr(e, 'strerror'): eb = e.strerror
28 elif isinstance(e, self._strtypes): eb = e
29 else: eb = e
30 if isinstance(eb, type(b'')):
31 estr = eb.decode(encoding='utf-8', errors='ignore')
32 else: estr = eb
33 raise Error('Unable to %s - %s' % (actstr, estr)) #
34
35 def __configure_subprocess(self):
36 '''Prevent subprocess module failure in frozen scripts on Windows.
37 Prevent console windows from popping up when not console based.
38 Make sure we use the version-specific string types.
39 '''
40 # On Windows, sys.stdxxx may not be available when:
41 # - built as *.exe with "pyinstaller --noconsole"
42 # - invoked via CreateProcess() and stream not redirected
43 try:
44 sys.__stdin__.fileno()
45 self._stdin = sys.stdin
46 except: self._stdin = PIPE
47 try:
48 sys.__stdout__.fileno()
49 self._stdout = sys.stdout
50 except: self._stdout = PIPE
51 try:
52 sys.__stderr__.fileno()
53 self._stderr = sys.stderr
54 # keep subprocesses from opening their own console.
55 except: self._stderr = PIPE
56 if hasattr(subprocess, 'STARTUPINFO'):
57 si = subprocess.STARTUPINFO()
58 si.dwFlags |= subprocess.STARTF_USESHOWWINDOW
59 self._pipeargs = {'startupinfo':si}
60 else: self._pipeargs = {}
61 # type names vary between Py2.7 and 3.x
62 self._strtypes = (type(b''), type(u''))
63
64 def qjoin(self, sl):
65 '''Join a list with quotes around each element containing whitespace.
66 We only use this to display command lines on sys.stderr, the actual
67 Popen() calls are made with the original list.
68 '''
69 def _q(s):
70 if ' ' in s or '\t' in s or ';' in s:
71 return "'" + s + "'"
72 return s
73 return ' '.join([_q(s) for s in sl])
74
75 def __parse_args(self, _in, out):
76 try: self._strtypes
77 except AttributeError: self.__configure_subprocess()
78 instr = ''
79 if _in == PIPE:
80 stdin = _in
81 elif isinstance(_in, self._strtypes):
82 if not getattr(self, 'donothing', None):
83 stdin = open(_in, 'rb')
84 else: stdin = None
85 instr = ' < "%s"' % _in
86 elif hasattr(_in, 'read'):
87 stdin = _in
88 instr = ' < "%s"' % _in.name
89 else: stdin = self._stdin
90 outstr = ''
91 if out == PIPE:
92 stdout = out
93 elif isinstance(out, self._strtypes):
94 if not getattr(self, 'donothing', None):
95 stdout = open(out, 'wb')
96 else: stdout = None
97 outstr = ' > "%s"' % out
98 elif hasattr(out, 'write'):
99 stdout = out
100 outstr = ' > "%s"' % out.name
101 else: stdout = self._stdout
102 return stdin, stdout, instr, outstr
103
104 def call_one(self, cmdl, actstr, _in=None, out=None,
105 universal_newlines=False):
106 '''Create a single subprocess, possibly with an incoming and outgoing
107 pipe at each end.
108 - cmdl
109 A list of strings, leading with the name of the executable (without
110 the *.exe suffix), followed by individual arguments.
111 - actstr
112 A text string of the form "do something".
113 Used in verbose mode as "### do someting\\n### [command line]"
114 Used in error messages as "Scriptname: Unable to do something".
115 - _in / out
116 What to do with the input and output pipes of the process:
117 * a filename as string
118 Open file and use for reading/writing.
119 * a file like object
120 Use for reading/writing
121 * PIPE
122 Pipe will be available in returned object for reading/writing.
123 * None (default)
124 System stdin/stdout will be used if available
125 If _in or out is a PIPE, the caller should call p.wait() on the
126 returned Popen instance after writing to and closing it.
127 '''
128 stdin, stdout, instr, outstr = self.__parse_args(_in, out)
129 if getattr(self, 'verbose', None):
130 sys.stderr.write('### %s \n' % actstr)
131 sys.stderr.write(self.qjoin(cmdl) + instr + outstr + '\n')
132 if not getattr(self, 'donothing', None):
133 try: p = subprocess.Popen(cmdl,
134 stdin=stdin, stdout=stdout, stderr=self._stderr,
135 universal_newlines=universal_newlines, **self._pipeargs)
136 except Exception as e:
137 self.raise_on_error(actstr, e)
138 if stdin != PIPE and stdout != PIPE:
139 # caller needs to wait after reading or writing (else deadlock)
140 res = p.wait()
141 if res != 0:
142 self.raise_on_error(actstr,
143 'Nonzero exit (%d) from command [%s].'
144 % (res, self.qjoin(cmdl)+instr+outstr+'\n'))
145 return p
146
147 def call_two(self, cmdl_1, cmdl_2, actstr_1, actstr_2, _in=None, out=None,
148 universal_newlines=False):
149 '''Create two processes, chained via a pipe, possibly with an incoming
150 and outgoing pipe at each end.
