| 1 |
schorsch |
1.1 |
# -*- coding: utf-8 -*-
| 2 |
''' pyrad_proc.py - Process and pipeline management for Python Radiance scripts
| 3 |
2016 - Georg Mischler
| 4 |
| 5 |
Use as:
| 6 |
from pyradlib.pyrad_proc import PIPE, Error, ProcMixin
| 7 |
| 8 |
For a single-file installation, include the contents of this file
| 9 |
at the same place (minus the __future__ import below).
| 10 |
| 11 |
from __future__ import division, print_function, unicode_literals
| 12 |
| 13 |
import sys
| 14 |
import subprocess
| 15 |
PIPE = subprocess.PIPE
| 16 |
| 17 |
| 18 |
class Error(Exception): pass
| 19 |
| 20 |
| 21 |
class ProcMixin():
| 22 |
'''Process and pipeline management for Python Radiance scripts
| 23 |
| 24 |
def raise_on_error(self, actstr, e):
| 25 |
schorsch |
1.5 |
try: self._strtypes
| 26 |
except AttributeError: self.__configure_subprocess()
| 27 |
schorsch |
1.3 |
if hasattr(e, 'strerror'): eb = e.strerror
| 28 |
elif isinstance(e, self._strtypes): eb = e
| 29 |
else: eb = e
| 30 |
if isinstance(eb, type(b'')):
| 31 |
estr = eb.decode(encoding='utf-8', errors='ignore')
| 32 |
else: estr = eb
| 33 |
raise Error('Unable to %s - %s' % (actstr, estr)) #
| 34 |
schorsch |
1.1 |
| 35 |
def __configure_subprocess(self):
| 36 |
'''Prevent subprocess module failure in frozen scripts on Windows.
| 37 |
Prevent console windows from popping up when not console based.
| 38 |
schorsch |
1.2 |
Make sure we use the version-specific string types.
| 39 |
schorsch |
1.1 |
| 40 |
# On Windows, sys.stdxxx may not be available when:
| 41 |
# - built as *.exe with "pyinstaller --noconsole"
| 42 |
# - invoked via CreateProcess() and stream not redirected
| 43 |
try:
| 44 |
sys.__stdin__.fileno()
| 45 |
self._stdin = sys.stdin
| 46 |
except: self._stdin = PIPE
| 47 |
try:
| 48 |
sys.__stdout__.fileno()
| 49 |
self._stdout = sys.stdout
| 50 |
except: self._stdout = PIPE
| 51 |
try:
| 52 |
sys.__stderr__.fileno()
| 53 |
self._stderr = sys.stderr
| 54 |
# keep subprocesses from opening their own console.
| 55 |
except: self._stderr = PIPE
| 56 |
if hasattr(subprocess, 'STARTUPINFO'):
| 57 |
si = subprocess.STARTUPINFO()
| 58 |
si.dwFlags |= subprocess.STARTF_USESHOWWINDOW
| 59 |
self._pipeargs = {'startupinfo':si}
| 60 |
else: self._pipeargs = {}
| 61 |
# type names vary between Py2.7 and 3.x
| 62 |
self._strtypes = (type(b''), type(u''))
| 63 |
| 64 |
def qjoin(self, sl):
| 65 |
'''Join a list with quotes around each element containing whitespace.
| 66 |
We only use this to display command lines on sys.stderr, the actual
| 67 |
Popen() calls are made with the original list.
| 68 |
| 69 |
def _q(s):
| 70 |
if ' ' in s or '\t' in s or ';' in s:
| 71 |
return "'" + s + "'"
| 72 |
return s
| 73 |
return ' '.join([_q(s) for s in sl])
| 74 |
| 75 |
schorsch |
1.2 |
def __parse_args(self, _in, out):
| 76 |
schorsch |
1.5 |
try: self._strtypes
| 77 |
schorsch |
1.2 |
| 78 |
instr = ''
| 79 |
if _in == PIPE:
| 80 |
stdin = _in
| 81 |
elif isinstance(_in, self._strtypes):
| 82 |
schorsch |
1.4 |
if not getattr(self, 'donothing', None):
| 83 |
stdin = open(_in, 'rb')
| 84 |
else: stdin = None
| 85 |
schorsch |
1.2 |
instr = ' < "%s"' % _in
| 86 |
elif hasattr(_in, 'read'):
| 87 |
stdin = _in
| 88 |
instr = ' < "%s"' % _in.name
| 89 |
else: stdin = self._stdin
| 90 |
outstr = ''
| 91 |
if out == PIPE:
| 92 |
stdout = out
| 93 |
elif isinstance(out, self._strtypes):
| 94 |
schorsch |
1.4 |
| 95 |
stdout = open(out, 'wb')
| 96 |
else: stdout = None
| 97 |
schorsch |
1.2 |
outstr = ' > "%s"' % out
| 98 |
elif hasattr(out, 'write'):
| 99 |
stdout = out
| 100 |
outstr = ' > "%s"' % out.name
| 101 |
else: stdout = self._stdout
| 102 |
return stdin, stdout, instr, outstr
| 103 |
| 104 |
schorsch |
1.1 |
def call_one(self, cmdl, actstr, _in=None, out=None,
| 105 |
universal_newlines=False):
| 106 |
'''Create a single subprocess, possibly with an incoming and outgoing
| 107 |
pipe at each end.
