root/radiance/ray/src/common/process.c
Fri Jan 15 19:01:53 2021 UTC (3 years, 4 months ago) by greg
CVS Tags: HEAD, rad5R4
fix: more 64-bit fixes
Fri Apr 3 17:06:16 2020 UTC (4 years, 2 months ago) by greg
Changes since 2.9: +1 -3 lines
Added input ray queue for more efficient batch processing
Fri Feb 28 05:18:49 2020 UTC (4 years, 3 months ago) by greg
Changes since 2.8: +10 -10 lines
Fri Sep 17 21:43:49 2004 UTC (19 years, 8 months ago) by greg
Changes since 2.6: +25 -85 lines
Changes since 2.4: +60 -4 lines
Fri Apr 16 10:26:45 1993 UTC (31 years, 1 month ago) by greg
Changes since 2.3: +18 -4 lines
made readbuf() and writebuf() retry after interrupted system call
Thu Apr 1 11:08:05 1993 UTC (31 years, 2 months ago) by greg
fixed potential bug in readbuf() and writebuf() for zero requests
Thu Mar 19 09:32:02 1992 UTC (32 years, 2 months ago) by greg
Changes since 2.1: +1 -3 lines
added vfork.h include file
Tue Nov 12 16:56:02 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.1: +0 -0 lines
Diff to previous 1.1 , to selected 2.6
Tue Jul 23 15:56:57 1991 UTC (32 years, 10 months ago) by greg
Diff to selected 2.6