151 Returns a tuple of two Popen instances.
152 Arguments are equivalent to call_one(), with _in and out applying
153 to the ends of the chain.
154 If _in or out is PIPE, the caller should call p.wait() on both
155 returned popen instances after writing to and closing the first on .
156 '''
157 stdin, stdout, instr, outstr = self.__parse_args(_in, out)
158 if getattr(self, 'verbose', None):
159 sys.stderr.write('### %s \n' % actstr_1)
160 sys.stderr.write('### %s \n' % actstr_2)
161 sys.stderr.write(self.qjoin(cmdl_1) + instr + ' | ')
162 if not getattr(self, 'donothing', None):
163 try: p1 = subprocess.Popen(cmdl_1,
164 stdin=stdin, stdout=PIPE, stderr=self._stderr,
165 **self._pipeargs)
166 except Exception as e:
167 self.raise_on_error(actstr_1, e)
168 if getattr(self, 'verbose', None):
169 sys.stderr.write(self.qjoin(cmdl_2) + outstr + '\n')
170 if not getattr(self, 'donothing', None):
171 try:
172 p2 = subprocess.Popen(cmdl_2,
173 stdin=p1.stdout, stdout=stdout, stderr=self._stderr,
174 universal_newlines=universal_newlines, **self._pipeargs)
175 p1.stdout.close()
176 except Exception as e:
177 self.raise_on_error(actstr_2, e)
178 if stdin != PIPE and stdout != PIPE:
179 # caller needs to wait after reading or writing (else deadlock)
180 res = p1.wait()
181 if res != 0:
182 self.raise_on_error(actstr_1,
183 'Nonzero exit (%d) from command [%s].'
184 % (res, self.qjoin(cmdl_1)))
185 res = p2.wait()
186 if res != 0:
187 self.raise_on_error(actstr_2,
188 'Nonzero exit (%d) from command [%s].'
189 % (res, self.qjoin(cmdl_2)))
190 return p1, p2
191
192 def call_many(self, cmdlines, actstr, _in=None, out=None,
193 universal_newlines=False):
194 '''Create a series of N processes, chained via pipes, possibly with an
195 incoming and outgoing pipe at each end.
196 Returns a tuple of N subprocess.Popen instances.
197 Depending on the values of _in and out, the first and last may be
198 available to write to or read from respectively.
199 Most arguments are equivalent to call_one(), with
200 - cmdlines
201 a list of N command argument lists
202 - _in / out
203 applying to the ends of the chain.
204 If _in or out is PIPE, the caller should call p.wait() on all
205 returned Popen instances after writing to and closing the first one.
206 '''
207 if len(cmdlines) == 1:
208 # other than direct call_one(), this returns a one-item tuple!
209 return (self.call_one(cmdlines[0], actstr, _in=_in, out=out,
210 universal_newlines=universal_newlines),)
211 stdin, stdout, instr, outstr = self.__parse_args(_in, out)
212 procs = []
213 if getattr(self, 'verbose', None):
214 sys.stderr.write('### %s \n' % actstr)
215 sys.stderr.write(self.qjoin(cmdlines[0]) + instr + ' | ')
216 if not getattr(self, 'donothing', None):
217 try:
218 prevproc = subprocess.Popen(cmdlines[0], stdin=stdin,
219 stdout=PIPE, stderr=self._stderr, **self._pipeargs)
220 procs.append(prevproc)
221 except Exception as e:
222 self.raise_on_error(actstr, e)
223
224 for cmdl in cmdlines[1:-1]:
225 if getattr(self, 'verbose', None):
226 sys.stderr.write(self.qjoin(cmdl) + ' | ')
227 if not getattr(self, 'donothing', None):
228 try:
229 nextproc = subprocess.Popen(cmdl, stdin=prevproc.stdout,
230 stdout=PIPE, stderr=self._stderr, **self._pipeargs)
231 procs.append(nextproc)
232 prevproc.stdout.close()
233 prevproc = nextproc
234 except Exception as e:
235 self.raise_on_error(actstr, e)
236
237 if getattr(self, 'verbose', None):
238 sys.stderr.write(self.qjoin(cmdlines[-1]) + outstr + '\n')
239 if not getattr(self, 'donothing', None):
240 try:
241 lastproc = subprocess.Popen(cmdlines[-1], stdin=prevproc.stdout,
242 stdout=stdout, stderr=self._stderr,
243 universal_newlines=universal_newlines, **self._pipeargs)
244 prevproc.stdout.close()
245 procs.append(lastproc)
246 prevproc.stdout.close()
247 except Exception as e:
248 self.raise_on_error(actstr, e)
249
250 if stdin != PIPE and stdout!= PIPE:
251 # caller needs to wait after reading or writing (else deadlock)
252 for proc, cmdl in zip(procs, cmdlines):
253 res = proc.wait()
254 if res != 0:
255 self.raise_on_error(actstr,
256 'Nonzero exit (%d) from command [%s].'
257 % (res, self.qjoin(cmdl)))
258 return procs
259
260
261 ### end of proc_mixin.py