| 108 |
- cmdl
| 109 |
A list of strings, leading with the name of the executable (without
| 110 |
the *.exe suffix), followed by individual arguments.
| 111 |
- actstr
| 112 |
A text string of the form "do something".
| 113 |
Used in verbose mode as "### do someting\\n### [command line]"
| 114 |
Used in error messages as "Scriptname: Unable to do something".
| 115 |
- _in / out
| 116 |
What to do with the input and output pipes of the process:
| 117 |
* a filename as string
| 118 |
Open file and use for reading/writing.
| 119 |
* a file like object
| 120 |
Use for reading/writing
| 121 |
* PIPE
| 122 |
Pipe will be available in returned object for reading/writing.
| 123 |
* None (default)
| 124 |
System stdin/stdout will be used if available
| 125 |
If _in or out is a PIPE, the caller should call p.wait() on the
| 126 |
returned Popen instance after writing to and closing it.
| 127 |
| 128 |
schorsch |
1.2 |
stdin, stdout, instr, outstr = self.__parse_args(_in, out)
| 129 |
schorsch |
1.1 |
if getattr(self, 'verbose', None):
| 130 |
sys.stderr.write('### %s \n' % actstr)
| 131 |
schorsch |
1.2 |
sys.stderr.write(self.qjoin(cmdl) + instr + outstr + '\n')
| 132 |
schorsch |
1.1 |
| 133 |
schorsch |
1.2 |
try: p = subprocess.Popen(cmdl,
| 134 |
stdin=stdin, stdout=stdout, stderr=self._stderr,
| 135 |
schorsch |
1.1 |
universal_newlines=universal_newlines, **self._pipeargs)
| 136 |
except Exception as e:
| 137 |
schorsch |
1.3 |
self.raise_on_error(actstr, e)
| 138 |
schorsch |
1.1 |
if stdin != PIPE and stdout != PIPE:
| 139 |
# caller needs to wait after reading or writing (else deadlock)
| 140 |
res = p.wait()
| 141 |
if res != 0:
| 142 |
| 143 |
'Nonzero exit (%d) from command [%s].'
| 144 |
schorsch |
1.2 |
% (res, self.qjoin(cmdl)+instr+outstr+'\n'))
| 145 |
schorsch |
1.1 |
return p
| 146 |
| 147 |
def call_two(self, cmdl_1, cmdl_2, actstr_1, actstr_2, _in=None, out=None,
| 148 |
| 149 |
'''Create two processes, chained via a pipe, possibly with an incoming
| 150 |
and outgoing pipe at each end.
| 151 |
Returns a tuple of two Popen instances.
| 152 |
Arguments are equivalent to call_one(), with _in and out applying
| 153 |
to the ends of the chain.
| 154 |
If _in or out is PIPE, the caller should call p.wait() on both
| 155 |
returned popen instances after writing to and closing the first on .
| 156 |
| 157 |
schorsch |
1.2 |
| 158 |
schorsch |
1.1 |
| 159 |
sys.stderr.write('### %s \n' % actstr_1)
| 160 |
sys.stderr.write('### %s \n' % actstr_2)
| 161 |
schorsch |
1.2 |
sys.stderr.write(self.qjoin(cmdl_1) + instr + ' | ')
| 162 |
schorsch |
1.1 |
| 163 |
schorsch |
1.2 |
try: p1 = subprocess.Popen(cmdl_1,
| 164 |
stdin=stdin, stdout=PIPE, stderr=self._stderr,
| 165 |
**self._pipeargs)
| 166 |
schorsch |
1.1 |
| 167 |
schorsch |
1.3 |
self.raise_on_error(actstr_1, e)
| 168 |
schorsch |
1.1 |
| 169 |
schorsch |
1.2 |
sys.stderr.write(self.qjoin(cmdl_2) + outstr + '\n')
| 170 |
schorsch |
1.1 |
| 171 |
try:
| 172 |
schorsch |
1.2 |
p2 = subprocess.Popen(cmdl_2,
| 173 |
stdin=p1.stdout, stdout=stdout, stderr=self._stderr,
| 174 |
schorsch |
1.1 |
| 175 |
p1.stdout.close()
| 176 |
| 177 |
schorsch |
1.3 |
self.raise_on_error(actstr_2, e)
| 178 |
schorsch |
1.1 |
| 179 |
| 180 |
res = p1.wait()
| 181 |
if res != 0:
| 182 |
| 183 |
| 184 |
% (res, self.qjoin(cmdl_1)))
| 185 |
res = p2.wait()
| 186 |
if res != 0:
| 187 |
| 188 |
| 189 |
% (res, self.qjoin(cmdl_2)))
| 190 |
return p1, p2
| 191 |
| 192 |
def call_many(self, cmdlines, actstr, _in=None, out=None,
| 193 |
| 194 |
'''Create a series of N processes, chained via pipes, possibly with an
| 195 |
incoming and outgoing pipe at each end.
| 196 |
Returns a tuple of N subprocess.Popen instances.
| 197 |
Depending on the values of _in and out, the first and last may be
| 198 |
available to write to or read from respectively.
| 199 |
Most arguments are equivalent to call_one(), with
| 200 |
- cmdlines
| 201 |
a list of N command argument lists
| 202 |
- _in / out
| 203 |
applying to the ends of the chain.
| 204 |
If _in or out is PIPE, the caller should call p.wait() on all
| 205 |
returned Popen instances after writing to and closing the first one.
| 206 |
| 207 |
if len(cmdlines) == 1:
| 208 |
# other than direct call_one(), this returns a one-item tuple!
| 209 |
return (self.call_one(cmdlines[0], actstr, _in=_in, out=out,
| 210 |
universal_newlines=universal_newlines),)
| 211 |
schorsch |
1.2 |
| 212 |
schorsch |
1.1 |
procs = []
| 213 |
| 214 |
| 215 |
schorsch |
1.2 |
sys.stderr.write(self.qjoin(cmdlines[0]) + instr + ' | ')
| 216 |
schorsch |
1.1 |
| 217 |
try:
| 218 |
prevproc = subprocess.Popen(cmdlines[0], stdin=stdin,
| 219 |
stdout=PIPE, stderr=self._stderr, **self._pipeargs)
| 220 |
procs.append(prevproc)
| 221 |
| 222 |
schorsch |
1.3 |
| 223 |
schorsch |
1.1 |
| 224 |
for cmdl in cmdlines[1:-1]:
| 225 |
| 226 |
sys.stderr.write(self.qjoin(cmdl) + ' | ')
| 227 |
| 228 |
try:
| 229 |
nextproc = subprocess.Popen(cmdl, stdin=prevproc.stdout,
| 230 |
| 231 |
procs.append(nextproc)
| 232 |
prevproc.stdout.close()
| 233 |
prevproc = nextproc
| 234 |
| 235 |
schorsch |
1.3 |
| 236 |
schorsch |
1.1 |
| 237 |
| 238 |
schorsch |
1.2 |
sys.stderr.write(self.qjoin(cmdlines[-1]) + outstr + '\n')
| 239 |
schorsch |
1.1 |
| 240 |
try:
| 241 |
lastproc = subprocess.Popen(cmdlines[-1], stdin=prevproc.stdout,
| 242 |
| 243 |
| 244 |
| 245 |
procs.append(lastproc)
| 246 |
| 247 |
| 248 |
schorsch |
1.3 |
| 249 |
schorsch |
1.1 |
| 250 |
if stdin != PIPE and stdout!= PIPE:
| 251 |
| 252 |
for proc, cmdl in zip(procs, cmdlines):
| 253 |
res = proc.wait()
| 254 |
if res != 0:
| 255 |
| 256 |
| 257 |
% (res, self.qjoin(cmdl)))
| 258 |
return procs
| 259 |
| 260 |
| 261 |
### end of proc_mixin.py
